Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 260 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
NetEA Army List Compendium 2012
 Post subject: Re: NetEA Army List Compendium 2012
PostPosted: Thu Feb 02, 2012 9:50 pm
COMMON NOTATION ADEPTUS MECHANICUS ARMY LISTS
Battle Titan vs Scout Titan Weapons
Currently, titans can choose from Scout and/or Battle Titan Weapons.
The weapon class headers are called:
Scout and Battle Titan Weapons
The reference sheet again divides them into Scout Titan Weapons and Battle Titan Weapons.
I think it would be more elegant to just use these two terms: Scout Titan Weapons and Battle Titan Weapons. Warhounds are restricted, the battle titans are not.
Or maybe I have missed something.
Shared typos for all three Adeptus Mechanicus lists (3.1-3.3)
Warhound. Critical Hit Effect. Says "...on a D6 roll of 6+...", should be "...on a D6 roll of 6..."
Found in the following reference sheets: War Gryphons (p.70), PDF (p.73), Hyperion (p.76).
Reaver. Critical Hit Effect. Says "...any units within 5cms will be hit...", should be "5cm"
Warlord. Critical Hit Effect. Says "...any units within 5cms will be hit...", should be "5cm"
Found in the following reference sheets: War Gryphons (p.70), PDF (p.74), Hyperion (p.76).
/Fredmans
PostPosted: Mon Feb 06, 2012 11:17 am
4.1 Adeptus Ministorium Army List (p.79). Dominion Recon, upgrades. Says “Transport(must be taken)…”, should be “Transport (must be taken)…”.
4.1 Adeptus Ministorium Army List (p.79). Fraternis Militia Detachment, upgrades. Says “Vehicles(may not…”, should be “Vehicles (may not…”.
4.1 Adeptus Ministorium Army List (p.79). “Repentia” upgrade description refers back to “Sisters Repentia upgrade”
4.1 Adeptus Ministorium Army List (p.79). Transport upgrade, description. Says “Immolators(either type)”, should be “Immolators (either type)".
4.1 Adeptus Ministorium Army List (p.79). Reaver Titan, cost. Says 625.
4.1 Adeptus Ministorium Names in Army List / Reference Sheet (p.79-81).
Repentia Confessional: Repentia units
Repentia Upgrade: Sisters Repentia units
Reference Sheet unit entry: Sisters Repentia.
Reference Sheet transport notes: Sisters Repentia
4.1 Adeptus Ministorium Names in Army List / Reference Sheet (p.79-81). [army list / reference sheet]
Mistress / Repentia Mistress
Arco-flagellant / Arco-flagellants
Dominion / Dominions
Redemptionist / Redemptionists
Retributor / Retributors
Rhino / Adepta Sororitas Rhino
4.1 Adeptus Ministorium Reference Sheet (p.80). Sentinel weapon says “Multi-laser”, whereas Chimera says “Multilaser”. I have not checked every reference sheet, but it seems to be a general inconsistency.
4.1 Adeptus Ministorium Reference Sheet (p.80). Adepta Sororitas Rhino, transport notes. Says “Battle Sisters” instead of “Sisters of Battle”.
4.1 Adeptus Ministorium Reference Sheet (p.80). Immolator “Justice Pattern”, transport notes. Says “Battle Sisters” instead of “Sisters of Battle”.
4.1 Adeptus Ministorium Reference Sheet (p.80). Immolator “Hellfire Pattern”, transport notes. Says “Battle Sisters” instead of “Sisters of Battle”.
4.1 Adeptus Ministorium Reference Sheet (p.80). Repressor, transport notes. Says “Battle Sisters” instead of “Sisters of Battle”.
4.1 Adeptus Ministorium Reference Sheet (p.80). Reaver Titan notes. Says “4 Void Shield”, should be “Shields”
4.1 Adeptus Ministorium Reference Sheet (p.80). Reaver Titan, critical hit effect. Says “…any unit within 5cms will be hit…”, should be “5cm”.
4.1 Adeptus Ministorium Reference Sheet (p.81). Warhound Titan, critical hit effect. Says “…on a D6 roll of 6+…”, should be “…on a D6 roll of 6…”.
4.1 Adeptus Ministorium Reference Sheet (p.81). Warlord Titan, critical hit effect. Says “…any unit within 5cms will be hit…”, should be “5cm”.
/Fredmans
PostPosted: Mon Feb 06, 2012 3:24 pm
On the pedantic/pluralization/transport name/etc stuff, are people looking for this in the compendium now or can they wait for it to be in there come July or in the 2013 compendium?
If they're looking for that stuff to be in there now I need someone else (looking at you Fredmans) to take this over for the Feb/March releases.
If people can wait, I'll get the most important stuff (wrong stats/army lists, missing datasheets) out the door and hold off on the others.
PostPosted: Mon Feb 06, 2012 3:31 pm
Sounds good to me.
Making a quick compilation of more "serious" errors during the day.
Ordo Hereticus Army List (p.82). Reaver cost. Says “625”.
Ordo Hereticus Reference Sheet (p.83).Inquisition Land Raider, transport notes. Should be just “Inquisitor”.
Ordo Hereticus Reference Sheet (p.83). Inquisition Rhino and Inquisition Valkyrie transport notes. Uses Adeptus Ministorium units.
Ordo Hereticus Reference Sheet (p.84). Black Citadel, transport notes. Lacks Inquisitor.
Ordo Hereticus Reference Sheet (p.84). Obsidian Fortress, transport notes. Lacks Inquisitor.
Ordo Hereticus Reference Sheet (p.84). Gun-cutter, transport notes. Lacks Inquisitor.
Ordo Hereticus Reference Sheet (p.84). Rogue Trader Vessel, transport notes. Lacks Inquisitor.
Ordo Hereticus Reference Sheet (p.84). Inquisition Battleship, transport notes. Lacks Inquisitor.
Imperial Allies Reference Sheet (p.85). Warlord, critical hit effect. Uses Banelord critical.
CHAOS ARMIES, INITIATIVE. The 6.0.2 common rule Factions applies to Black Crusade and Stigmatus Covenant armies, but mono-god and some traitor lists do not seem to use it, or do formidably with their 0+ initiative. Maybe armies that use Factions should specify it in the first paragraph along with strategy rating and initiative.
Stigmatus Covenant Reference Sheet (p.93). Traitor Sentinel, type. Says AV, should be LV.
Vraksian Traitors Reference Sheet (p.96). Traitor Leman Russ Demolisher. Has FF4+, should it be FF3+?
Vraksian Traitors Reference Sheet (p.97). Malcador, Malcador Defender and Malcador Annihilator all lack Reinforced Armour.
/Fredmans
PostPosted: Mon Feb 06, 2012 7:30 pm
/Fredmans
Actually, this is the other way around. The correct unit name is "Battle Sisters". The transports are right, but the unit name and army list are wrong to refer to "Sisters of Battle".
