Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
E:A Power creep in air units and formations
 Post subject: Re: E:A Power creep in air units and formations
PostPosted: Wed Oct 08, 2014 10:54 pm
We all want to reflect the relevant weaponry in an acceptable way, but in order to stop power-creep ruining the game, we have to call a halt somewhere - and AP4+ / AT4+ is it (together with the other parameters discussed above).
I disagree with this statement. Had epic shipped without any ground units mounting weapons with a 2+ to hit we'd be having the same conversation about that if we needed to add a weapon that logically should have a 2+ to hit. If the ground game can be balanced with 2+ to hit weapons then there's no gameplay mechanic reason that the same cannot be true for air units.
Don't blame correctly statted weapons for OP units. If the weapon is correct and the formation is OP, then we look at other options either using alternative load outs, different formation sizes, price increases, etc.
I'm perfectly fine with having an Avenger that has crap AA if it means it's good at strafing ground targets. In the case of the Nephilim, I hate to say it, but the ABC isn't the primary load out. It's an option that can be swapped out and perhaps the solution there is to just not include the ABC version or price it appropriately to upgrade the unit.
-Vaaish
PostPosted: Wed Oct 08, 2014 11:09 pm
Now you're cooking with gas! ;D
PostPosted: Wed Oct 08, 2014 11:15 pm
Well since it looks like Vaaish is getting steam rolled here and people keeping throwing the Nephilim (something I didn't want to add because of this kind of topic) around like its deadly poison. I'll stand up and agree with Vaaish, lol.
I find this whole topic a little pointless now because how many days has it been here and no official comment from our governing NetEA ERC, which I believe to be a core reason to Ginger's topic in the first place. That's not saying there isn't room for revamp but that I doubt there will be any official movement about it.
I would be in favor of revamp old Epic flyers to match FW/GW/40k stats and re-working the entire Air game. But I doubt that is a popular idea ;D Because it bugs me when someone quotes "Well the T-Bolts have different stats...blah blah" That is because Epic plane stats existed before FW/40k etc current ones. I bet like Vaaish said, if Epic rolled out of the gate with accurate stats with planes that match FW/40k we wouldn't be having this conversation.
Ginger wrote:
While I agree that your stats for the Avenger are close to acceptable, the Nephilim design 'borrowed' the AMB weapon and put it in a different context that was well OTT. If we accept the AMB stats as they are now, some other design will come along and quote this as an 'accepted precedence' and the whole miserable process will repeat.
Why? What makes it okay for the AM but not DA? I may have missed something and I'm open to hear it. The reason to matches these stats is, to the best of my knowledge and info, they are the same weapon. I do not have 40k/FW books anymore so I'm relaying on people like Ortron and Vaaish to feed accurate data.
My NetEA Lists:
Fir Iolarion Titan Clan List
Dark Angels List
Always looking to Trade!
Angel's Trade Thread
PostPosted: Wed Oct 08, 2014 11:58 pm
Bruno
I am not against a limited use of 45cm ground attack weaponry - it is the 45cm AA that is problematic IMO (especially where that is AA4+.) Your views on the Helltalon are news to me and very interesting. However, it is the Hellblade that has the Autocannon. Dropping the AA4+ shot completely from the twin Lascannon on the Helltalon would remove all AA capability from the Helltalon, which is probably unacceptable.
I would far rather use split stats which allows greater flexibility when modelling the weaponry, and stats possibly looking like this:-
Hell Talon
Fighter-Bomber 5+ n/a n/a
Bombs 15cm 2BP, FxF
Havoc Launcher 45cm AP5+/AT6+, FxF
Twin Lascannon 45cm AT4+, FxF
. . . OR . . . . . . 30cm AA5+, FF
I would also recommend the use 'split' stats for the 'Long-barrelled' Autocannon on the Lightning like this:-
Lightning Fighter
Fighter 6+ n/a n/a
Wingtip Lascannons 30cm AT5+/AA5+, FxF
Long-barrel Autocannon 45cm AP5+ / AT6+, FxF
. . . . . OR . . . . . . . . . . 30cm AA5+, FxF
And I would even suggest more imaginative use of arcs of fire to represent agility eg
    Wingtip Lascannons 30cm AT5+ / AA5+, FxF
    . . . . . .OR . . . . . . . 15cm AA6+, RF
    . . . . . .OR . . . . . . . 15cm AA6+, LF
This retains the firepower in the front arc, but also simulates the aircraft turning left or right and getting a fleeting AA shot on enemy attacking them. However, I also realize this approach bulks out the list in a way that may not be acceptable
PostPosted: Thu Oct 09, 2014 12:27 am
I certainly agree that ERC should be driving this, so I share your frustrations and your concerns whether there will be an 'official' revamp.
I also share your pain about the Nephilim, especially since you apparently did not want it in the first place. It seems that virtually every list designer gets to go through the same pain over aircraft (eg the Tau AX-1-0 tiger shark). Unfortunately, since there are no 'principles' or 'guidelines' written down, it is up to nuisances like me :-[ to point out the issues and desiderata.
Note I am a 'fluffy-phobe', so do not know the 40 details. However, from the comments in this forum, the AMB seems to be a titan weapon that has been modified to be carried by aircraft. As such it is still a large and heavy weapon designed to attack ground targets, so it belongs on a Fighter-Bomber at best and quite possibly ought to be restricted to bombers only. Fighters need to be armed primarily with AA weaponry (which may have a ground component) rather than weapons that are primarily designed for attacking ground targets. This, coupled with the manoeuverability, power and range, and the formation size all combine to make it OTT (as others have commented elsewhere).
Finally, revamping the entire aircraft stats to reflect the current 40K stats would be a 'labour of love' that would need to review all the aircraft and ground AA units and weaponry, and potentially many other ground weapon stats as well - potentially re-writing a core part of the game. This is not really practical :tut :D
PostPosted: Thu Oct 09, 2014 1:13 am
Note I am a 'fluffy-phobe', so do not know the 40 details. However, from the comments in this forum, the AMB seems to be a titan weapon that has been modified to be carried by aircraft. As such it is still a large and heavy weapon designed to attack ground targets, so it belongs on a Fighter-Bomber at best and quite possibly ought to be restricted to bombers only. Fighters need to be armed primarily with AA weaponry (which may have a ground component) rather than weapons that are primarily designed for attacking ground targets. This, coupled with the maneuverability, power and range, and the formation size all combine to make it OTT (as others have commented elsewhere).
Indeed, I had a hunch adding this new OTT 40k unit wasn't going to be simple and addition to the fluff I felt unneeded.
Is there justification to make the Nephilim a Fighter Bomber? I do not know as I have no laid my eyes on the 40k Data entry. I understand your points but with that and keeping matching stats, which I feel is a worse slippery slope were falling down already in lists and even to units, ie different SHT or Marauder Bombers.
"Labour of Love" indeed but well worth it ;) ;D
My NetEA Lists:
Dark Angels List
PostPosted: Thu Oct 09, 2014 1:27 am
Might even of been quicker in retrospect! ;D
PostPosted: Thu Oct 09, 2014 6:02 am
It's my lot in life. Strong opinions and thick skin do that to ya. :)
Nothing except that it seems currently to be severely OP in the DA though not necessarily because of the AMB stats. I'm not really up on the state of the DA list myself though.
Technically, the ABC and the AMB on the Nephilim aren't the same weapon. They source the same fluff but have slightly different names and the AMB is inexplicably weaker with different ranges than the ABC. Most probably they were supposed to be the same weapon but instead of making the AMB a paid upgrade for the Nephilim, GW changed the FW stats. I say that since it doesn't really make sense otherwise to have two weapons that are described the same but giving them different stats.
This is true. For all intents and purposes its a Vulcan Mega-bolter that's been chopped in half and mounted on an airframe. However, it's pretty clear that the airframes it goes on are fighter sized since the Avenger is about the size of the Lightning. That means Fighter-Bomber is appropriate though larger craft (at least I think it's larger hard to tell) like the Fire Raptor might need bomber classification since they mount the somewhat awkward Twin Linked Avenger Bolt Cannon (really FW, wouldn't that just be a regular VMB?)
-Vaaish
PostPosted: Thu Oct 09, 2014 7:27 am
As the 'human' member of the ERC I have zero interest in rebooting all the aircraft to match their ever changing 40k stats, as long as a unit works in game and is at least representative of the fluff then fine.
Regarding this debate as a whole I don't see what edict from on high you want, the debate here is civil with pertinent points on both sides. There is no proposal with widespread support to look at. The thread is serving it's purpose by having discussion about and highlighting ideas and issues about aircraft stat design and creep. Furthermore the list design process is working,at least in this area, with testers flagging up concerning stats to their ACs
www.epic-uk.co.uk
PostPosted: Thu Oct 09, 2014 7:51 am
Indeed, and it looks as if we are building towards a consensus that the avenger can keep the AMB, as a fighter bomber, and the nephilim can swap for the lascannon for an AA craft, with limited stats to keep it from being mega powerful.
PostPosted: Thu Oct 09, 2014 8:16 am
Vaaish wrote:
You and Ginger say the Avenger is OTT, but I challenge you to prove it. Play with it, see how it performs and then come back here and show that my playtests are an anomaly.
The unit being disproportionately powerful relative to how it should be compared to existing aircraft (which are often toned down, sometimes significantly) is a problem, though you seem not to want to recognise it as such. Don't be so pedantic about the 40k rules similarity between the Vulcan Mega Bolter and the Avenger Cannon, the existing epic norms and balance are much more important and it should be toned down in translation.
Playtesting isn't the be all and end all - getting the unit stats right in the first place is very important. A list designer could invent a Warhound variant with weapons overall as powerful as the main weapons on an Imperator and cost, playtest and balance it from there. Such a unit could be balanced to perfection while still being wildly inappropriate.
PostPosted: Thu Oct 09, 2014 9:34 am
Didn't I recently read a batrep that was utterly dominated by ground attacking Nephilim?
- Ulrik
PostPosted: Thu Oct 09, 2014 9:42 am
Yeah I wrote one of them....
Also guys if Glyn is telling you to calm down about matching 40k stats accurately that is a pretty good barometer that you're maybe being a teensy bit anal about it.... ;)
PostPosted: Thu Oct 09, 2014 4:47 pm
Saying it's a problem enough times doesn't make the argument any more valid. Show how it is and I'll recognize it as a problem. Right now there's been a distinct lack of showing despite the Avenger basically trading Tbolt AA for AG capability. Obviously the situation is a bit more fluid since the Avenger gets the most dice when going against AT or mixed formations. (3.3 hits if split AP/AT, 2.64 against AP, and 1.98 against AT. compare to the Thunderbolt: 2.66 hits if split AP/AT, 1.66 vs AP, 1.32 vs AT. Both aircraft squadrons throw 4-6 dice)
Since we're going in circles with all this, I'll just say it straight up. The Avenger Bolt Cannon stats aren't changing, they are appropriate for the weapon they represent evidenced by epic standards (shells the size of a VMB should have AP3+/AT5+ defined by core rulebook titans), fluff defininitions (the weapon is one half of a VMB), and 40k stats further bear evidence that this is correct though they aren't used to directly stat the weapon. If that makes the Avenger too good, we'll further reduce it's AA capability (currently 1/2 of the Thunderbolt), but as of right now there is ZERO indication of any verifiable issues with the unit especially since it pays a 50 point premium for effectively dropping an AA hit for an AG hit.
-Vaaish
PostPosted: Thu Oct 09, 2014 6:27 pm
I'm sorry but that is a ludicrous stance
www.epic-uk.co.uk
