Post new topic Reply to topic  [ 127 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
Consolidating Blood Rage and Red Thirst
 Post subject: Re: Consolidating Blood Rage and Red Thirst
PostPosted: Fri Oct 29, 2010 12:47 pm
frogbear wrote:
Evil and Chaos wrote:
You've removed the stipulation that the rule does not apply to transport aircraft. Why?
Because I was concentrating on the first line and forgot the other stipulation. Not really something to make an Inquisition about.
No need to be so defensive. I'm trying to help you write a good rule, not attacking you personally.
You've removed the stipulation of reaching base contact "in a charge move", potentially introducing ambiguity for rules lawyers.
The formation that is given it should naturally be a CC unit. If not, then I would ask why not. Why force a player to move into BtB?
You've misunderstood me.
The rule says nothing about being forced to move into CC.
It still just says you have to Engage if you're within CC range.
The intent of saying "potentially reach base to base after a charge move" is just for clarity, not to force players to move their units into CC.
PostPosted: Fri Oct 29, 2010 1:06 pm
Well it came across strongly by starting the sentence with "You..". That's all. :P Not an issue.
PostPosted: Fri Oct 29, 2010 1:13 pm
Oh. OK. My question: is it necessary? Is it to do with Infiltrators? Just attempting to understand what a rules lawyer can do with the rule.
PostPosted: Fri Oct 29, 2010 1:15 pm
My concern is not just rules lawyers, but also with providing clarity for newbies. For the sake of a couple of words, I think it'd make things clearer for them.
PostPosted: Fri Oct 29, 2010 1:19 pm
The rule then needs to probably be broken up into 2 sentences. Hmm
PostPosted: Fri Oct 29, 2010 1:25 pm
3 sentences. You still need the stipulation that each rule doesn't apply to aircraft.
PostPosted: Fri Oct 29, 2010 1:37 pm
Well at leastthe rule with the +1 for Engages can't apply for aircrafts as aircrafts can't carry out an Engage action (unless landed in a previous turn).
PostPosted: Fri Oct 29, 2010 1:38 pm
Again, you need to specify these things for the benefit of newbies.
That's why the notes section of unit datafaxes will often clarify how to use stats that are quite clear to an experienced player (For example, the Land Speeder).
PostPosted: Fri Oct 29, 2010 2:21 pm
Rug wrote:
Is the THawk situation ok? Still not sure what happen with a THawk ground attack as it can always b2b assault!
Hmm. I never had to deal with that one for the WoE so not sure. I would think that it would not apply, hence part of the stipulation of the third line I seem to keep forgetting about :)
Are BA that frenzied/ your face?
Meh. Depends on GW I guess. I think the latest flavour would indicate "yes".
What are we going to do for Flesh Tearers?
Ignore them and hope they go away? Seriously. Why a Codex Chapter has such a stupid name is beyond me. I digress...
Interesting note: Lexixcanum has the Red Thirst as Black Rage. Not a bad name for the over-reaching skill as well. Not as good as Blood Rage however.
PostPosted: Fri Oct 29, 2010 2:28 pm
40k is basically made of stupid things.
"World Eaters' indeed.
PostPosted: Fri Oct 29, 2010 2:33 pm
Yes. At least they are the bad guys now. :) There is no excuse for the Flesh Tearers...
PostPosted: Fri Oct 29, 2010 2:41 pm
I've been thinking about how to screw with this rule and the more I think about it, the more opportunities present themselves. The rule doesn't say you have to Engage the formation that triggers the penalty/bonus. That means there are a lot of alternative actions to take beyond what is implied and that seriously reduces the vulnerability to the baiting tactics discussed so far.
1) You could take the bonus/avoid the penalty for a close, triggering formation by moving off to FF a different formation farther away.
2) You could pick a target so far away there's no chance of being in range, and use the bonus to move however you like. That gives an option to the player to take the reduced-effect action to avoid the penalty/take the bonus or to attempt to activate normally. That will allow you to do things like grab/block objectives any time a single move is sufficient. That tactical choice partially offsets the penalty side while remaining a definite positive for the bonus side.
3) For a small group of formations with particular traits, the penalty is effectively non-existent and the bonus can almost always be claimed (as long as it's triggered, obviously) - assault formations with Infiltrate. Whether it wants to Engage a target directly or double/support (Engage with 2x move to a support position), it can claim the bonus/avoid the penalty. Only if it really needed to March would the rules cause a negative effect.
My point is that when testing, we need to make sure that everyone involved is aware of the manipulations allowed. Not only does it need to be checked for balance, but whether doing stuff like the above feels gamey (whether it's outside the intended feel).
This is especially true for a list like WoE where a substantial portion of the formations have Infiltrate and little or no firepower (Juggers, Slautherfiends, Blood slaughterers) so #3 above is applicable.
Naming: I'd use something with a positive connotation for the +1 and a negative connotation for the -1. So, "Bloodthirsty" would be better for the negative, for example.
PostPosted: Fri Oct 29, 2010 2:44 pm
Well all Blood Angels have the Red Thirst but only the Death Company suffers from the Black Rage.
PostPosted: Fri Oct 29, 2010 3:00 pm
Just some quick ones:
I will repeat what I stated earlier: The formation that is given it should naturally be a CC unit. If not, then I would ask why not. Do not give the rule to FF units or formations that benefit greatly from FF and there should be no issue.
Yes, where a single move is sufficient - and how often is this the case? Not often in my experience.
As above, for a single move. Yes, I know that you are going to state Infiltrators, so please see below.
Ok. Now the formations mentioned (you forgot Defilers, Greater Brass Scorpions, and Flesh Hounds) do have Infiltrate and can take advantage of that rule. However I put it back to you in how often do you really expect such units to be used?
- I use the Slaughterfiends quite a lot as I like the idea of them, yet they also have a severe penalty when attempting to mount them to take advantage of that rule.
- Juggers and G.Brass Scorpions I do not expect to see much of.
- Defilers - Maybe, however you take them to a detriment of less Khorne Engines
- Flesh Hounds - when did you last see them used?
So it may appear that a "portion of the formations have Infiltrate and little or no firepower" (although I think you sell Defiler Engines short when the have a 75cm shot), yet keep it all in perspective. They are a large portion in the quick reference guide, but far less visible in a competative force. Have you attempted to make up a force or two to bring such a concern to light?
That is a big part of the problem. We have examples, yet are they realistic?
PostPosted: Fri Oct 29, 2010 5:03 pm
There are so many assumptions wired into this statement that I don't know where to start.
What if the triggering formation is a CC specialist as well?
What if the triggering formation is so large or has so much support that the superior CC doesn't matter?
What if the alternate target is a weak FF formation?
What if there is a lot more support fire on the alternate target?
"Gee, I can assault this Orkeosaurus in CC... or I can go over there and FF against a formation of Boyz..."
I'd say this is a matter of planning your overall attack strategy.
No, I didn't forget them. Defilers and Brass Scorpions have considerable firepower, so it's a lot larger drawback for them. Flesh hounds don't form separate formations.
Yeah. That's why I flagged these as "we need to be sure this is tested" and not 'ZOMG, FROGBEERZ LSIT IS BROAKEN!!!!!'
As far your defense of the units, if the units aren't being taken in play, then that's a problem with the internal balance of list. It doesn't have anything to do with determining whether the rule creates the desired effect in game.
Users browsing this forum: No registered users and 62 guests
