Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
NetERC website - input requested!
 Post subject: Re: NetERC website - input requested!
PostPosted: Fri Jul 29, 2011 1:44 am
elsmore wrote:
Just to let you all know I am working on this, albiet very slowly. New business + house decoration, move = very little free time. I created a first design draft but decided it looked a little dull so I scrapped it and started again. I'll post a preview when I'm happy with the design.
any one else notice that seems to happen when ever they try and start a big project and announce it publicly? Happened to me twice now.
Have you seen the miniarmageddon webpage elsmore? I like it a lot.
PostPosted: Wed Aug 03, 2011 2:15 am
https://sites.google.com/site/epicarmag ... minigeddon
PostPosted: Sat Aug 27, 2011 12:04 pm
Rug wrote:
1) Am I the only person who thinks one big army list doc on the main site is a bad idea?
Just have both options, 1 mega doc and a set of separate race specific lists. Personally i want a mega doc, i would in no feel obliged to print the entire thing just because it is one document etc etc, but if other people want individual documents I can't see why having both available is a problem to either side.
c) Only one person will be able to be responsible for fixing everyone else’s mistakes and making all their little changes or the document will fall apart!
Nah, plenty of people on here are able to edit pdfs for small corrections.
PostPosted: Sat Aug 27, 2011 1:13 pm
I have started work on something that might prove to make things much simpler. It is in a very early stage of development, so I'm not very comfortable with going public with it yet, but the discussions in this thread are making me think that it could be very useful, and it is probably of interest to many of us, and more than any others, to ACs and ERCs.
I was setting out to make an experimental list. Well, I don't know if you're like this, but I found it very painful, lots of layout issue and I'm not an expert with any stuff like Acrobat or Word or whatever.
However, I am an expert in web development (or at least a scattering of techniques useful on the web), and I am the kind of lazy guy who would rather develop a software from the ground than fight with the layout options of MSword.
So the idea is to make a web based application, that could store complete lists for EA, from units and weapon statlines to lists with all their options, point costs, etc.
then, from there, the goal is to be able, dependent on a system of permission per user and per user groups, to :
- export data in a format that would be understandable by the application itself, and human-readable enough that someone web-competent could develop his own stuff based on the data.
- import data in the same format.
- display, on a web type interface (i.e. : web pages) :
* unit listings in a way akin to what the current lists are doing, with full stats, background/lore/fluff text and possibly image galleries
* lists with core, support, allied choices and upgrade, i.e.: Lists as usable as those published
* quick reference sheets
- generate and export the same "view" (unit datasheets, army lists, quick reference sheets) in a paper friendly way (web based probably at first, PDF as a probable future feature)
- Allow people with sufficient permission (i.e.:ACs ) to modify and add data to official lists, so that updated lists are available instantly
- Allow people with sufficient permission (i.e. : hand-registered taccommers) to create their own lists, as variants, house lists, experimental stuff, etc.
There are LOTS of stuff that could be plugged on such a structure, from army-builder style sub-applications to statistic extraction from lists to whatever.
Now, where am I with all that ? Well, the basic data structure is defined (like, I have my MySQL structure ready), and that's all for now. This structure can do everything I found in marine, guards, eldar, ork lists, from alternate weapon loadouts (marine dreadnought) to weapon with alternate statline themselves (earthshaker cannon), it can manage unit upgrades or free upgrades (+1DC as an upgrade), core/support/restricted allies discriminations and that kind of things, detailed structural transport options, etc.
The system can cope from the start with some stuff that are not used anywhere but could be interesting (for example, making you buy "detachment packages", for example paying n points and getting a marine company, that is 4 detachments : 2 tacs, one Assault and one dev).
I think I still have to do some slight modifications to allow things like weapons as an upgrade in a structured way (that should be almost instantaneous however), and of course re-read to all lists to make sure that I can manage all that is currently existing.
This is an important but small part in term of the total amount of work involved.
From there I have to (in a rough order) :
- define the structured data format I want to use in the application (only just started, relatively straightforward, JSON will be the obvious choice for me)
- develop SQL procedures and various middleware to :
* produce the aforementioned data structures from the database
* be able to insert/update the correct stuff in the DB, taking the aforementioned structure.
Nota : this stage is likely to be the most technical and the most time consuming; this also imply that if I get this done, motivation and time won't be nearly as hard to get to do the rest. import/export functionality are almost free at this stage, since the structured JSON will be the export format.
- develop the SQL structures and associated code to implement the user & permission system (relatively straightforward, but tedious and meticulous task if we don't want this to have gaping security breach; luckily, a good friend of mine is a security expert: that might help); after this stage, the stuff can basically go public (it still wont be usable for most interesting applications)
- develop a basic display interface. Basic means ugly.
- develop a basic input interface. Basic still means ugly.
- refine such display to make it nice to look at, and alternate layout for printing and use on paper. (fun stuff for me)
- expand from there (link to galleries, quick references extractions, celebrating with champagne, etc).
Keep in mind that this is all a LOT of work; also keep in mind that while motivation is strong at this point, I have a consuming RL job (I'm an IT engineer if you didn't guess), a wife, a son, like to do long roller-skating sessions, have started rock climbing recently, have armies to paint, and am an avid reader. So, stuff might move very fast or stall, and I would be a liar if I made any promises, or even give you an ETA on all this.
What I can commit to do is keep you all informed on my progress, and answer any questions you might have on all this. I'll start a thread about this as soon as I have the time and a name for the project. I'm open to suggestions of course.
Oh, and by the way, if you don't realise all the usefulness of such an applications, it implies things like instant army compendium compilation, indeed a living army rulebook with no compilation work involved, clearly labelled status of lists (be they netEA official, FERC official, EUK official, experimental, fanlists... indeed as many status as one might want).
Right now I HAVE to go take a plunge into the Mediterranean sea with my family, so I probably won't answer any questions instantly :P, but I'll be back soon.
PostPosted: Sat Aug 27, 2011 2:13 pm
You know, Athmos, I was thinking of mowing my lawn today. But your idea's good too.
Seriously, that sounds like an application that would be a huge boon to the community, and I heartily approve of such an endeavor. Unfortunately I don't have any of the neccessary skills to help in any way whatsoever, so I'll just leave you to it...
PostPosted: Sun Aug 28, 2011 7:17 am
you know, we need a final year IT degree - this would make an excellent disseration project.
PostPosted: Sun Aug 28, 2011 11:12 am
I sympathize completely, with the sentiments and the solution.
I've lost count of how many web apps I've built (I'm an application architect by profession and avocation), so do send me a PM if you want help (I do work in Java, PHP, MySQL, PostgreSQL, HTML, CSS, Tomcat, Linux etc etc etc), or just reviews & suggestions.
PostPosted: Tue Aug 30, 2011 2:09 pm
Thanks for the offer, but at the moment I'm still mostly sorting what needs to be done, and Elsmore gave me quite a bit of additional work by innocently suggesting that it "might be interesting" to make the webapp flexible and generic enough to be able to use it for other game systems :)
The most needed help ATM is to help me find a damn name for the thing. I suggested one, but it's not a very good one, I didn't search too hard, actually I think I'd like the Taccom community to produce one :)
Anyway, I have started a thread dedicated to it in the "Epic Armageddon" section, since it's not a "rule amendment". You may find it here : For want of a better name, here comes Irene.
Further info, discussion and all will go there.
PostPosted: Thu Sep 15, 2011 5:49 am
About the website creation, when I created epic40k.fr, the choices were:
- free: (free webhost that works quite well), free CMS (I pick wordpress but I considered Joomla and others CMS)
- easy to handle: something like wordpress is really easy to put in hands. you can manage rights for actors (contributors, authors...). Installation took about 5 minutes just by following installation doc... I did not want to spend hours on designing my website or in maintaining it. Just pressing the "updates" button in the cms is quite enough :) Wordpress is quite user friendly, that's important if you have writers who are not expert in computers.
- customizable: I was not that bad on css and themes can be installed to change the display
- secure: after a JS script injection last month (but i'm guilty, I did not update wordpress during 8 months...), I've slighty enhanced the security on the site by installing few security plugins that work well and following small "basic" security advices on wordpress.
My web site is running since 18 months, the only bill I get for it is for the domain name. Most pics are hosted on picasa gallery (so no problem with upload limit), all pdfs (I host some FERC files) are hosted on acrobat.com. Host is up 99% of time, backups are available in less than 10 minutes, ftp access etc...I made those choices to prevent problems with bills. Main email is a gmail address (enough space for a whole life and efficient spam filter), access to Picasa and Google Analytics.
Off course, my website is not the most beautiful or the most original but in 5 minutes, I can post a new article, do updates etc...
If you want some informations about host or wordpress extensions I'm using, just let me know, I'd be happy to help you.
