Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
A Malanthrope
 Post subject: A Malanthrope
PostPosted: Sat Feb 02, 2008 2:58 am
(Pulsar @ Feb. 01 2008,20:49)
it's offical the next time we play Epic and you use those nids, i'm going to take them and run away while laughing like a girl!!!!!!!
You have another kind of laugh? :D
PostPosted: Sat Feb 02, 2008 3:00 am
(zombocom @ Feb. 02 2008,00:27)
(Otterman @ Feb. 01 2008,20:16)
What's up with the 'alledged rippers'? I see some vaguely round shapes and some of your Tyranid colors. Is it supposed to be a carpet-like mass of rippers?
There are 3 rippers in each 'pile' of them, and four piles on the base. The close up does them a disservice actually.
I'm gonna be immodest and say that Zombo is correct. :)
I'll try and snap a better picture of them... in fact, casting those 'alledged' rippers has convinced me it *may* be possible for me to cast Raveners / updated Warriors.
PostPosted: Sun Feb 03, 2008 2:10 am
Immodest isn't a word. You mean conceited...
PostPosted: Sun Feb 03, 2008 11:55 pm
So what's the stats on this bad Boy !? 1 per base like Lictors ?  Have the stats been added to the latest v. ?  Come on boys, there is a War on !  I need intell !  :O
PostPosted: Sun Feb 03, 2008 11:57 pm
It's not in the standard tyranid list, since that is more representative of the 2nd edition 40k nids than the current style.
PostPosted: Mon Feb 04, 2008 12:06 am
So what would those stats be ?
PostPosted: Mon Feb 04, 2008 12:46 am
Well, in 4ok it has similar stats to a hive tyrant, can spawn rippers and if any wounds it cause get through armour saves it causes instant death.
So probably something roughly like:
Type: AV   Speed: 15cm  Armour: 4+ Close combat: 3+ Firefight 5+
Weapons:
Rippers:   (small arms) EA(+1) ignore cover
       AND (assault weapons) EA(+1) ignore cover
Feeder Tentacles: (assault weapons) EA+1 Sniper.
Notes: Fearless, Invulnerable Save, Reinforced Armour, Synapse(+3)
Or something along those lines anyway I'd imagine.
PostPosted: Mon Feb 04, 2008 12:54 am
Looks about right to me.
It's meant to be faster than a Hive Tyrant though, so I'd probably go with 20cm speed.
PostPosted: Mon Feb 04, 2008 1:02 am
I would drop the Reinforced Armour, because Hive Tyrant units stats include the Tyrant Guards.
The FF attacks are a good way to represent the ground around the Malanthrope bristling with Ripper Swarms :)
PostPosted: Mon Feb 04, 2008 1:05 am
I'm dubious on this one, as a Malanthrope is harder to kill than a Carnifex (Same toughness (6) and number of wounds (4), better armour save (2+ vs 3+ for the fex) and also has an invulnerable save which a carnifex lacks.).
Also, the Hive Tyrant's 4+RA doesn't represent the Tyrant Guard IMHO. It just represents the fact that a winged Tyrant tends to be easier to kill.
PostPosted: Mon Feb 04, 2008 1:12 am
(zombocom @ Feb. 03 2008,01:10)
I believe you are incorrect.
im?mod?est
adj.
1. Lacking modesty.
2.
a. Offending against sexual mores in conduct or appearance; indecent: a bathing suit considered immodest by the local people.
b. Not properly restrained in expression or self-assertion; boastful: immodest claims in advertising and promotion.
3. Arrogant.
PostPosted: Mon Feb 04, 2008 1:18 am
Fair enough, but it's clunky. Conceited is a much more elegant word.
PostPosted: Mon Feb 04, 2008 1:19 am
Ok. I followed zombocoms statement that the Malanthrope has similar stats as a Hive Tyrant and hadn't looked them up myselve.
If the Malanthrope has indeed identical stats regarding to Toughness, Wounds and armour as a Carnifex then it should use Reinforced Armour.
PostPosted: Mon Feb 04, 2008 4:30 am
So there'd be 1 on a base ?   And what are the final stats.  We've taken the exercise this far ... What's the bottom line ?  And good job ! :D
PostPosted: Mon Feb 04, 2008 5:22 am
Definitely 1 per base, they're roughly equivilent in usage to Hive Tyrants, except they're followed by swarms of little rippers.
I'll be playing him with these stats:
Type: AV   Speed: 20cm  Armour: 4+ Close combat: 3+  Firefight 5+
Weapons:
That puts it roughly on par with a Hive Tyrant... it's a bit faster (5cm), but it has no shooting attack, and is slightly sub-par compared to the Tyrant in CC, as its Sniper attack isn't allowed by the rules to spread beyond B2B contact. On the other hand, it's better in a FF situation than a Tyrant.
It is also cool! :D
Same cost and place in the army list as a Hive Tyrant  I think (So where it says I can take a Hive Tyrant or a Winged Hive Tyrant, maybe I'll take a Malanthrope instead)...
Users browsing this forum: No registered users and 149 guests
