Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
NetEA Army List Compendium 2012 - 20120208
 Post subject: Re: NetEA Army List Compendium 2012 - 20120208
PostPosted: Wed Apr 04, 2012 12:51 am
Not 100% sure if these are actual errors, as the only historical versions of the list I could easily find went by the name 'SUMBUDDIERUVVER’S BLOOD AXE WAR HORDE ORK ARMY'. However, there's a number of inconsistencies in the BLOOD AXE KOMMANDANT UG SKRAGGA MORKRUMPS’S KORPS ORK ARMY list. Both are labeled as v1.3 with Neal Hunt as the army champion, so I'm assuming they're supposed to be the same.
page 141 of the pdf (p133 on the page), BLOOD AXE KOMMANDANT UG SKRAGGA MORKRUMPS’S KORPS ORK ARMY
Warband formation list entry: includes Killa Kanz as an upgrade option. The 'Sumbuddieruvver' version does not include Killa Kanz. Killa Kanz and Dreadnoughts do not appear anywhere else in the list, and do not seem to be in theme. Not sure they should be here or if they're a cut and paste error from other Ork lists.
Bommer's formation list entry: 'Ork Bommer'. Unit reference list: 'Bommer'. This is inconsistent naming.
Bommers Special Rule indicates that they can be part of a squadron of Fighta Squadron. The formation list does not support this; they are two separate entries. Either this special rule needs to go, or there should be an option in the Fighta Squadron to upgrade or add Bommers. In the 'Sumbuddieruvver' version of the list, they were only upgrades to the base Fighta Squadron.
Special Rule Deth From Above indicates that there are Drop Kanz, Kroozers and Battlekroozers. The unit reference list supports this. The main list entries (and points) are missing. 'Sumbuddieruvver' version of the list had the following three additional entries:
Kill Kroozer, One Kill Kroozer, May be upgraded to Ork Battlekroozer for +50 points, 200
Gargant, One Gargant, n/a, 650
Great Gargant, One Great Gargant, n/a, 850
page 157 of the pdf (document page 149), KOLONEL SANDORK'S BLOOD AXE CLAN ORK ARMY
Several formation entries reference a +50 point upgrade 'Warkopta'. This unit does not appear in the unit reference list. Based on the 3.04 Supplemental list here: viewtopic.php?f=83&t=22042 it should have the following profile:
Ork Warkopter
Light Vehicle
35cm 5+ 6+ 6+
2x Big Shoota 30cm AP6+ / AT6+
Skimmer, Transport (2 from: Boyz, Kommandos or Nobz. Plus 1 Grot unit in addition to other units, May not carry Meganobz)
PostPosted: Tue Apr 24, 2012 9:23 pm
Page 140,
Feral Orks reference sheet
The orkeosaurus is missing it's dammage capacity (or DC) in it's notes.
It should have DC 6 added to the begining of it's notes.
The same page,
steam gargant is listed as move 12 cm
should be 15 cm.
cheers!
PostPosted: Tue Apr 24, 2012 10:00 pm
The Bikes entry in the Space Marine list omits the word "unit" (on page 3).
The Apocrypha of Skaros 1.1
Rogue Trader Expedition 0.4
The Horus Heresy 0.5
Night Lords 0.1
My Trade Thread
PostPosted: Tue Jul 03, 2012 9:18 pm
page 191,
KABAL OF PAIN'S WAY DARK ELDAR ARMY LIST REFERENCE 1,
The heamonculi unit it's missing it's armour, CC and FF values.
they should read:
armour CC FF
4+ , 3+ , 5+
Another inconsistency I noticed between this document and Raiders 2, on the same unit as above, is that it's weapon Arcane terror has 20 cm range in Raiders but 15 cm in the compendium. I'm inclined to believe however that it's Raiders 2 that's at fault here since 20 cm is a rather unconventional range for a weapon in epic.
Same page
The Warp Beast unit is missing EA(+1) in it's Firepower stat.
PostPosted: Wed Jul 04, 2012 11:04 am
link dead for this one too?
PostPosted: Wed Jul 04, 2012 12:10 pm
It was either hosted via the wiki or some part of the site that CS hasn't gotten to yet. Anyway, I just attached it to the first post.
PostPosted: Fri Jul 06, 2012 10:55 am
Hy,
page 108
Emperor Children Subjogator CC/FF is 5+/3+ should be 3+/5+
Regards
PostPosted: Sun Jul 15, 2012 1:24 pm
Hi, Page 104
Death Guard list
the Plague reaper War Engine has a demolisher cannon, it lacks ignore cover which demolisher cannons usually have.
cheers
PostPosted: Sun Jul 15, 2012 2:36 pm
gazrak wrote:
Hy,
page 108
Regards
This is also true for the LatD list, page 98.
PostPosted: Wed Jul 18, 2012 8:15 am
P57
Minervans Reference sheet
Valkyrie is missing.
PostPosted: Fri Jul 20, 2012 10:35 pm
The Thunderhawk Transporter in the reference sheet for the Black Templars list is missing it's CC and FF values.
The Thunderhawk Transporter in the Scions reference sheet is also wrong in a different way in having AA4+ Twin Heavy Bolter, rather than the correct AA5+.
Also, the criticals on both state the aircraft crashes, but not the closing statement that this kills all on board. For completeness this should be added.
PostPosted: Sat Jul 21, 2012 6:46 am
The Magna Melta on the Caestus Assault Ram is MW4+ going by the Raven Guard list, but the compendium has it as MW5+ in error. Page 25.
PostPosted: Sun Jul 29, 2012 8:38 am
Hi
The stats of the Warlord are missing in the Feral Orks Army list.
PostPosted: Wed Aug 08, 2012 3:57 am
There are errors in the Vraksian list, I'll skip giving the page number sorry, as I think they're coming out different on my mobile, but it should be easy enough to find.
The Valdor is missing the Reinforced Armour it should have.
The Minotaur is missing the Reinforced Armour and Thick Rear Armour it should have.
PostPosted: Wed Aug 08, 2012 4:04 am
The Attack Bike in the Space Marine lists should take up a single transport slot in a Landing Craft, not two slots as you have it now. It should also be amongst the list of units that can be transported in a Thunderhawk.
I thought the Compendium had these wrong and opened a thread about it and Dobbsy confirmed they were. See here: viewtopic.php?f=73&t=23611&hilit=Attack+bikes
