Post new topic Reply to topic  [ 145 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
NetEA Tournament Pack
 Post subject: Re: NetEA Tournament Pack
PostPosted: Tue Jan 09, 2018 3:39 pm
Dave, it's been pointed out that the vindicator upgrade in the Imperial Fists list in the TP is missing the price break (ie. 1 for 50pts, 2 for 75pts) as this wasn't flagged after approval and was well tested during development I'm assuming this is a mistake? if so please can it be corrected at your earliest convenience?
PostPosted: Tue Jan 09, 2018 5:18 pm
Fixed that, the RC Silver Tower cost and the Rag type typo.
Squats 2018-05-15
PostPosted: Mon Mar 05, 2018 10:13 pm
Hey Dave,
I've noticed something in the Feral Ork army list: In the "Final version 2012 NetEA Approved army list" and again in the NetEA Army list Compedium 2014-01-14, formations of Wildboyz could take "Boyz (plus an optional free Grot per Boyz unit)" for 25 points as an upgrade. However in the latest NetEA Tournament Pack 2016-12-02 and in the Armyforge NetEA army compendium, the Boyz upgrade is missing from the Wildboyz formation entry. I've looked through Ork threads going back to 2014 and haven't found any discussion about deleting that upgrade option from the list. Am I correct in assuming that the upgrade was mistakenly left out? If so, it would be great if it could be added back into the army list. Thanks very much!
PostPosted: Tue Mar 06, 2018 1:13 am
Given that upgrade was never in the Swordwind PDFs and the Feral Ork list hasn't seen but a handfull of changes I'm going to say that it was likely a typo introduced by the compendium and whatever the "final version" you're referring to is. Best to toss the older versions and just print the TP lists.
Squats 2018-05-15
PostPosted: Mon Apr 16, 2018 1:52 pm
Does anyone know when this FAQ entry was removed from the Tournament Pack?
Q: Barrage templates – is it possible to place the first template over units to whom no LoF exists as long as there is a LoF to at least one unit under the template? Can I hit units I can’t see?
A: Yes. As noted, only a single unit under the template has to be in LoS and range. That means you can have units out of LoS and beyond the nominal range of the BP weapon under the template.
The Wargaming Trader
PostPosted: Mon Apr 16, 2018 1:54 pm
And why? It's in Neal's FAQ here: viewtopic.php?p=354848#p354848
PostPosted: Mon Apr 16, 2018 3:55 pm
When? Likely in the first FAQ review 4+ years back. It was because it's directly stated in 1.9.8:
Each weapon contributing to the barrage must be within range and have a line of fire to at least one unit under the template.
Squats 2018-05-15
PostPosted: Sat Nov 03, 2018 5:09 pm
Would it be possible for the next Tournament Pack to put the section 5 and 6 into one section and in alphabetical order. Its very difficult if you are seeking a specific Army and have to scroll back and forth between 2 sections.
PostPosted: Sat Nov 03, 2018 7:25 pm
That's what all the army lists are there for. You could print sections 1-4 out of the TP and then print the army lists out separately and put them in any order you want.
Squats 2018-05-15
PostPosted: Sun Nov 04, 2018 4:56 pm
Not very practical, especially if you don‘t want to print the lists.
PostPosted: Mon Nov 05, 2018 3:33 am
Your post confused me until I re-read your first post. "Scroll", so you're looking to use it on a device. Just merge the lists and section 1-4 however you like then. There's more than a couple of free PDF mergers out there (I use pdftk), and I'm sure there's a few that are web-based too.
Squats 2018-05-15
PostPosted: Thu Oct 17, 2019 1:53 pm
I just completed a two-weekish update to the TP system (new styles and javascript, and a reduction of tools to get it running). It's live now, along with the FAQ update, IW's and a few other small changes.
As always, let me know if you find an error.
Squats 2018-05-15
PostPosted: Thu Oct 17, 2019 3:24 pm
thanks for the effort Dave! much appreciated :)
PostPosted: Thu Oct 17, 2019 4:19 pm
Seconded!
PostPosted: Thu Oct 17, 2019 11:54 pm
Yes wonderful work! Many thanks!
