Flame template rules question
 Post subject: Flame template rules question
PostPosted: Mon Aug 18, 2008 4:28 pm
So I was tinkering with a home-brew list, and I was wondering what rules I should use for a weapon that uses a flame template. I don't want to go against the grain, so is there a general consensus on the rules for flame templates?
I'll plan on using the rules from the tyranid list unless someone has a problem with those rules being generic for all army lists.
So everyone knows what I'm talking about, I lifted this text from the Tyranid list:
Flame Template: Some Tyranid weapons can spray gouts of bioplasma, pyro-acid, or other biological nastiness. Such weapons have a range of "Flame" and use the following rule to resolve their attacks.
Position the teardrop-shaped template so that its narrow end is touching the firing model and the entire template is within the firing arc of the weapon, placed to cover as many enemy units from the target formation as possible. Roll to hit all units (friend or foe) under the template with the appropriate to hit values for the weapon, removing casualties from those closest to the firing unit first. A unit is affected by the template(s) if any part of the model, or at least one model on a stand, falls under the template(s). Each formation hit by a flame template receives a Blast marker for coming under fire as normal.
War Engines (WE): If a WE lies directly under the centre-line of the template it is subjected to a number of attacks equal to half its starting damage capacity, rounding up; due to the war engine's large size, a flame template weapon that can meet this criteria is blocked by the WE and any units beyond are not affected by the attack. Other flame templates used in the same attack are not blocked by the WE, but cannot score additional hits on the WE. If a war engine is hit, but not under the centreline of any template, it only suffers one attack.
PostPosted: Mon Aug 18, 2008 4:46 pm
I'd rather skip the flame template altogether and replace it with short-range BP weapons.
PostPosted: Mon Aug 18, 2008 5:43 pm
The use of the "teardrop" template was extensively discussed in this SG forum thread. While it is possibly viable under particular circumstances, the template also causes some particular problems, and quite frankly, it is both simpler and less contentious to use the usual template(s) as Neal suggests.
PostPosted: Mon Aug 18, 2008 7:02 pm
I agree with Neal... short-ranged BP weapons can duplicate the effects of a "spray" well enough.
PostPosted: Mon Aug 18, 2008 7:52 pm
Just so everyone is on the same page, the weapons I had in mind to use the template were various types of Eldar vibro-cannons.
In 40k:Apocalypse, the Revenant sonic lance uses a large flame template. I have no problem going either way with it in E:A, I just wanted to see if there was some standard.
PostPosted: Mon Aug 18, 2008 8:04 pm
I'm with Neal on this one ; I've tested the teardrop template rules more than most, and have ultimately come to the conclusion that it simply can't be made to work in a way that is acceptable to the majority of the Epic-playing community.
PostPosted: Wed Aug 20, 2008 11:09 am
After reading the thread you refer to, it looks like it could be summarized as: "Multiple flame templates don't work and here's why." "Yes they do and here's why!" "Nuh-uh!" "Uh-huh!" By the way, regular barrages with multiple templates aren't really too fun to work out either, if you only have access to one template.
So, as long as you only put one of them in there, I don't think there's any problem with it. Hena's rules in said thread work just fine and I think it'd be a horrible shame to drop such a cool and tactically different (but ruleswise pretty similar and simple) mechanic because a few vocal people don't like it. Move warengine, point flamey template, kill stuff. Fun!  :laugh:
PostPosted: Wed Aug 20, 2008 10:42 pm
That sentence makes no sense.
It does make sense.
First you say that your only one that has tested it
No, I said I've tested it more than most (Which is true).
but then (You say that) everyone else won't accept (A more balanced mechanic than that used in the Tyranid army list)...?
Yes, and I stand by that comment; I don't think that the community is willing to accept any of the solutions that I believe will fix or mitigate the problems raised by the 'multiple template attacks originating from one formation' situation.
Notably, the Tyranid army list is still over JJ's stated word limit for Special Rules (IIRC), and I think that it should lose its template attack Special Rule in order to fit within JJ's 1500 word limit.
Btw you haven't posted a single batrep of those games,
And I won't be, as most of my tests occured 1-2 years ago, and no batreps were done at the time.
so at least I will take that comment with grain of salt thanks.
I assume that you're being aggressive here due to a translation error... otherwise this line simply calls me a liar.
PostPosted: Thu Aug 21, 2008 2:28 am
E&C, it's a 1200 word limit, not 1500... and it's being worked on...   :cool:
PostPosted: Thu Aug 21, 2008 3:45 am
Wow, people are getting kinda testy. Ok, so I think I'll go ahead and stick with using the BP rules. Thanks for the input everyone.
PostPosted: Thu Aug 21, 2008 9:28 am
I would be ok with shortrange BP weapon. Just to keep it simple.
Eradication of Earth's
Population loves Polaris
