Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
Keep +1 AA on Intercept?
A) 8%  8%  [ 2 ]
B) 8%  8%  [ 2 ]
C) 20%  20%  [ 5 ]
D) 64%  64%  [ 16 ]
Total votes : 25
+1 AA on Intercept. Is it needed?
 Post subject: Re: +1 AA on Intercept. Is it needed?
PostPosted: Fri Jul 13, 2012 11:41 am
okay let's call it something else (providing the model, stats and everything else stays the same) how about a sky-turkey? :D
PostPosted: Fri Jul 13, 2012 11:51 am
Do you have any playtesting or game experience that the 1+ is broken, overpowered or in any way detrimental to epic games?
www.epic-uk.co.uk
PostPosted: Fri Jul 13, 2012 12:00 pm
No.
But i too have not experienced that without 1+ it is broken, underpowered or in any way detrimental to epic games.
After all with the inital release of EA the aircraft rules seem to work fine. Or the aircraft rules wheren't tested as thoroughly as the other rules in the book.
Apart from this: Current result on the poll shows that the majority doesn't see AA4+ as overpowered.
PostPosted: Fri Jul 13, 2012 12:18 pm
BlackLegion wrote:
For those who do not know what the "AA-umbrella" is:
After an aircraft moves on the board and performed its action it can still use its AA attacks on enemy aircrafts as Flak-attacks.*
Was that the ruling? I thought the enemy AC needs to END its approach move in an aircraft's AA arc and range in order to be target. Just going through it is doesn't trigger anything.
Also, were their FAQs on this? There's nothing in the master thread and there really should be. The RAW seem to further restrict these attacks to only AC performing a ground attack may shoot at other AC that are intercepting.
PostPosted: Fri Jul 13, 2012 1:27 pm
BlackLegion wrote:
As i said above i'm purely argumenting with EA stats. If i would argument with Wh40k stats then the Assault Cannon would have 15cm AP4+/AT5+ on a single Assault Cannon (calculated with my WhES) which would drop to 0cm range if it is mounted on an aircraft with any other Fire Arc than Fixed Forward (current EA stats consistency). :D
I'm gonna go out on a limb here then and say your much vaunted whes is a load of bunk. If it's producing widely unusable and broken results then maybe you need to admit there's no absolute conversion formula for 40k to epicA.
If AA4+ is too good on an intercept capable aircraft, you need to accept that the weapon stat is wrong and needs to change.
PostPosted: Fri Jul 13, 2012 1:59 pm
+1
There's just so much wrongness on this thread, pretty much every assertion seems to be a fallacy.
+1 intercept wasn't done because of "AA umbrella"
AA4+ on the sky talon isn't broken just because of +1 intercept (hint, it's because the sky talon looks like my grandma could outrun it, and she's dead)
AA values aren't "usually" the same as the AT value (none of the 3 most common interceptors stick to this at all)
The NetERC can't just decide a rule does not exist any more.
PostPosted: Fri Jul 13, 2012 2:45 pm
My last word on this wall-headbuttingly daft topic.
AA4+ is not "too good". Quite frankly that's a blinkered assertion that takes in no account of context.
At 225pts BL's stats for his Stormtalon are blatantly underpowered compared to other aircraft squadrons in its points cost bracket (They kill less, and die much easier than every other squadron type in that points bracket), yet there's this knee-jerk reaction going on that "4+ is too good".
Sure, 4+ when given to a too-cheap aircraft with 45cm range was "too good".
It categorically does not follow that therefore all 4+ rolls are "too good".
Context matters, sheesh.
PostPosted: Fri Jul 13, 2012 3:19 pm
If +1 to intercept was removed, it would actually favor aircraft with higher hit values.
Currently it's 2.33 vs 2 (2 Storm Talons vs 2 Thunderbolts). Removing the intercept bonus would make it 1.67 vs 1.33 - same absolute difference, higher relative difference (ratio of 7:6 vs 5:4).
So if the change was reverted it would favor Storm Talons, unless it made interceptors in general so useless that no one takes them.
PostPosted: Fri Jul 13, 2012 5:35 pm
MikeT wrote:
BlackLegion wrote:
I'm gonna go out on a limb here then and say your much vaunted whes is a load of bunk. If it's producing widely unusable and broken results then maybe you need to admit there's no absolute conversion formula for 40k to epicA..
Sure my WhES has its faults. I never claimed that it produces infallible and true stats for Wh40k weapons in EA. But it produces SOME stats as BASIS for discussion instead of pulling EA stats out of thin air. It was never intended to do more than this.
PostPosted: Fri Jul 13, 2012 8:55 pm
And FWIW, my argument about AA4+ weapons in intercept & CAP is based on the existing weaponry for all other Fighters and Fighter-bombers - except the Helltalon - irrespective of whether or not they gain the +1.
If AA4+ is adopted, it paves the way for 'arms creep' as sets a precedent for use on other 'new' aircraft, which ultimately will skew the way the game works, leading to calls for existing units to have their stats revised uprwards.
Another part of the problem lies in people's expectations over how the air-game and indeed E:A as a whole should work. There is a misconception that weapons should have a good chance of destroying the target. In the air-game, adding BMs can effectively prevent an A/c from appearing, thus reducing its usefullness between 33% - 50%. Up to 3x BMs can automatically be added to each air formation by shooting at it in the approach, on disengagement and by interception; actually shooting something down should be regarded more as a bonus!
PostPosted: Sat Jul 14, 2012 3:33 pm
Hmm on a quick thought i can't imagine a weapon with an AA3+ value. That would be an AP2+ or AP3+/ATx+ weapon.
Even a Twin Reaper Autocannon (AP4+/AT6+) would rather produce 2 x shots than AP3+/AT5+ as a single Reaper Autocannon alreaady is Twin-linked.
And if AA4+ is THAT good then simply increase the price of the aircraft.
The "best Fighter of the game" the formation of three Nightwings still will eat a formation of two Storm Talons for breakfast.
PostPosted: Sat Jul 14, 2012 3:49 pm
Fighters attacking fighters isn't a very relevant comparison, so the relevant comparisons for a Storm Talon starts and ends with the Thunderbolt, really, and performance on intercept/cap mission (so number of hits and resistance to flak).
PostPosted: Sat Jul 14, 2012 4:04 pm
With the statistics E&C provided here:
viewtopic.php?p=451083#p451083
The two Storm Talons produce 0.33 more hits than two Thunderbolts and need 0.33 more hits to be destroyed completely.
PostPosted: Sat Jul 14, 2012 7:34 pm
Also the Stormtalon gets 1+ initiative the T/bolts are 2+, that's a 16.66% boost per turn.
PostPosted: Sat Jul 14, 2012 8:00 pm
Thunderbotls cost 175pts. 116,66% are 204.155pts.
I guess with 200pts the cost is quite correct.
