Post new topic Reply to topic  [ 1935 posts ]  Go to page Previous  1 ... 94, 95, 96, 97, 98, 99, 100 ... 129  Next
Vaaish's random army painting log
 Post subject: Re: Vaaish's random army painting log
PostPosted: Fri Nov 14, 2014 3:30 pm
That predator looks like it could beam some conversion juice onto something... or someone.
PostPosted: Fri Nov 14, 2014 3:31 pm
Thanks!
do you wet blend or use layering or what? I'm trying to teach myself wet blending and it's a time consuming technique when you're just starting out..
Well I'm putting together a tutorial for this particular scheme that might help. It's really very rare that I use wet blending though. The nature of acrylics means they dry very quickly when using them thinned out and in very small areas which makes it very difficult to get color A in place and color B on before the first color has dried too much for a good blend even with retarders. Wet blending works best in larger areas like terrain.
Pretty much everything I do at this point is based on feathering. One brush puts a layer down and a second brush blends the edges. That's the technique I used on the turret up there. Black is more forgiving though since you can just hit it with a black wash to tone it down to the proper level.
The last option is glazing. I don't do this unless I'm toning an area like after I finish metals to bring back some color or to tint an area/ enhance a color without repainting the whole thing. You can use this to build up very smooth highlights but it's extremely time consuming and I get impatient most of the time.
-Vaaish
PostPosted: Fri Nov 14, 2014 6:07 pm
will have to try feathering, my last experiment with wet blending was a void spinner which took well in excess of 10 hours to paint, most of which was spent trying to get even wet blends on the panels.... I just can't get the hang of seriously watered down glazes, I find that even a small amount of water ends up with me pushing blobs of paint around rather than creating smooth even layers..... ah well!
PostPosted: Fri Nov 14, 2014 6:36 pm
well with glazes you don't want a blob of water on things. You want a very thin layer. If it's blobbing up then your applying it like a wash which will probably end in frustration.
-Vaaish
PostPosted: Fri Nov 14, 2014 7:56 pm
Your technique is excellent as usual on the Sons of Horus vehicles but the colour you've used for them is WAY off - yours are a bit pale but I initially thought you'd meant them to be Salamanders.
Sons of Horus use a darker colour, that's more of a bluey-green. Like this:
Maybe try repeated glazes all over the green to drag it back to the proper colour?
Heh, yes. I thought that too and had already decided that version to be best for a Slaanesh Predator.
PostPosted: Fri Nov 14, 2014 8:33 pm
Gyln, the painted FW ones don't match the art in the HH books or the November WD army. Even among the FW models there is variation in color between green blue and blue green as well as the value of the hue. In fact, the SoH scheme is list as "light green" which none of the FW examples are even close to.
When painting various army schemes, the artist has a pretty free hand in interpreting exactly what is meant by the described color scheme. For instance, Ultramarines can be painted up in anything from pastels to rich navy blue and Imperial Fists can get anything from a brownish yellow to golden or solid yellow.
-Vaaish
PostPosted: Fri Nov 14, 2014 8:54 pm
Fair enough. There is some divergence between the colour schemes in various places, but all the art for them in the HH books is still distinctly a pale bluey-green (admittedly a different shade of bluey-green to the ones they painted the FW models in) and closer to one or the other might have been better IMO if you'd wanted them to be recognised as SoH.
PostPosted: Sat Nov 15, 2014 3:25 am
Those look excellent, right color or not!
PostPosted: Wed Dec 24, 2014 9:48 pm
Hey guys, I finished painting up the first Helian Firedrake just in time for Christmas. Hope you like it! Merry Christmas everyone!
-Vaaish
PostPosted: Wed Dec 24, 2014 10:07 pm
THAT is awesome.
PostPosted: Wed Dec 24, 2014 10:17 pm
Most awesome!
PostPosted: Wed Dec 24, 2014 10:50 pm
:o Luckily, in Space no one can hear the screams of joy! Inspiring stuff.
PostPosted: Wed Dec 24, 2014 11:04 pm
Thanks guys!
-Vaaish
PostPosted: Thu Dec 25, 2014 12:07 am
Stunning. Very impressive!
