Minefield as a classification
 Post subject: Minefield as a classification
PostPosted: Thu Apr 17, 2008 10:37 am
The tau robotic sentries, and now the 'Nid meotic spores suggest that we might possibly need another troop classification of "minefield". This would be used to describe objects that are effectively inert as far as the game goes, except that they exert a Zone of Control, and need to be "assaulted" by enemy formations in order to clear them.
So Minefield has the following properties:-
- It has an inherent movement of 0cm
- It cannot be activated
- It cannot attack (because it cannot be activated)
- It has a Zone of Control, and so prevents enemy movement
- It can be assaulted, so has CC and FF values and other weapon capabilities
- It can be used in an AA mode (because ground AA is reactive as part of the enemy air movement), so can have AA and range.
- It can garrison
- It cannot contest objectives
- It can be "dropped off" from another formation, but may not be picked up again
Potentially a unit with "Minefield" can also have other capabilities:-
- Jump pack to permit a 15cm deployment from its transport
- Teleport for in game deployment from off-table
PostPosted: Thu Apr 17, 2008 12:06 pm
I would go for a different name, since we already have mine fields as terrain with the siege regiments
disruption or spoiler troops perhaps
Tyranid air marshal
PostPosted: Thu Apr 17, 2008 1:12 pm
Could these points be covered in the unit notes a bit like the dreaded Drop pod? For example, if you give the unit "planetfall", just specify that it occurs during the "teleport" phase at the start of a turn and does not need a spaceship to do this. As for movement by the Synapse creatures, while I am not comfortable with this (additional complexity), you could specify that in the Rally phase, units within X cms of a synapse creature may be moved Y cms - but need to maintain formation coherency etc.
As for the name, perhaps "Reactive" or "Dormant"  would be a better description of the unit's nature together with its lack of activations etc.
PostPosted: Thu Apr 17, 2008 2:42 pm
(ragnarok @ Apr. 17 2008,12:06)
Area denial?
PostPosted: Thu Apr 17, 2008 3:26 pm
"Area Denial" would work, though I was trying to find a name that described the action (or in this case reaction) of the unit rather than its activity or effect.
I did consider Inactive, Inert etc but felt they were a bit too passive (someone stepping on a mine could find it very "ert" indeed :p ); Responsive didn't ring true and Minefield seems to have been reserved (though I do not recollect seeing this in the rules) and anyway, on reflection it is a noun rather than an adjective
PostPosted: Thu Apr 17, 2008 3:38 pm
Maybe "reactive defender"? If it were purely mechanical, "automated defender" might work.
PostPosted: Thu Apr 17, 2008 4:30 pm
Most of what you describe would normally fall under the term of 'static' or 'fixed' defences.
Everything else seems very reasonable.
"I aim to misbehave" - Mal (Serenity)
PostPosted: Thu Apr 17, 2008 5:31 pm
(Fomas @ Apr. 17 2008,16:30)
Hmm "Static" seems to do the trick - it is short, descriptive of the unit rather than its activities.
Thanks Fomas :blues:
PostPosted: Thu Apr 17, 2008 5:57 pm
Ok, CS, Neal, Chroma
Could we consider the new term "STATIC", used to describe battlefield objects that have some capabilities similar to minefields or other area-denial weapons.
These can be deposited on the battlefield, but are essentially passive in nature, so cannot activate, contest objectives etc, but act like a unit in all other ways. These are *Smart* munitions, so they do not attack or hinder friendly units, but they do have ZoC, so inhibit enemy movement, can be shot or assaulted etc.
Also, how should we play the *Intermingled* rule with these units? If people get upset at clipping assults on normal formations, I can already hear the outcry about being caught intermingled with a formation of these ?"STATIC" units.
Is it reasonable to say that they can be declared "intermingled" with another formation that is the target of an assault, but not visa-versa (so other formations cannot be declared intermingled with a "STATIC" formation that is the target of an assault)?
PostPosted: Thu Apr 17, 2008 6:24 pm
make it simply a terrain feature which can be added for a price.
PostPosted: Thu Apr 17, 2008 7:08 pm
(Soren @ Apr. 17 2008,18:24)
I understand what you are intending, but this is specifically intended to cover 'Nid Spores, Tau Robot Sentries etc, which are not really pieces of terrain :)
The fact that it can equally be applied to actual minefields is intended, because in practice the game mechanics work in the same way; the enemy does not want to enter the field, but if he does, he can clear it (by "assaulting" the mines).
PostPosted: Thu Apr 17, 2008 7:12 pm
(Hena @ Apr. 17 2008,19:03)
(Ginger @ Apr. 17 2008,19:57)
I came up with Non-Sentient. That is better as the need can be to allow moving (which static is not).
I am not quite certain where you are going here. How can the unit be moved if it has no activations? the intention as I see it is to provide a term to cover inanimate objects that do not move - if you need to allow it movement, then it is a normal unit isn't it?
