Post new topic Reply to topic  [ 279 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 19  Next
Lightning Fighter Stats
 Post subject: Re: Lightning Fighter Stats
PostPosted: Thu Dec 01, 2011 3:47 pm
That's ok with me, and I believe ok with signal too, so that gives us:
Code:
Lightning Attack Fighter
Fighter   6+   -   -
Long Barreled Autocannon  45cm  AP5+/AT6+/AA6+  FFA
Twin Lascannons           30cm  AT4+/AA4+       FFA
Code:
Lightning Strike Fighter
Fighter   6+   -   -
2x Underwing Rockets      30cm  AT4+       FFA
150ish points for a pair for Attack Fighter, 200ish for Strike Fighter?
PostPosted: Thu Dec 01, 2011 3:48 pm
I'd suggest 175 and 200, and revise downwards after testing if nessesary.
Last edited by Evil and Chaos on Thu Dec 01, 2011 3:49 pm, edited 1 time in total.
PostPosted: Thu Dec 01, 2011 3:49 pm
That'd be fine too.
PostPosted: Thu Dec 01, 2011 3:51 pm
AA4+ meaning 3+ on intercept? Really?
PostPosted: Thu Dec 01, 2011 3:52 pm
It would have 1x3+ and 1x5+, statistically the same as the 2x4+ on the thunderbolt, just with a longer range as it's an AA specialist.
PostPosted: Thu Dec 01, 2011 4:09 pm
It's the Lascannons I really have a problem with. AA4+ does strike me as over the top. While it seems fine for the Attack Fighter, it seems out of place for the Strike Fighter. I understand that both have the same weaponry, so why can't we just make the lascannons AT4+/AA5+?
PostPosted: Thu Dec 01, 2011 4:10 pm
The exact same weapon already has AT4+ / AA4+ on the Marauder Bomber, however.
PostPosted: Thu Dec 01, 2011 4:12 pm
I'm fine with that, Signal isn't.
PostPosted: Thu Dec 01, 2011 5:14 pm
Grrrr.. Damn you Epic for being so rich and full of many units!
I dunno what to do.
PostPosted: Thu Dec 01, 2011 5:24 pm
If we give Strike Fighters AA3+ intercepts, you won't see the Attack Fighters taken unless there is a significant price difference. Say, 150 for Attack Fighters and 225 or 250 for Strike Fighters?
PostPosted: Thu Dec 01, 2011 5:27 pm
With speed fighter and extra AA range over a Thunderbolt, I'd say Attack Fighters are worth 175pts.
Strike Fighters as statted above are 16% better than Thunderbolts at AA at 30cm range, and 33% worse than Thunderbolts at 15cm range.
PostPosted: Thu Dec 01, 2011 5:29 pm
Then maybe removing the AP/AT shots from the autocannon would help drop that price down? I'm trying here...
PostPosted: Thu Dec 01, 2011 5:31 pm
removing the AP/AT shots from the long-barreled autocannon
No objection.
PostPosted: Thu Dec 01, 2011 5:34 pm
I dunno what to do.
It's not quite the exact same weapon. The Marauder has a twin lascanon is a turret at the front that can point anywhere in the front arc of the plane. The wingtip lascanons on the Lightning can't move to aim at all, they're fixed in place and so can only be used to attack an enemy plane straight in front of one or both lascanons. It is perfectly reasonable therefore for Wingtip Lascanons to have different stats to Twin Lascanons, since they are much more limited in their firing.
PostPosted: Thu Dec 01, 2011 5:55 pm
Okay, looks like we've got agreement on the Attack Fighter. Took us a bit, but I think everyone's mostly happy, at least :P AA6+ Autocannon and the AA4+ Lascannons it is.
Even though speed fighter has no effect on interception missions? Like Moscovian, I'd be happy with removing the ground attack capabilities of the Autocannon to drop the price. Makes the 45cm range weapon carry the fluff connotations of it being the primary AA weapon of the craft.
Code:
Fighter   6+   -   -
Long Barreled Autocannon  45cm  AA6+  FFA
Pricing is independent, but I think we can all agree that this is at rough parity with Thunderbolts, yes?
Code:
Fighter   6+   -   -
2 x Underwing Rockets  30cm  AT4+  FFA
Definitely more expensive than the Attack Fighter. The AA4+ does make it fairly decent at interception as E&C pointed out, but the Thunderbolts are still, on average, more capable. It's also very specialized at attacking Armored Vehicles, without any of the flexibility of the Thunderbolt. Regardless of the price, are we agreed on this statline?
