Stands
 Post subject: Stands
PostPosted: Thu Sep 24, 2020 10:21 am
Hi! We have a WhatsApp group for spanish people and a recurring theme, especially when a noob enters, is that of the bases.
• A stand may be no more than 40mm and no less than 5mm
across in any direction.
• A stand must be at least 20mm across in one direction (i.e., a
5mm by 5mm stand is not allowed, but a 5mm by 20mm
stand would be okay).
• Stands representing infantry units must have at least three
infantry models and may not have more than seven. Infantry
mounted on bikes or horses must have between two and
four models mounted on each base.
• Stands representing artillery must have between one and two
artillery pieces and up to six crew models.
This is what the Tournament pack says. The usual question is how big they should be. According to that, would a 4x4cm base be legal? Or when you say "across in any direction" it also means measuring diagonally?
 Post subject: Re: Stands
PostPosted: Thu Sep 24, 2020 11:46 am
Anything between 5x20mm and 40x40mm is allowed. The diagonal measurement has been mentioned before, but that would make the standard 12x40mm "strip" bases illegal. I'm assuming they said "across" and not "edge" as it would infer that circles are illegal.
