looking for volunteers
 Post subject: looking for volunteers
PostPosted: Mon Sep 17, 2018 1:21 pm
I'd like to make sure that Armyforge matches the Tournament Pack lists. Is anyone willing to double check that the lists here: http://www.tp.net-armageddon.org/
Are correctly represented here:
https://traitor-legion.appspot.com/indexNETEA.html
Post and let me know, we'll divvy up the lists and give people a few days to check. Then I (or Kyuss if he's free) can make the changes to the JSON.
 Post subject: Re: looking for volunteers
PostPosted: Mon Sep 17, 2018 8:52 pm
I can check some.
PostPosted: Mon Sep 17, 2018 9:42 pm
I know that most of the marine lists do not have the latest changes applied - i did codex and white scars but not the rest.
I also know the tau list doesnt have the latest crisis suit change, I have made a change locally but think the TP needs to be updated first - see post in Tau section.
PostPosted: Mon Sep 17, 2018 11:43 pm
Tau should be good, we gave them thr AT on plasma and made them 2 for +75.
PostPosted: Mon Sep 17, 2018 11:58 pm
I can do one, just let me know which.
Tau AC: viewforum.php?
Net EA Chair
PostPosted: Tue Sep 18, 2018 1:24 am
Yeah but don't think it was intended to replace the 1 for 50 option. Best discussed in tau thread.
PostPosted: Tue Sep 18, 2018 11:47 am
This is what Borka sent:
2) change crisis upgrade to + 2 units for 75 pts. (currently + 1 unit for 50 pts).
Anyway, the lists are below. Tell us which ones you're checking and get back to me here of via PM.
Code:
Adeptus Mechanicus – Knight World
Adeptus Mechanicus – Titan Legion
Chaos Cultist – Stigmatus Covenant
Chaos Space Marine – Black Legion
Chaos Space Marine – Emperor's Children
Chaos Space Marine – Red Corsairs
Dark Eldar
Eldar – Alaitoc
Eldar – Biel-Tan
Eldar – Iyanden
Eldar – Saim-Hann
Imperial Guard – Baran Siegemasters
Imperial Guard – Death Korps of Krieg
Imperial Guard – Minervan Tank Legion
Imperial Guard – Steel Legion
Necron
Ork – Feral Orks
Ork – Speed Freeks
Ork – War Horde
Space Marine – Codex Astartes
Space Marine – Imperial Fists
Space Marine – Salamanders
Space Marine – Scions of Iron
Space Marine – Space Wolves
Space Marine – White Scars
Tau
Tyranid
I'll check 'nids, knights and all the Eldar.
PostPosted: Tue Sep 18, 2018 1:29 pm
PM me a list of all the changes required and I'll action them in the repository
PostPosted: Tue Sep 18, 2018 2:43 pm
AMTL:
Skitarii should be 250 points on Army Forge.
Everything else looks good.
-Vaaish
PostPosted: Tue Sep 18, 2018 2:59 pm
@Everyone please check everything against lists here: IO Site and NOT the main armyforge site, the main AF site is not always updated instantly, whereas the IO pages typically take ~30 min for changes to ripple through
I will suggest to Adam that the IO pages are linked on the main site, but I suspect there is some reason they are not
so if a value is incorrect on AF but correct on the IO site above, it will eventually ripple through and go live on the main site, please don't report it without checking the IO address above as it wastes my time checking a value that may have already been changed :)
PostPosted: Tue Sep 18, 2018 4:16 pm
I’ll start with the Guard lists. After that I’ll go through the marine lists if no one else has.
PostPosted: Wed Sep 19, 2018 8:04 am
The TP site shows dates that are older than the dates on the PDFs. I'm using the PDFs. The individual army list pages (not the PDFs) could really use a revision date on them.
I'm using the IO Armyforge site.
Baran Siegemasters:
The points values are all fine. Fortified Positions should let you exchange Gun Emplacements for Bunkers or say that you get a total of 6 of either/both types.
Death Korps of Krieg:
The Fire Support Battery Upgrade should be 4 units (currently 6). The points are right.
The Heavy Tank Upgrade should cost +125 points (currently +100).
The Hellhound Squadron Upgrade should cost +100 points (currently +125).
The Tank Squadron would be a lot more intuitive if the base upgrade gave you 3 Leman Russ Thunderers instead of "Leman Russ variants" (with +20 point upgrades to Leman Russ or Leman Russ Demolishers). The support Tank Platoon already works this way.
The Artillery Support Company should probably come with Gun Emplacements that can be upgraded in one go for 0 points to
Trojans.
The Deathstrike Silo should cost 250 points (currently 225).
The Grenadiers Platoon should cost 225 points (currently 200). Their Gorgon/Centaurs upgrade should be +75 points (currently +100).
The formation order in Armyforge isn't meant to match the order in the army list PDF, is it?
The Heavy Support Battery's Medusa option should cost +150 points (currently +125). Ideally the formation would come with 3 Gun Emplacements that could be upgraded in one go to Trojans for +25 points.
The Heavy Tank Platoon shouldn't have the option to add 1 Macharius and any number of Hydras. Or at least I don't see the option in the army list.
The Light Support Battery should cost 200 points (currently 150). Ideally the formation would come with 4 Centaurs that could be upgraded in one go to 20cm of Trenches for 0 points.
Armyforge has a "Marauder Bomber" formation. The army list PDF says that the "Heavy Marauder" formation consists of "One Marauder Heavy Bomber".
The single Warhound option shouldbe removed.
The Warlord Titan should cost 825 points (currently 850).
More tomorrow.
PostPosted: Fri Sep 21, 2018 4:07 am
Hi everyone,
Didn't see this post until now, but I updated the Tyranid files and submitted a pull request yesterday because I noticed the latest TP changes was missing... I can do more lists, just let me know.
Skickat från min Nexus 6P via Tapatalk
Army Champion - Scions of Iron & Iron Hands
PostPosted: Sat Sep 22, 2018 11:58 am
just getting to the party tooo, happy to go through any that havnt been crossed off.
PostPosted: Sat Sep 22, 2018 9:17 pm
Steel Legion is fine (using the 2018-04-20 PDF on the TP site). Two very minor quibbles:
The Storm Trooper's Valkyrie upgrade shows up in Armyforge as "Valkyrie Transport." I'd rather it said "4 Valkyries." Points are fine, though. Also applies to the Minervan list.
As a BFG player, I think it'd be more intuitive if the Orbital Support formation added "Cruiser" and "Battleship" to the two options in Armyforge. The specific class isn't really important, just the size of the ship. This applies to other IG lists too.
Minervans (2018-04-20 PDF) seem fine too.
As with the Death Korps of Krieg, I think it'd be nice if the Tank Squadron upgrade was listed in Armyforge as giving you Thunderers and the menu also showed the surcharges to turn them into other Leman Russ variants with + signs in front of the points costs. But everything works.
