2025 Quality of Life Proposals
 Post subject: 2025 Quality of Life Proposals
PostPosted: Tue Feb 18, 2025 9:25 pm
Similarly to what we did in 2023, the New England group is putting forward some changes that we will be testing through-out 2025. If they work out we'd like to put them up for an ERC vote in December. If you have other suggestions and/or thoughts or concerns on these please voice them here or on the Discord. The majority of these are innocuous and are the result of us playing with the lists the last couple of years. A few will definitely need some some more testing though.
Adeptus Mechanicus – Titan Legion
  • Remove the God Machines rule. New England has played this way for years and it hasn't been an issue for us.
Adeptus Mechanicus – Skitarii Legion
  • Sagitarii, Skitarii and Praetorian Maniple formations can access to a "formation leader" upgrade that works like Bonded Team from the Tau list. The list has no leader on infantry units beyond the SC, which is pretty rough for an army that's supposed to be lock step with its commanders.
  • Reduce the Rapier upgrade on the Sagitarii to +0 points. Taking the upgrade means you lose two units and are hamstrung with a 10cm speed unit, +25 seemed too unattractive.
Ork – Feral Orks
  • Add the following underlined text to the Junkatrukk note: Units being transported may shoot and use their firefight value in an assault or to lend support. Dark Eldar have been using this and it hasn’t been an issue for us.
  • Orkeosaurus and Squiggoth gain walker because they have legs... And it’s also weird that the Steam Gargant has it and they don’t.
  • Add a Squigg Katapult Horde to get some more mileage out of the model:
Code:
Squig Katapult Horde | Five Squig Katapults | 125 | 225 | 325 |
* Add any number of Squig Katapults for +25 points each
* Add up to one Nobz for +35 points
* Add up to one Wyrdboy character to any unit for +50 points
Ork – Gargant Mob
  • Stompamob change from War Horde below.
  • Change Mega-Lobba to Arm weapon mount only (effectively 0-2 of them per unit) to reduce BM spam.
  • Change Ultra-Lobba to Arm weapon mount only (effectively 0-2 of them per unit) and change Firepower to 2D3+3BP to reduce BM spam.
  • Increase Gatling Cannon to +50 points because it’s a lot of shots.
Ork – Speed Freeks
  • Wherever Nobz are referenced in extra units for +35 make it “Nobz and Trukk”. Also, in the Warband extras, the Nobz/Nob Warbike replacement should be changed so the Nob and Trukk have to be given up to get the Nob Warbike. Looking at the EpicUK list and Tim’s post here I think this has always been the intention.
  • Add the following extra to the Kult of Speed: Add up to one Nob Warbikes unit for +35 points. This seems like an oversight given you can get Nobz in all the other formations bar the outriders.
  • Add the following underlined text to the Trukk note: Units being transported may shoot and use their firefight value in an assault or to lend support. Dark Eldar have been using this and it hasn’t been an issue for us.
  • Add a Guntrukk unit (LV/35cm/5+/6+/6+/Big Gun/-) for +25 to the Warband and allow it in the core units along with Scorcha/Warbike/Warbuggy. The CC and FF are reduced to keep the Warbuggy a competitive option.
Ork – War Horde
  • Change the Stompamob to 3 Stompas for 175/300/425. I think it was Rastaman that brought this up, but the 2023 change to 4 Stompas as core units would not be backwards compatible and that’s something I’d like to correct. So this roles back the core unit change while keeping the point reductions from 2023.
Space Marine – Codex Astartes (and others where applicable)
  • Reduce Vindicator formation cost to 200 points to make them more appealing.
  • The Attack Bike is pretty under-utilized and uncompetitive compared to the similarly costed Land Speeder. As a proposed fix: change the Bike formation to the following (Multi-melta Attack Bike is same as the Salamander Attack Bike):
Code:
Bike | Five Attack Bikes | 150 points |
* Replace any number of Attack Bikes with an equal number of any of the following units for +10 points each: Bike, Mutli-melta Attack Bike
Space Marine – Imperial Fists and Dark Eldar
Add the following notes to the Bastion and Barge of Pleasure to clear up how the WE rules work with transported formations shooting.
Transported units do not have to disembark in order to shoot or use their firefight value if this unit is able to shoot, assault or lend support. Measure to this unit for the purposes of determining line of fire, range and suppression of the transported units. If the transported units are not able to physically fit on the this unit's model use an off-board piece of card to show their relative position for the purposes of suppression.
Space Marine – White Scars
  • Attack Bike change from Codex list.
  • Add Scout Bike unit (INF/35cm/5+/4+/4+/Scout) and formation of 4 for 175 points to help differentiate the list more.
  • Add Vindicator formation of 4 for 200 points to add some more list flexibility.
Tyranid
  • Add a renamed Wraithgate to the army, +50 points, works exactly like the Eldar one. This is the biggest change here and the one most in need of testing.
  • Change Tyranid Swarm 0-1 per army restriction on Dominatrix to 0-1 per 2,000 points. A 0-1 limit is too restrictive for higher point games.
  • Drop Dactylis Swarm price to 250/475/675, extras for +75 each. They are too expensive right now at 300 points for a small formation.
  • Add Harridan Swarm option for 4 Gargoyles for +75 points. Makes for an easier list build, individual gargoyles at +20 will stay too.
  • Up War Engine formation limit to 1/3 total points. A few players were calling for this on the Discord.
  • Give Carnifex Bio-plasma the following profile: 15cm AP5+/AT6+. Acquiescing for a certain player on Discord. :P
  • Change the Genestealer Swarm to 6 Genestearlers for 150/-/-/. Same reasoning as the Stompamob above.
  • Change the Trygon Swarm to 3 Trygons for 200/-/-/Add up to 3 Trygons for +60 points each. Same reasoning as the Stompamob above.
Necron Special Rule
  • Because I’m tired of always looking this up, add the following underlined text to the Necron rule: Formations can return one previously destroyed Necron unit in the end phase of each turn, before all formations attempt to rally, either on or off the board.
Summed Units Special Rule (all Chaos lists)
  • The following is a rewrite of Summoned Units rule with the intent to extract which units can be summoned into army specific special rules (e.g. Death Guard summons Nurgle daemons and doesn’t need to mention Tzeentch daemons in its special rule). There’s no gameplay changes here.
Each formation in a Chaos army owes allegiance to Chaos Undivided or one of the four chaos gods: Khorne, Nurgle, Slaanesh or Tzeentch. The Chaos player must declare each formation’s allegiance before the battle, noting it down on their army list. Unbroken formations with Daemonic Pact are able to summon daemons with a similar allegiance to the battlefield from the Daemon Pool.
Daemons in the Daemon Pool are noted only as being lesser or greater daemons when they are purchased, they should be thought of as markers. The Chaos player must declare the number of lesser and greater daemons in the Daemon Pool in some fashion that is easily apparent to their opponent at all times. The Daemon Pool is kept off the board and daemons are removed from it as formations summon daemons to the battlefield.
A formation may summon daemonic units from the Daemon Pool as part of its action before declaring which action it will carry out. The formation generates 2d3 summoning points that can be used to move daemons from the Daemon Pool to the battlefield where they are converted to actual daemonic units. The allegiance of the summoning formation determines which daemonic units it may summon, while the daemonic units available to summon (and their respective summoning point costs) are defined in the specific Chaos army lists. Summoning points must be used immediately or lost, but un-summoned daemons in the Daemon Pool remain to be summoned by other formations or on later turns.
Summoned daemonic units must be placed within 5cm of a unit from the formation that was there prior to summoning, you may not place a “chain” of summoned units. They also may not be placed in enemy zone of control or in impassable terrain. Finally, an army may only have one greater daemon with a given allegiance on the battlefield at any one time. Summoned daemonic units count as part of the formation that summoned them while they remain on the battlefield.
Daemonic units that are destroyed are removed from play and not put back into the Daemon Pool. If a formation with daemonic units is broken then all the daemonic units are removed from play as well. If a formation with daemonic units loses an assault (see Work Out Result) the extra hits it suffers occur before it becomes broken and the daemonic units are removed from play. Also note that daemonic units do count towards the “For each kill you have inflicted during the assault” assault modifier of your opponent.
In the End phase, after all rally tests, all summoned daemonic units are converted back into daemon markers and returned to the Daemon Pool. Note that this may lead to the formation breaking. War Engine units that are returned to the Daemon Pool keep their current DC and do not heal back to full DC. If they are summoned again they will have the same DC they had before being returned to the Daemon Pool.
As an example of what the army specific rules for which units can be summoned will look like see the Hedonic Crusade list.
 Post subject: Re: 2025 Quality of Life Proposals
PostPosted: Fri Feb 28, 2025 2:11 am
Add the transported unit shooting/FFing note change for Imperial Fists and Dark Eldar.
We had some games over the weekend, testing the Gargant and Skitarii changes.
PostPosted: Sat Mar 01, 2025 8:15 pm
Giving Orkeosuruses and Squiggoths walker will in practice be a signifigant boost to the effectiveness of the Ferals list. They'll alway toe into cover whever possible then when usually I wouldn't risk it. I'm not sure this is needed or a good idea? I speak as someone who plays with a Ferals army occasionally too. Sure the giant beasties have legs but they're always awkward and truly gigantic beasties. If they have to squeeze through trees or between shattered ruins I don't have a problem with them having a reasonable risk of damage from getting stabbed by a tree while trying to smash through some wood or whatever.
The Ferals Katapult Horde looks bonkers over powered for the cost. Have you thought it through? For 225 you can have a 10 barrage point barrage with disrupt garrisoned forward on overwatch. Direct only sure but that's excessive. I would suggest a rethink and a heft points boost. To be honest I don't know that I see the need for the formation in the first place - I usually take 2 x Wildboy formations + 3 Kapaults in my 3k list so katupults get used regularly for me. For 200 for each formation you get a decent forward garrison that can shoot and defend itself in CC.
What actually seems to be the main issue with Ferals is that the usual list with loads of slow 4++ armour tends to end up mostly in draws (way higher % of draws than any other faction at UK tournaments using the near identical list). Often as games run out of time and as the Ferals struggle to get their slow stuff across enough to get the objectives while the enemy will struggle to kill or stop enough to win themselves. Made worse by most canny players aware of how slow Ferals are will chose to play corners if they play them and have higher strat so that the Ferals have even further to go. I wonder whether they could have a special rule where an Orkeosaurus crew can push their beast harder if they choose and add +5cm to one move per tern (definitely only a single move and not 2 or 3 times for a double or march as that would go too far) but they have to then roll a dice and on a 1 they get a critical hit (the usual lose 1 DC and rampage 3D6 in a random direction). That would then help slightly in them getting to the enemy, but with a risk and added orky randomness.
Vindicators at 200 sounds great! I've suggested this before myself.
Nice idea with the Attack Bikes too.
PostPosted: Sat Mar 22, 2025 1:02 pm
Been a bit busy to add my five cents properly.
The fastest part would be that, i mostly agree with GlynG has written about Ferals, save for this part.
Orkeousaurus are already powerful enough and an auto-take, so if any power up should be given to anything on the list, Orkeosaurus should be the last, with Gargs being second last.
The main issue the list has is internal balance making best option being taking the most 4+RA is reasonably possible. I am more of about rising the cost of Orkeousarus to +200p and lowering the Warbands to 175p as they are barely being taken and this is not Ghazghkull where there is the option of Landas, but that still doesn't fix the issue that Wyldboyz Warbands are just there to serve as the cheapest way to get an Orkeosaurus, Leader, and numbers for the outnumbering at assaults.
Sculpting Orks thread
PostPosted: Sat Mar 22, 2025 1:32 pm
I agree with both of those Abetillo - I'd be happy to see the Orkeos raised to 200 (they are too good and an auto take currently) and the Warband dropping to 175 (100% of the time I use Wildboyz for my foot troopers and I've never bothered with a regular Warband while running Ferals).
Those changes alone still don't change the biggest problem with the list which is drawing WAY more than other armies though.
I still argue Orkeo's need a minor speed boost as well. Surely it's more justified if it's combined with them going up slightly in cost? I'm not suggesting it so much aiming to make them better but for the army as a whole to have a bit more chance to move forward and win or lose rather than not be able to get close enough to objectives to win and so very often drawing. It gets disheartening to play with or against them then.
I don't want them to have the option to move as fast as Gargants can with Push them harder though - hence suggesting a smaller change of +5cm to a single move in a turn only max and with the risk of a critical.
Dave's idea of giving them walker free would be way too large a boost to their survivability and would just end up with the list drawing more than ever (some of what would have been losses for the Ferals ending up as draws due to Orkeos being in area terrain loads more and dying less).
PostPosted: Mon Mar 31, 2025 9:52 am
Take into account that if giving them any speed increase, being from Walker or from anything else, due to its impact and that it is removing a weakness, they should be going to 225-250p or they will be even more than an auto-take than now. Do you want them at that cost? It will also remove the only big advantage Squigoths have over them, making them being taken a lot less, and making units more redundant.
On the matter of the Warband to 175p, i only said it regarding the issue with the Wyldboy fm, because if the Warband were to be lowered in cost, that could unbalance things with half the other formations.
If wanting to fix the Orkeoosaurus, the option would be to put the Wyldboyz on 150-250-325p to stop them from being a Orkeosaurus prerequisite, and Orkeosaurus to +200p to stop it being an auto-take. But there is an issue, as the list is not the most powerful around by far, even though when we group victories by VC an by points they do not fare badly at all, so a buff somewhere else would be good, for that, to improve internal balance, and to encourage to take options that play less to a victory on points.
I was thinking about putting back the 'UGE cost on Junkatrukks (i read the entire Ork subforum during the COVID confinement and i still have yet to find why that happened and i struggle to see the issue in a 25p discount on something detrimental to activations like a 450p fm), reduce the 'UGE cost on Wyldboyz and Warbands, reduce the cost on Trappas or give them a BIG-'UGE cost, and maybe reduce the cost on Squigoths to +35p. Also maybe put the 'UGE cost on Gargs on +25p, so they aren't the auto-take for BTS they are. Oh, and i am not thinking about changing all of that at once, they are ideas to the pile.
Sincerely, i only care about their percentage in wins by points because its better to have variety in both wins and because of internal balance, and while i understand the concern from tournament players because most tournaments punish players that win on anything that isn't turn 3, i do not share it.
Now that i think about it, there is something funny about this topic that i am dropping as a curiosity: i have to find it again and save because its interesting, but i have read recently some words from Jervis ( i think here on the oldest threads) about his concerns about the objective he wanted to achieve in relation between the win by VC and by points ratio and turn3-4 games, and none of the current TP or UK lists achieve that, save maybe AMTL. I think it was related to the perceived (before Spirit Stones were added) turn 4 wilt on Eldar.
PostPosted: Mon Mar 31, 2025 11:28 am
Squiggoths at 35 feels too cheap to me - they seem about right currently IMO but are rarely taken more due to the Orkeosaurus overshadowing them.
I’m more unusual in that in my usual Ferals list I currently run a small 125 Wildboyz formation with 8 Squiggoths added so that it’s 525. It then becomes the BTS so the enemy has to deal with it and I also run 3 Steam Gargants with all 6 arms as close combat weapons and march it at the enemy, without minding as much if it dies since it’s not the BTS. Feel a more orky way to run them.
Edited to add: yes there is a minor advantage to winning turn 3 to turn 4 at a tournament but it’s pretty minor - 28 points vs 26 for a 2 victory condition won turns 3 or 4. The issue for Ferals is they’re a slow horde army (who canny opponents will force to let corners when they can to make them have to go further) and so they’re not able to win in the time constraints of a 2.5 or so allowed time at a tournament and so much more often Ferals games end in a draw. In a friendly game if you’re able to play longer than normal for a 3k EA game maybe this wouldn’t happen quite as much, though they’ll always draw more than normal.
I don’t think increasing the cost of Wildboyz formations is a good idea either. Currently they’re okayish for their price and the issue is specifically the Orkeosaurus so focus the fix on that. Currently I run 2 x Wildboyz formations upgraded with 3 x Squig Catapults in my Ferals list. They’re okay but not amazing, providing some direct fire overwatch barrage garrisons. Increase the cost for Wildboyz even slightly then an okay foot formation becomes poor and I’d drop them from the list on place of something else.
PostPosted: Sat Apr 05, 2025 7:10 pm
So ... what's your idea for removing the internal umbalance Ferals have. AS you have commented on only two i suppose you have your own ideas.
I knew of that formation (but did not remember who took it) and its cool, but it further proves my point: Wyldboyz normal fm is so cheap that is only used as a base for something, be the 8 Squigoths you say, Squig Catapults, or the Orkeosaurus, but never as Wyldboyz themselves.
About how they are played, usually i would say i have been here more than what my account says so i know all of that well, but i think it is the first time i hear about that the issue is more about games ending up in a real draw, and not a win by points called draw like usual. What i do not get is why or how that happens, as Feral typical forces do not have that many units or formations, and as corner deployment is used, while not much happens so formations stay around longer, that also means turn 1 and most of turn 2 is mostly moving which is fast to do, unlike assaults. Cold you explain? Or is it people that take longer on purpose?
PostPosted: Tue Aug 19, 2025 5:28 pm
Hello. Thought it would be better to put all the fixes that have been reported in the last weeks together with the rest of possible changes.
- On 6.18, the Tactical formation has option for more Tacticals. This is a copy-paste from Salamanders, as Scions' never had that option, since way before the TP.
- On 6.29, it is missing the following line under Special Rules, which other CSM lists have:
The Fickle Masters, Sacrifice and Summoned Units rules apply to the Red Corsairs army (see Fickle Masters, Sacrifice and Summoned Units, respectively).
- On the Red Corsairs only pdf for the Summoning Rule, it still lists the daemons as if it were for the other chaos lists, not the generic ones Red Corsairs' list uses.
Maybe there is one more, but i am not sure.
