Post new topic Reply to topic  [ 1676 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 112  Next
 Post subject: Re: My random forces, Imperium, Chaos etc. + project Spike
PostPosted: Mon Jul 30, 2012 5:47 pm
Some more progress on Spike. :)
Plasma weapons fitted to ceiling and weapon room progress. Also started detailing on the lower hull.
One of the lower hull edges is broken so i will need to fix it. You can see the damage on the right edge in the last pic.
PostPosted: Wed Aug 01, 2012 6:13 pm
Weapons in position. They are still removable to ease painting.
PostPosted: Thu Aug 02, 2012 5:39 pm
Decided to stick these plastic clips to the lower rim to add interest. What do you think.
PostPosted: Thu Aug 02, 2012 6:33 pm
Yep, clips work :) looking good
PostPosted: Fri Aug 03, 2012 3:13 am
More.
PostPosted: Fri Aug 03, 2012 7:29 am
Keep up the good work dude, clips look good!
PostPosted: Fri Aug 03, 2012 11:57 am
jprp wrote:
More.
OK try these. Progress to date. :)
PostPosted: Mon Aug 06, 2012 7:25 pm
Some progress on Spike.
Fixed the damage to the rim with plastic sheet, ended up laminating the lot, then added panel lines to the bottom hull with plastic stripe, and fixed undercarriage defence guns in place.
Also started adding extra bits to the weapons and gun room.
PostPosted: Mon Aug 06, 2012 7:27 pm
Just a few pics of what it looks like at the moment.
PostPosted: Mon Aug 06, 2012 9:33 pm
Impressive!
PostPosted: Tue Aug 07, 2012 5:55 pm
Hey thanks Blindhorizon much appreciated.
PostPosted: Mon Aug 27, 2012 5:25 pm
Its been awhile so heres a small update.
Making good progress on the main hull, but need to get more plastic channel to be able to finish it as i want.
I have added secondary weapon turrets and close defence ball turrets, also a rear armoured intake and i have started to add chaos markings in the form of FW etched brass.
Still undecided on if i will add a bridge section to the front and/or maybe some anti aircraft weapons.
What do you think so far?
PostPosted: Mon Aug 27, 2012 6:02 pm
Love it
PostPosted: Tue Aug 28, 2012 12:05 am
What DC is this?
When do we get to see paint!!!!!
PostPosted: Tue Aug 28, 2012 1:11 am
Blindhorizon wrote:
What DC is this?
DC 20 but commisars kill it on a 2+ ;)
