Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3, 4  Next
Questions: The Demolisher Cannon
 Post subject: Questions: The Demolisher Cannon
PostPosted: Tue Dec 02, 2014 5:01 pm
Discussion about the Demolisher Cannon has been circling recently and a point has been made here that sheds light on its abilities, however, the change would effect several lists at once - Marines, Chaos, Imperial Guard.
Should or could the weapon receive MW 4+ and should it change in all lists?
 Post subject: Re: Questions: The Demolisher Cannon
PostPosted: Tue Dec 02, 2014 5:06 pm
I'm torn.... thematically it really should be a MW, but in the marine case, it would change the vindicator from a siege breaking tank (good at blasting infantry in heavy cover) to an AV killer...... I'm not sure that's a good thing
PostPosted: Tue Dec 02, 2014 5:13 pm
Perhaps an IC, Disrupt AP3+, AT5+ attack? Not quite the MW monster. I really wish that MW was an ability and not an attack type, that way you could apply it to various target types independently
PostPosted: Tue Dec 02, 2014 5:15 pm
True, but as Morsla mentions it does nasty things to AV as well.
You mean like the Rail Gun in the Tau lists....?
PostPosted: Tue Dec 02, 2014 5:19 pm
That might make the Baneblade more aggressive if we did try MW so solve two problems at once. Problem is you've got chaos with them as well and no offence, they're overloaded with MW already.
PostPosted: Tue Dec 02, 2014 5:48 pm
Agreed and the one thing that makes me question this idea. Chaos does not generally need the extra MW ability, whereas both Imperial units both seem able to make the argument for it
PostPosted: Tue Dec 02, 2014 6:17 pm
So, is this the point to equip the chaos vehicles with different weaponry, due perhaps to differing development / tactics etc since they turned to Chaos?
OR
is this another good reason for treating MW as a weapon ability as Jimmy suggested earlier?
PostPosted: Tue Dec 02, 2014 6:48 pm
Sorry, not allowed; The ERC have decided that is verboten.
PostPosted: Tue Dec 02, 2014 6:52 pm
Not really MikeT. We can rename the weapons to get around that by design.
PostPosted: Tue Dec 02, 2014 6:54 pm
you probably don't want to do this, but just putting it out there, siege rounds for stuff in bunkers could be 1BP IC.
Assuming it is essentially a sturmtiger, using high explosive rounds to nuke stuff that's in hard cover.
Think you need to strictly define what the demolisher's role in epic (or 40k) is , *then* stat it.
PostPosted: Tue Dec 02, 2014 7:01 pm
But they are literally the same weapon, made in the same factorys, to the exact same designs. Hell, if there should be any difference, then the vintage 30k era Traitor Vinidcators should be built with better technology and so would have a better claim to upgraded stats
Oh i agree, it's pushing it ;D
PostPosted: Tue Dec 02, 2014 9:49 pm
SM could use MW weaponry, but it would feel weird for it to come from Vindicators. Those may be weak right now, but they feel right when it comes to their role. Maybe give them disrupt? It's not as significant as it is to barrage weapons, and I'd imagine a shell like that would have an impact on morale.
PostPosted: Tue Dec 02, 2014 10:11 pm
I'd also like to start small and evaluate. IC + Disrupt is nothing to sneeze at, especially if we do 4-6 Vindi formations.
PostPosted: Tue Dec 02, 2014 10:26 pm
Agreed.
