2026 QoL Proposals
 Post subject: 2026 QoL Proposals
PostPosted: Thu Jul 16, 2026 7:56 pm
Putting these forward as playtest changes for the rest of the year.
Skitarii
  • Remove AA shot line from Colossus Robot's Autocannon
  • Remove AA6+ from Ordinatus Majoris Heavy Bolter
  • Remove AA6+ from Ordinatus Minorus Heavy Bolter
  • Change Ordinatus Majoris crit to "5cm of the model suffer a hit on a 4+"
  • Change Ordinatus Minorus crit to "5cm of the model suffer a hit on a 5+"
Slaves to Darkness
  • Add 0–1 per allegiance to Daemon Prince upgrade
Stigmatus Covenant
  • Drop the Factions special rule and change initiative to a flat 2+.
  • Add "This formation has Daemonic Pact and adds one lesser daemon to the Daemon Pool." to the Coven formation.
  • Remove the Daemonic Pact upgrade.
  • Drop Greater Daemon cost to +50 points
  • Drop Lesser Daemon cost to +15 points
Slaves to Darkness/Stigmatus Covenant
  • Add "(add up to three Defilers) (+75 points each) to Defiler formations
Black Legion
  • Allow Sorcerer in Havocs formation
Black Legion/Red Corsairs
  • Drop Defiler formation to 250 points, add Defilers upgrade
Iron Warriors
  • Drop Defiler formation to 400 points
Krieg
  • Add note to Commissars rule: You may not add a Commissar to a unit from a Company upgrade.
Gargant Mob
  • Add Battlewagon upgrade for +25 points and add it to the Loota Warband
Ork War Horde
  • Add Battlewagon extra to Kommando Warhorde for +25 points each
Imperial Fist
  • Change Rapier transport note to "Counts as a Terminator unit for the purposes of being transported."
  • Change Thudd Gun transport note to "Counts as a Terminator unit for the purposes of being transported."
Scions of Iron
  • Change commander upgrade to match Codex List.
  • Add Prometheus upgrade option to replace a Land Raider with a Land Raider Prometheus for +25 points.
Squat
  • Change Berserker to 175/325/475
Tyranids
  • Drop Tyrgon upgrades to +50 points each in the Trygon Swarm
 Post subject: Re: 2026 QoL Proposals
PostPosted: Thu Jul 16, 2026 8:36 pm
For ork war horde: what do you mean? I'm having trouble parsing that sentence.
PostPosted: Thu Jul 16, 2026 9:10 pm
thirds guns are towed weapons. No toe-y No move-y
mattie
http://maashes.blogspot.com/
PostPosted: Thu Jul 16, 2026 9:41 pm
If you don't mind my asking - what's driving removing the AA from Colossi & Ordinatus in the Skitarii list?
Also, if we're taking the AA off the Ordinatus, we probably should take it off the Ordinatus Medrengard in the Iron Warriors list, too.
No issues with dropping Defilers down to 400 for 6. Point matching Black Legion would take them down to 6 for 375, but I can see the purpose in a 25 point tax since they're a Core choice.
Instagram: https://www.instagram.com/armiger84/?hl=en
My General Modelling Blog: http://armiger84.blogspot.com/
PostPosted: Fri Jul 17, 2026 2:58 am
Whoops, I think I lost track of what I was copying and pasting. It's fixed now.
I misinterpreted Harry on the Discord channel, this change will likely be dropped.
The Marjoris is less of an issue, I put it in there for testing though. The IW is even less than that, being 0-1 in a 3k list and also being that it's a Chaos list where there's a dearth of AA.
Between the Hydra, Colossus, Minoris and potential Titan AA there's no other list that can come close to lacing up a board with AA shots. Coupled with the fact that the majority of those shots can be on shielded WEs it makes it particularly nasty and a bit of a crutch. Most lists get by with 1 ground AA option, AdMech has 4, excluding Titans.
PostPosted: Fri Jul 17, 2026 1:03 pm
I'm on board with these updates/changes. Thanks for putting this together for the community Dave.
PostPosted: Tue Jul 21, 2026 4:45 pm
I propose reducing the cost of the Battlewagon in the Ork Speed Freek list from 35 points to 25 points in order to bring it into line with the current Battlewagon point cost in the War Horde list and the proposed Battlewagon upgrade point cost in the Gargant Mob list.
Thank you.
