Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 260 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18  Next
NetEA Army List Compendium 2012
 Post subject: Re: NetEA Army List Compendium 2012
PostPosted: Fri Jan 13, 2012 9:27 pm
1.11 Grey Knights Army List (p.33). Purgation Squad unit description. Says "4 Grey Knight Purgation units", should be "4 Grey Knights Purgation units".
1.11 Grey Knights Army List (p.33). Question regarding 0-1 choices (Brotherhood Champion and Vindicare Assassin. If the Brotherhood Champion is a 0-1 army choice, like the Space Marine Supreme Commander, it should be written that way, especially if the Vindicare Assassin is not. From the list, I'd guess that you can field 1 Brotherhood Champion, and 1 Vindicare/Inquisitorial Warband. The reason is that Commander is a 0-1 choice/formation anyway, so the 0-1 restriction means nothing if it does not restrict them further.
1.11 Grey Knights Army List (p.33). Reaver Titan costs 625.
1.11 Grey Knights Reference Sheet (p.34). Warrior Acolyte has lost its stats for Armour, CC and FF.
1.11 Grey Knights Reference Sheet (p.34). Land Raider Redeemer has lost its stats for Armour, CC and FF.
1.11 Grey Knights Reference Sheet (p.35). Warhound Critical Hit Effect. Says "D6 roll of 6+", should be "D6 roll of 6".
1.11 Grey Knights Reference Sheet (p.35). Grey Knights Strike Cruiser Transport Notes. Last sentence says "plus 6 Thunderhawk Gunships or Transporters". I suspect it should be "Thunderhawk Transporters".
1.12 Imperial Fists Army List (p.36). Achilles upgrade units description. Says "Land Raiders Achilles", should be "Land Raider Achilles"
1.12 Imperial Fists Army List (p.36). Commander upgrade cost. Says "+50 point", should be "+50 points"
1.12 Imperial Fists Army List (p.36). Hunter upgrade cost. Says "+75 point each", should be "+75 points each"
1.12 Imperial Fists Army List (p.36). Reaver Titan costs 625.
1.12 Imperial Fists Army List and Reference Sheet (p.36 and 38). The army list says "Marauder Destroyer", the reference sheet lists "Marauder Heavy Bomber"
1.12 Imperial Fists Reference Sheet (p.37). Predator Destructor has FF4+, should be FF3+
1.13 Siege Vanguard Army List (p.39). Thunderfire Defence Battery unit description. Says "4 Thunderfire Cannon", should be "4 Thunderfire Cannons"
1.13 Siege Vanguard Army List (p.39). Commander upgrade cost. Says "+50 point", should be "+50 points"
1.13 Siege Vanguard Army List (p.39). Reaver Titan costs 625.
1.13 Siege Vanguard Reference Sheet (p.40). Dreadnought reference lists Hellfire and Tactical configurations. Army list says Hellfire or Vulcan.
1.13 Siege Vanguard Reference Sheet (p.40). Land Raider Helios Firepower. Says "1BP Indirect Fire", should be "1BP, Indirect Fire"
1.13 Siege Vanguard Reference Sheet (p.40). Land Raider Helios Transport Note. Says "(May carry 1 1 of...", should be "(May carry 1 of...".
1.13 Siege Vanguard Reference Sheet (p.41). Razorback Transport notes. Says "Transport (may...", should be "Transport: (may..."
1.13 Siege Vanguard Reference Sheet (p.41). Rhino Transport Notes. Lists codex units and not the Siege units.
1.13 Siege Vanguard Reference Sheet (p.41). Warhound Critical Hit Effect. Says "D6 roll of 6+", should be "D6 roll of 6".
1.13 Siege Vanguard Reference Sheet (p.40). Land Raider Crusader Transport Notes. Lists Black Templars units, should be Siege units.
1.13 Siege Vanguard Reference Sheet (p.40). Land Raider Crusader entry. I guess it has been added to the list, but it should be moved to the AV section of the sheet.
/Fredmans
PostPosted: Fri Jan 13, 2012 9:30 pm
fredmans wrote:
0.0 (p.1) under Section 2 – Army lists and Reference sheets: last sentence ends with “or fortifications data” [The text seems to refer to the reference sheets specifically, but I cannot find any fortifications data in any relevant Guards reference sheet. Instead I find some relevant data specified in certain army lists.]
Disregard the above. I had not realized some Marine lists used Fortifications and indeed lists them in their reference sheets. I also think it should be implemented for Imperial Guards fortifications.
/Fredmans
PostPosted: Fri Jan 13, 2012 9:33 pm
8.1 (p. 155). Scorpion lacks Reinforced Armor.
8.2 (p. 157). Scorpion lacks Reinforced Armor.
8.3 (p. 161). Scorpion lacks Reinforced Armor.
8.4 (p. 164). Scorpion lacks Reinforced Armor.
8.5 (p. 167). Scorpion lacks Reinforced Armor.
8.6 (p. 170). Scorpion lacks Reinforced Armor.
8.7 (p. 172). Scorpion lacks Reinforced Armor.
Basically the same error in all the Scorpion entries.
8.7 (p. 171). Autarch does not replace an exarchs in the formation. Don't know if this is intentional or not. I thought it was intentional in Alaitoc (draft 2010), but it got fixed in 2012.
PostPosted: Fri Jan 13, 2012 9:55 pm
General Errata for all Space Marines army using the relevant units:
Drop Pods. Rules explanation. "Then any troops carried in the drop pod must disembark within 5cm of the drop pod or within 5cmof another unit ..."
Drop Pods are used in the following armies: 1.1 Codex Astartes, 1.2 White Scars, 1.3 Salamanders, It is listed in 1.4 Scions of Iron but I recall Hena saying they should not, 1.5 Black Templars, 1.6 Blood Angels, 1.7 Raven Guard, 1.8 Space Wolves, 1.9 Apocrypha of Skaros.
Warlord Titan. Critical Hit Effect 4-6. "If destroyed any units within 5cms will be hit on a roll of 4+." Otherwise, consistently written "5cm".
Warlord Titans are used by the following Space Marine armies: 1.1 Codex Astartes, 1.3 Salamanders, 1.4 Scions of Iron, 1.8 Space Wolves, 1.9 Apocrypha of Skaros, 1.11 Grey Knights (where the error is found in the Psi-titan critical effects as well), 1.12 Imperial Fists, 1.13 Siege Assault Vanguard.
Reaver Titan. Same as Warlord above. Reaver Titans are used by the following Space Marine armies: 1.1 Codex Astartes, 1.3 Salamanders, 1.4 Scions of Iron, 1.8 Space Wolves, 1.9 Apocrypha of Skaros, 1.11 Grey Knights, 1.12 Imperial Fists, 1.13 Siege Assault Vanguard.
Editorial Note: The explanatory texts under the various headers, e.g Space Marine Detachments, Space Marine Upgrades, Imperial Allies Formations, are sometimes punctuated, sometimes not.
Example, Codex Astartes Army List
(A Codex Astartes Space Marine army may contain any number of Space Marine Detachments) [no punctuation]
(Each allowed upgrade may be taken once by each detachment.) [punctuation]
Editorial Note. In unit notes, units with just abilities uses commas (e.g. Scout, Infiltrator). When Transport capacity or critical hit effects are added, inconsistency emerges.
My suggestion would be to use period to differentiate between abilities (possibly including Transport capacity), rules and critical hit effects. [shown in example below]
Ability, Ability, Transport: (x of y, z and a). Critical Hit Effect/Special Rule.
/Fredmans
PostPosted: Fri Jan 13, 2012 11:44 pm
And They Shall Know No Fear: Space Marines count half their number of Blast Markers in assault resolution. I thought this was changed back to counting their full number of blast markers? Or am I confused?
PostPosted: Sat Jan 14, 2012 2:24 pm
fredmans wrote:
1.10 Dark Angels Army List (p.30). Intractable Special rule. Given that Ravenwing formations can include units that are not explicitly named Ravenwing (I'm thinking of the Land Speeder Tornados), does this rule mean Ravenwing formations, or formations that consist solely of units named Ravenwing?
/Fredmans
Ravenwing Formations.
PostPosted: Sat Jan 14, 2012 8:31 pm
Checking Space Marine army lists for units and structure (as well as catching new typos). Sorry if these have been mentioned before.
1.2 White Scars Army List (p.6). Bike Core units. Says "8 White Scar Bike units", should be "8 White Scars Bike units"
1.3 Salamanders. Reference sheet includes Land Speeder Tornado and Typhoon, but I see no way in the army list to get them.
1.4 Scions of Iron Army List (p.12). Land Raider formation has a Vindicator upgrade that is not listed. Should probably be Armour.
1.4 Scions of Iron. Reference sheet lacks Land Raider Helios.
1.4 Scions of Iron. Reference sheet include the following units that I cannot find in the army list: Dreadnought, Assault, Devastator, Thunderhawk Gunship.
/Fredmans
PostPosted: Sun Jan 15, 2012 1:59 pm
1.5 Black Templars. Reference Sheet includes Whirlwind, but there are no Whirlwinds in the army list.
1.5 Black Templars. Army List has a Sniper upgrade, but no Scout formation or Sniper upgrade listed.
/Fredmans
PostPosted: Mon Jan 16, 2012 7:46 am
1.6 Blood Angels Army List (p.18). Assault upgrade. Should be "Add 2 Blood Angels Assault units" to be consistent with the reference sheet.
1.6 Blood Angels Reference Sheet (p.19). Army List uses "Blood Angels" Land Raider and Redeemers. Reference Sheet says "Land Raider" and "Land Raider Redeemer"
1.6 Blood Angels Army List (p.18). Death Company upgrades list "Dreadnoughts", should be "Dreadnought".
1.6 Blood Angels Army List (p.18). Devastator formation upgrades. Hunter and Heavy Support upgrades should change place.
1.6 Blood Angels Army List. (p.18). Fast Attack upgrade, unit description. "Bike units" should be "Blood Angels Bike units".
1.8 Space Wolves Army List (p.24). Upgrades which can consist of 1 unit should be written in singular. This includes:
Razorback (Space Wolves Upgrades as well as in Long Fangs Pack Upgrades)
Land Raider (Space Wolves Upgrades, Great Company Upgrades, Wolf Guard Terminators Upgrades, Long Fangs Pack Upgrades)
Dreadnought (Space Wolves Upgrades, Great Company Upgrades)
Vindicator (Space Wolves Upgrades, Blood Claws Pack Upgrades)
Swiftclaw Attack Bike (Space Wolves Upgrades, Swiftclaws Bike Pack Upgrades)
/Fredmans[font=][/font]
PostPosted: Tue Jan 17, 2012 12:16 pm
1.9 Apocrypha of Skaros Army List (p.27). Armoury and Predator Upgrade description. Says "Land Raiders", should be "Land Raider".
1.10 Dark Angels Army List (p.30). Army List uses undefined "Predators" in Ironwing Formation and Ironwing Support Upgrade. Should list the different versions in a previously used way, depending on what combinations are allowed.
1.10 Dark Angels Army List (p.30). Ironwing Support upgrade. Says "Add up to 2 Vindicator...", should be "Add up to 2 Vindicators..."
1.10 Dark Angels Army List (p.30). Land Raider upgrade description. Should say "Dark Angels Land Raiders". Land Raider Crusaders is consistent with reference sheet, but should probably be changed to "Dark Angels Land Raider Crusaders/Crusader" in the army list and reference sheet.
1.11 Grey Knights Army List (p.33). Land Raider upgrade. Says "Land Raiders" in Strike Squad Upgrades, Terminator Upgrades, Purgation Squad Upgrades and in the title under Grey Knights Upgrades.
1.11 Grey Knights Army List (p.33). Says "Psi Titan" in army list, "Psi-Titan" in reference sheet.
1.11 Inconsistency between army list and reference sheet for the following units [army list/reference sheet]:
Grey Knight Interceptor/Grey Knight Interceptors
Grey Knights Strike Squad/Grey Knights Strikes
Grey Knights Purgation/Grey Knights Purgations
1.12. Imperial Fists Army List (p.36). Army list uses "Terminator Assault" units, reference sheet says "Assault Terminator"
1.12 Imperial Fists Army List (p.36). Upgrades for Scout Snipers and Thunderfire Battery uses "Dreadnoughts", upgrade itself is named "Dreadnought"
1.12 Imperial Fists Army List (p.36), Static Defences. Army List says "Firebase", reference sheet says "Fire Base".
1.13 Siege Assault Vanguard (p.39).The following units are in the reference sheet, but not in the army list:
Bike
Scout
Thunderhawk Interdictor
On to Guards... (but tonight is game night)
/Fredmans
PostPosted: Wed Jan 18, 2012 1:07 am
I think fredmans is doing a fine job searching for all these typos and I would like to say my thanks for his hard work!
PostPosted: Wed Jan 18, 2012 1:13 am
I agree, though he's causing me a lot of work to collate the change doc. :) Thanks, Fredmans
PostPosted: Wed Jan 18, 2012 1:18 am
Its crazy pedantic but thats what is needed when proofing.
Good work fredman!
PostPosted: Wed Jan 18, 2012 1:24 am
Yep great job Fredman!
