Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 260 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 18  Next
NetEA Army List Compendium 2012
 Post subject: Re: NetEA Army List Compendium 2012
PostPosted: Tue Jan 10, 2012 1:21 am
PostPosted: Tue Jan 10, 2012 7:58 am
Hi guys. From someone who contributes nuthin to the hobby he enjoys the most, thanks for this document. And the version one is able to download is not the "draft version," correct?
Thanks
PostPosted: Tue Jan 10, 2012 12:42 pm
PostPosted: Tue Jan 10, 2012 7:28 pm
madd0ct0r wrote:
not any more. we just reused the same thread
Thanks
PostPosted: Tue Jan 10, 2012 10:08 pm
In an effort to make this topic cleaner/easier to read can I ask that people go back through and delete posts and discussion that don't contain typos? Ideally saying something like this in each post:
Unit X on page 100 has 5+ for it's FF. It should be 6+.
Unit Y on page 101 has no CC value. It should be 3+.
PostPosted: Tue Jan 10, 2012 11:37 pm
rather than deleting posts, a new topic for JUST typos and corrections could be made
preserve information people!
PostPosted: Tue Jan 10, 2012 11:40 pm
PostPosted: Wed Jan 11, 2012 1:01 am
Minor issue
P121 - KABAL OF PAIN'S WAY DARK ELDAR ARMY LIST - Doesnt have the '9.1 NetEA APPROVED' on that page
PostPosted: Wed Jan 11, 2012 2:12 am
Typo Space Wolves army list pg.27
Blood Claws should have the Land Raiders upgrade (looks like I omitted it by mistake from the 2.4 list itself then transferred the error to the compendium)
PostPosted: Wed Jan 11, 2012 3:42 am
p53 - MINERVAN TANK LEGION ARMOURED REGIMENT IMPERIAL GUARD ARMY REFERENCE 2
Stormhammer has no Critcal hit Effect listed
PostPosted: Wed Jan 11, 2012 3:26 pm
Page 191 - Tau Special Rules
Tau Jet Packs: Second paragraph should be replaced with: Tau Jet Packs follow all the rules for Jump Packs. (Otherwise need to write specifically that Jet Pack equipped troops can deploy up to 15cm from aircraft).
Page 193 – Third Phase Ref Sheet
1. Shas’el should not have invulnerable save in notes.
2. Gun Drones should not have Drones in notes.
3. Rename Kroot Carnivore to Kroot Warriors.
4. Barracuda missing AA5+ from Ion Cannon.
5. Custodian Battleship should not have slow and steady in notes.
Page 195 – Farsight Army List
1. Support Formations should be limited to two per core.
2. Ethereal option needs removing from upgrades.
3. Custodian needs replacing with Explorer with cost at 225pts.
4. AX-1-0 squadron needs replacing with missile strikes cost at 225pts.
Page 196 – Farsight Ref Sheet
1. Needs Ethereal entry removed.
2. Enclave Shas’o needs Coordinated fire and Leader removed from notes and addition of Supreme Commander
3. Shas’el needs Coordinated fire removed from notes and addition of Commander.
4. Enclave Pathfinders need Coordinated fire removed from notes.
5. Barracuda missing AA5+ from Ion Cannon.
Page 198 – Fio’Ka Ref Sheet
1. Gun Drones should not have Drones in notes.
2. Barracuda missing AA5+ from Ion Cannon.
3. Custodian Battleship should not have slow and steady in notes.
PostPosted: Wed Jan 11, 2012 9:10 pm
I will use the printed pagination, and underscore typos and errors. I will also bring up certain inconsistencies for the editor to consider.
ENTIRE ARMY LIST COMPENDIUM
On every reference sheet, the header "Notes" is italicized.
TABLE OF CONTENTS
p.i – 1.0.1 “And They Shall Know No fear”. Should be “Fear”
INTRODUCTION AND EXPLANATIONS
0.0 (p.1), under Section 1 – Common Special Rules: “all Space Marine units benefit from the “They Shall Know No Fear” special rule…”. Should be “...from the “And They…”
0.0 (p.1) under Section 2 – Army lists and Reference sheets: last sentence ends with “or fortifications data” [The text seems to refer to the reference sheets specifically, but I cannot find any fortifications data in any relevant Guards reference sheet. Instead I find some relevant data specified in certain army lists.]
0.0 (p.1) under Section 2 – Army lists and Reference sheets: The list of abbrevations lack the following used acronyms: LF and RF (for instance for Thunderhawk Gunship).
0.1.2 Self Planetfall (p.1, in scatter procedure): “determine scatter […] as if it were a normal Planetfall, including loaded units disembarking up to 5cm.” Perhaps (non-native speaker suggestion) “,including the disembarkment of loaded units up to 5cm”
0.1.2 Self Planetfall (p.1, last sentence): “scatter role”. Should be “scatter roll”.
Will add to these...
/Fredmans
PostPosted: Wed Jan 11, 2012 10:52 pm
CHAPTERS 0 AND 1
Inconsistent way of referring to core rules: (EA, core rules, Epic Armageddon rules, Epic: Armageddon main rule book)
0.1.1 Expendable (p.1) uses: “(see EA 1.12.7)”
0.1.2 Self Planetfall (p.1) uses: “as Planetfall in section 4.4 of the Core rules” and later “determine scatter according to Core Rules 4.4”.
0.1.4 Tunnelers (p.1) uses: “(see EA 4.3.1)” twice
0.2.1 Aircraft Escorts (p.1) uses: “the Epic Armageddon rules”
1.0.2 Space Marines Transport (p.2) uses: “(see section 4.4 of the Epic: Armageddon main rule book)”
SPACE MARINES ARMIES SECTION
1.0.2 Space Marines Transports (p.2): “…will be noted as having ‘plus transport’ in the unit’s section of the army lists below.” Should probably refer to Core Units
1.0.2 Space Marines Transports (p.2, in the description of Spacecraft requirements): “at least one Space Marine Strike cruiser or Battle Barge…”. Should be “Cruiser”.
1.0.2 Space Marines Transports (p.2), *Please note: “e.g. Rhino, becomes Dark Angels Rhino […] and Drop Pod, becomes Space Wolves […])”. These commas could be omitted.
1.1 Codex Astartes (p.3): Vindicators’ cost reads “225points”. Should be “225 points”
1.1 Codex Astartes (p.3): Hunter upgrade costs “75 points each”. Should be “75 points”.
1.1 Codex Astartes (p.3): Land Raider Upgrade cost: “75 point each”. Should be “75 points each”.
1.1 Codex Astartes Ref sheet (p.4): Razorback Notes reads: “Transport (may…”. Should read: “Transport: (may…)”
1.1 Codex Astartes Ref sheet (p.4): Inconsistency between Razorback and Rhino Transport notes. Razorback says “Devastator & Scout). Rhino says “Devastator and Scout)”
1.1 Codex Astartes Ref sheet (p.5): Warhound Notes – Critical Hit effect. “D6 roll of 6+”. Should be “D6 roll of 6”.
1.2 White Scars (p.6): Hunter upgrade costs “75 points each”. Should be “75 points”.
1.2 White Scars ref sheet (p.7): White Scars Razorback Notes reads: “Transport (may…”. Should read: “Transport: (may…)”
1.2 White Scars Ref sheet (p.5): Warhound Notes – Critical Hit effect. “D6 roll of 6+”. Should be “D6 roll of 6”.
1.3 Salamanders (p.9): "Tacticals" formation should be "Tactical"
1.3 Salamanders (p.9): Predator detachment costs 275. Should be 250.
1.3 Salamanders (p.9): End of explanation of Salamanders Restricted Formations: "[...] this total)" should be "[...] this total.)"
1.3 Salamanders (p.9): End of explanation of Imperial Allies Formations: "[...] formations.)" should be "[...] Formations.)"
1.3 Salamanders (p.9): Commander costs says "+50 point". Should be "+50 points".
1.3 Salamanders (p.9): Inconsistencies in names of non-codex upgrades. Upgrades column says "Salamander Devastators" and "Salamander Tacticals" whereas the Upgrades are named "Salamander Devastator" and "Salamander Tactical". On p.9-10 the units are referred to as Salamanders Devastator and Salamanders Tactical.
1.3 Salamanders reference sheet (p.11): Salamanders Rhino transport notes. Reads "[...], Salamander Devastator, [...]". Should read [...], Salamander Devastators, [...]".
1.3 Salamanders reference sheet (p.11): Warhound Notes – Critical Hit effect. “D6 roll of 6+”. Should be “D6 roll of 6”.
1.3 Salamanders reference sheet (p.11): Salamanders Thunderhawk Gunship Notes - Transport capacity. "[...] Salamander Devastator, Salamander Devastator, Salamander Terminator [...]" Should be "Salamanders in all three cases.
1.3 Salamanders reference sheet (p.11): Salamanders Thunderhawk Gunship Notes - Transport capacity. "Terminators and Dreadnoughts [...]" should be "Salamanders Terminators and Dreadnoughts [...]".
1.3 Salamanders reference sheet (p.11): Salamanders Strike Cruiser - end of transport notes. Says "on Board).". Should be "on board)."
[Edited for Reaver Cost mistake]
More to follow...
/Fredmans
PostPosted: Thu Jan 12, 2012 1:23 am
fredmans wrote:
1.1 Codex Astartes (p.3): Reaver Titan cost: “650 points”. Should be “625 points”.
Well now I'm confused as I had the exact opposite question on price from someone else for the Reaver when the first lot of "AC typo checks" were done and had it changed to 650. What is it supposed to actually be??? 625 or 650?
These should definitely be Salamanders as the Chapter is the Salamanders.
Thanks Fredmans!
