Epic Armageddon House Rules:
 Post subject: Epic Armageddon House Rules:
PostPosted: Thu Jul 30, 2015 12:51 pm
Just thought I'd upload our current in use house rules to see what you guys think of them. Any similarities to what you might be using, criticism, praise? It would be interesting to hear.
-If the unit has blast markers less than 10% of unit’s current size no action roll minus
-When the action roll is fumbled, remaining options must be chosen from original orders option ea. no regrouping if no marshal was declared
-When unit embarks/disembarks -5cm to transports sub movement, ea. march with movement 30cm, embark move 25cm + 30cm + disembark movement 25cm = 80cm (not 90cm)
-Transported units gets the same hit with normal armour save if transport is destroyed
-Skimmer max skimming altitude is 20cm
-From those units that are on range to fire, first remove number of blast, then number of damage on war engines, then divide remaining between available weapon types at same ratio
Shooting weapons = 1- (blast + damage / units original hit points) from those that are on range
e.g. Of 6 units, with 2 blast, 3 on range => 2 can shoot
-War engines shoot weapons, assault and firefight relative to current damage capacity not original damage capacity
-Templates must cover canter dot to hit a unit
-Supporting unit in firefight gets 1 blast
-Broken units get armour saves normally when taking damage
-Unit retreats/is destroyed when 33% or less are left, does not count for ork units if 5 or more remain (still gets the Waagh bonus for size, experimental)
-Flyers out circling back every second turn of board
-Flyers fire at each other in order of ranges in CAP, same ranges fire simultaneously
-Army breaks (loses) when 33% or less remain that are not dead or broken
 Post subject: Re: Epic Armageddon House Rules:
PostPosted: Thu Jul 30, 2015 12:54 pm
I assume that ATSKNF units get 20% then?
So you're literally measuring to/from an altitude for the unit( s )?
Umm...that's already in the rules
PostPosted: Thu Jul 30, 2015 1:03 pm
Yes, you assume correctly, Marines would get the bonus as double. This is something we haven't yet properly play tested in practice tough. We came up with it recently after fresh large ork units kept getting action roll minuses when somebody threw a rock at them and missed, they still got that one blast for being shot at. Something that should be pretty much the default expectation for an ork and not tho bother them too much, marines even less.
PostPosted: Thu Jul 30, 2015 6:43 pm
Hmm interesting stuff. Let's roll.
Good luck with Assault Marines. :P The "one blast marker turns the table" effect is part of the Epic chess, why drop it?
Engage? Overwatch? And after that; many times a hold action overthrows your plan so the player must optimize to do something different than the original order. [lets say I want move and shoot, but fails... hmm then let's stay in cover and hit regroup for better opportunity next turn. With this house rule you drop out tactical options. If that was the aim, then its okay.]
Exactly this!!!!!!!!!!! Mega high five!!!!!!!
Transported units get the same hit with normal armour save if transport is destroyed. It's in the original rules.
Yup, skimmers may be annoying, especially pointy ear-gear ones... but why 20 cm? Why not 25 cm? 15 cm?
Apologize for my English is rusty nowadays. I don't understand what you want with this, and why the original rule not satisfying.
How many DC Baneblade has? How many weapons Baneblade has? [and insert each and every other WEs troubling with this house rule.]
And what is the problem with a War Engine being / acting like a War Engine?????? It's their fluff to be awesome and have big firepower even when damaged, cornered.
This. It's good for removing the problem of different bases and models, bringing glorius equality to them.
If it meant for losing assault, then it is already in the original rules. If meant as is then... you know. :P
Broken units do get armour saves normally when taking damage. It's in the original rules. You probably misunderstood dmg through blast markers. It's key part of the game, otherwise EVERY broken formation would act like fearless units as there would be no combat drawback for them!!!
Good luck with elite armies, especially Space Marines. Current "formation breaking and withdrawal" is fine to represent retreats and stuff.
If I understand this, flyers can make 60 cm line attacks, then make a vertical turn and don't need to take horizontal circles in the map?
Cool.
Anti heroic rule.
Epic Commander of the Prassium Invasion Troops 214th Regiment
***Action is our prayer. Victory is our offering.***
PostPosted: Thu Jul 30, 2015 9:04 pm
A lot of these seem to come from a misreading of the rules, are very impractical (% of WE weapon's firing), or don't make much sense.
PostPosted: Thu Jul 30, 2015 9:40 pm
I don't like them and don't see the point of using them really.
PostPosted: Thu Jul 30, 2015 10:16 pm
"-Skimmer max skimming altitude is 20cm" lol wut?
PostPosted: Thu Jul 30, 2015 10:23 pm
The new suppression rule would make Shadowswords nearly never fire their volcano cannons. One BM and it's silenced.
I've noticed a lot of these rules benefit large fm sizes and large DC WE, which both happen to be frequent in Ork armies. Is it a coincidence your username is an Ork name?
