Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
The oddly specific grim dark cross platform weapons debate
 Post subject: The oddly specific grim dark cross platform weapons debate
PostPosted: Wed Sep 10, 2014 3:07 pm
AoC requested this thread for us to talk about weapons, specifically it seems the Avenger. So here we are. Discuss. :)
-Vaaish
 Post subject: Re: The oddly specific grim dark cross platform weapons deba
PostPosted: Wed Sep 10, 2014 8:00 pm
Intriguing title LoL :)
FWIW, my views are that in general A/c units should be costed between 75 and 150 each (giving formation costs between 150-300 for two, 250-400 for three). Also a general guide would be to add 25 points to the cost of the first 2 units to cover the 'activation advantage' (hence the TBolts cost of 175) and ideally the formation costs should aim at 200+ to minimise the potential for spam. They should only field 'moderate' weaponry so that the air formations do not have too great an impact on E:A as a whole. This is why ranges are much reduced from any ground-based equivalent, and often the stats are also reduced. Finally, the Eldar units should be the 'best' in the game so the stats of other air units should never exceed any individual stat, and usually be worse for several individual stats.
I realise these are very tight constraints which are necessary to counteract power creep that raises its head with almost every new unit / formation. Hence the need for this discussion with the Avenger.
That said the current Avenger stats don't seem too bad (though 150 a pair seems too cheap) as they fall roughly with the above guidelines, though I have not seen / heard of any play-tests.
PostPosted: Wed Sep 10, 2014 9:59 pm
They're costed at 225/pair, not 150/pair.
PostPosted: Wed Sep 10, 2014 11:17 pm
Correct, in the Skitarii list they are 225 for two, but in the old SoB list they were 150 for two.
I think AoC might be thinking about the stats for the Avenger Bolt Cannon more than the Avenger fighter though, since that's the only thing in the DA list I can see cross over.
-Vaaish
PostPosted: Thu Sep 11, 2014 12:14 am
So, does the Avenger fill the same role in the various lists?
PostPosted: Thu Sep 11, 2014 8:19 am
Indeed, I was speaking of the Avenger Mega Bolter aka Half of a Vulcan Mega Bolter, or so I'm told. Does that weapon exists in the AM and Sisters list or am I totally confused? lol
My NetEA Lists:
Fir Iolarion Titan Clan List
Dark Angels List
Always looking to Trade!
Angel's Trade Thread
PostPosted: Thu Sep 11, 2014 5:13 pm
It does exist, the weapon is named for the Avenger strike fighter. The FW version of it is almost exactly 1/2 the number of shots and range of the Vulcan megabolter. However, the Avenger megabolter on the Nephilim is bizarre in that it's very much underpowered despite being basically the same weapon.
To put into epic terms, The VMB is 4x AP3+/AT5+ 45cm and the Avenger Bolt Cannon is 2x AP3+/AT5+ 30cm.
-Vaaish
PostPosted: Thu Sep 11, 2014 5:54 pm
I would expect that as it is part of the AMTL list that was just approved that it would of had a number greater than 0 play-tests
PostPosted: Thu Sep 11, 2014 5:57 pm
It's not part of AMTL, it's part of the Skitarii list which is NOT approved yet.
-Vaaish
PostPosted: Thu Sep 11, 2014 7:34 pm
DOH! The unified nature of the document bit me in the butt! :D
PostPosted: Thu Sep 11, 2014 8:28 pm
If the 40k Nephilim mounts an underpowered version of the Avenger, then the epic one should too rather than match the AM one.
The SM Fire Raptor has twin avengers too (plus 4 x twin linked heavy bolters) and I plan on modeling and fielding some eventually.
PostPosted: Thu Sep 11, 2014 8:51 pm
True, but it's an odd nonsensical underpowered version. The Nephilim version is longer range, fewer shots, and worse AP. Fluff wise both cite the same source for the tech. Additionally, the SM Fire Raptor mounts the same cannon (with the same stats) as the avenger.
Nephilim Avenger Mega-bolter: 48" s6 ap4 heavy 5
Avenger Bolt Cannon: 36" s6 ap3 heavy 7
Vulcan Mega-bolter: 60" s6 ap3 heavy 15
In this case, I would recommend ignoring the DA codex Avenger megabolter stats and just use the stats that are used every other time the weapon shows up.
-Vaaish
PostPosted: Wed Sep 17, 2014 7:56 am
I concur Vaaish. I think there very little difference in the 40k stats to be noticeable in Epic. Are these correct?
30cm 2x AP3+/AT5+
My NetEA Lists:
Dark Angels List
PostPosted: Wed Sep 17, 2014 10:20 am
Is this the ground-based or airborne version of the weapon?
PostPosted: Wed Sep 17, 2014 3:11 pm
@AoC: Yet those are the correct stats. 1/2 the shots of the VMB and shorter range.
As far as I know the weapon only appears on aircraft.
-Vaaish
Users browsing this forum: Majestic-12 [Bot] and 41 guests
