Post new topic Reply to topic  [ 441 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 30  Next
Ghost's Paint Blog
 Post subject: Re: Ghost's Paint Blog
PostPosted: Sun Dec 05, 2010 10:29 am
Cool work until now
I really like your blue/grey colorsheme
PostPosted: Sun Dec 26, 2010 9:01 pm
Almost a month. Too long with out an update!
For anyone planning on magnetizing their EW tanks, a note of caution: The vision slits in the Elektra are magnetizable, but DO NOT use sprue cutters to remove the turret peg. It will deform and or destroy the insert. However, a razor saw does work to remove the peg. And it only took two destroyed inserts to conclusively prove this. Remember folks, replicability is a key requirement in any good experiment! Otherwise the Elektra went off without a hitch, in fact the cannon was one of the easiest pieces to magnetize yet.
No new painted stuff, primarily due to lack of motivation, but partly due to poor weather to prime in, and no primed turrets, just hulls. My ADHD also played a part. But the distractions are coming along well...
PostPosted: Sun Dec 26, 2010 9:52 pm
More nice tanks
those EW models are pretty cool
PostPosted: Mon Dec 27, 2010 4:29 am
Nice Panzers !
PostPosted: Sun Jan 16, 2011 11:35 pm
WIPs of the first of a pair or Warbarques I've been commissioned to build...
PostPosted: Mon Jan 17, 2011 4:20 pm
Looks good so far. ;)
How large is that Warbarque?
WAAARGH!!
The Lost & the Dipped
PostPosted: Mon Jan 17, 2011 4:44 pm
Primary hull is a box 42mm L x 25mm W x 15mm H
Overall dimensions, not including gun barrels, are 58mm L x 35mm W x 30mm H.
I think I'm done here, but possible some side panels will be added. Not sure the best way to go about it, though. Suggestions are welcome.
3/4 Front
3/4 Rear
Front
PostPosted: Mon Jan 17, 2011 8:13 pm
Very, very nice !!!
PostPosted: Mon Jan 17, 2011 10:32 pm
maybe glowy strip bits like on the monoliths or buttresses could work?
-Vaaish
PostPosted: Mon Jan 17, 2011 10:47 pm
Butresses were an option, but they would fill the gaps between the panels on the runners at this point.
As for the glowy bits, I'm not sure they would fit into the overall feel. There's not enough room to do them vertically (about 8mm from the runner to the roof IIRC), and horizontally would look... odd, I think. Too much like racing stripes. Hmmm.
PostPosted: Mon Jan 17, 2011 10:56 pm
Not sure, but I think they would look fine as power conduits feeding the weapons on the side.
-Vaaish
PostPosted: Mon Jan 17, 2011 11:24 pm
Not convinced, but it's not glued on. Was this what you had in mind?
Stupid flash...
PostPosted: Tue Jan 18, 2011 12:19 am
I think if you make the side lines not just straight across, like with some corners or some angles , it would look cool.
PostPosted: Tue Jan 18, 2011 1:09 am
Lately I've been trying to scam up neat ideas to manufacture in pewter. One of said ideas was cabling. Dragonforge already makes pewter cables based off of guitar strings (notoriously tough and hard to bend).
Perhaps a good idea for a pewter conversion cable would be something like this, flat on one edge to be glued up again plasticard.
Would such a thing prove useful in these sorts of circumstances?
PostPosted: Tue Jan 18, 2011 1:14 am
I like! That's something I could use! Email me about a foot of the stuff. Don't worry, I've got a printer. ;)
