Post new topic Reply to topic  [ 99 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
[Weapons] Issues with Plasma weapons
 Post subject: [Weapons] Issues with Plasma weapons
PostPosted: Wed Sep 23, 2009 9:58 am
Quote: (stompzilla @ Sep. 23 2009, 04:49 )
It's not exactly rocket science is it boys?
If you want to fire plasma every turn you fire one plasma cannon from each demolisher every turn.  It's no more difficult than keeping track of warhound plasma blast guns or manticores.
Now correct me if i'm wrong but even a monkey can be trained to count the no of demolishers in a unit and work out how many plasma shots (1 each!) there are if done in this way.  If you try to get any more complicated than this, then you bring the hassel on yourself which hardly makes for a satisfactory argument for effectively doubling the firing rate of demolisher plasma cannons.
Come on, who wouldn't want to fire all weapon systems the second they get into range with those things? Bearing in mind this is probably turn 3 or if you are lucky turn 2. The problem comes because most likely they are not all in range. So some fire, some don't. Yes there are a multitude of ways of tracking it (turn it round which looks bad, give it a marker that can get knocked, etc etc but it would be far easier if you didn't have to.
PostPosted: Wed Sep 23, 2009 2:07 pm
The issue is probably less about the Demolisher Plasma Cannon Sponsons and more about the current Dark Angel lists having Tactical squads carrying them.
TRC's DA Tacticals have the AP5+/AT5+ Mk.V Plasma Cannon
Blacklegions DA Tacticals have the AP4+/AT4+ Slow Firing Plasma Cannon (as per the sponson).
I like the AP4+/AT6+ version (for the DA Tacticals at least, maybe under the Mk.V name) as Plasma cannons aren't any better than Missile Launchers or even equal to Lascannons at popping tanks.
How would Range:30cm, Firepower:AP5+, Notes:Macro-Weapon read as a weapon option. I think it conveys AP only MW in a form that is recognised by the rules and players know how to use it.
You could also do an unorthodox split weapon mode option (like Eldar Titan weapons) for the AT component. Would be listed as Range:30cm, Firepower:AP5+, Notes:Macro-Weapon OR Range:30cm, Firepower:AT6+, Notes:-
PostPosted: Wed Sep 23, 2009 2:27 pm
KISS!
Whatever gets done, don't introduce different versions of the same gun (addition of Mark Whatever alone doesn't cut it) with different profiles without a damn good reason.
PostPosted: Wed Sep 23, 2009 2:31 pm
I just wanted to call the new version a heavy plasma gun, but no, everyone keep telling me about this game 40k that I haven't played for 16 years.
PostPosted: Wed Sep 23, 2009 2:35 pm
I vote for keeping the current Plasma Cannon stats exactly as they are myself, it's a little bit extra book keeping, but it's characterful and fits in with the plasma weapons from the titans.
(I also think it's silly to give Dark Angel's Tacticals and Devestators Plasma Cannons as the mix of heavy weapons they use should be abstracted to shoot as Missile Launchers just as all other Marines ones are - there's no need to exaggerate difference for the sake of change).
PostPosted: Wed Sep 23, 2009 3:08 pm
But not strangely with the plasma gun on the stormtroopers.
For the DA no, I dissagree, swapping range for AT makes for a different tactical experience that helps differentiate the army.
PostPosted: Wed Sep 23, 2009 3:40 pm
I was against giving Dark Angels Infantry any Plasma weapons because of the same reason GlynG said. But there was wailing and moaning thats not characterful because DarkAngels where renown for fielding Plasma Cannons (in earlier editions of Wh40k they where the only Chapter which could field Plasma Cannons in Tactical Squads).
So i give in and added the option to switch some (not all) Tacticals for Plasma Cannon Tacticals.
PostPosted: Wed Sep 23, 2009 5:04 pm
Quote: (BlackLegion @ Sep. 23 2009, 15:40 )
In earlier editions of Wh40k they where the only Chapter which could field Plasma Cannons in Tactical Squads.
Plasma cannons (or heavy plasma guns, as they used to be called) were available to any Space Marine Tactical Squad in 2nd edition, and I'm pretty sure they have been ever since. Not sure if the DA had their own army list in 1st edition; if they did, I don't have a copy.
- George Borrow
PostPosted: Wed Sep 23, 2009 6:17 pm
Hmm then it was 3rd edition where all big-4 chapters got their mini-codex.
PostPosted: Thu Sep 24, 2009 3:45 am
I can't find my 3rd-ed. Codex at the moment, so I'll have to assume you're right on that one.  :)
- George Borrow
PostPosted: Thu Sep 24, 2009 11:39 am
For the DA issue, it's either drop the plasma cannon as an option or alter it to a non-slow-firing variant. It has wormed it's way in with no real reason to be there anymore (Both DA lists here and EpicUK's Dark Angel Dev's have 2 but not on tacticals).
If the Demolisher isn't a problem then leave it alone.
PostPosted: Sat Oct 03, 2009 5:57 am
In the 3rd Edition Marine Tactical Squads had only heavy bolters, missile launchers and lascannons.  Dark Angels had Plasma Cannons as well in their minidex.
The Heavy Plasma Gun on minimum power in 2nd Ed 40k are approximately like current plasma cannons in 40k.
It shouldn't need to wait to shoot.  To me it seems wierd that weapons of this size are slow firing in the epic time scale.  Having to wait to 15min between firing is a bit excessive, 15 min is a long time.  I would think that the Plasma Cannons overheating problem should be represented as the weapon not being as lethal as it could be.
I don't care if keeping track of which one has fired or not is easy or hard.  It just doesn't seem consistent with the way plasma cannons / heavy plasma guns have been described and used from 2nd ed onwards.  I would advocate changing it to 30cm AP5+/AT5+.  It definately does not diserve MW.
Leave slow firing to super heavy weapons.
PostPosted: Sat Oct 03, 2009 5:03 pm
As we in germany would say "Butter bei die Fische"  :cool:
What is the NetERCs view of the state of the Plasma Cannon?
PostPosted: Sat Oct 03, 2009 5:05 pm
Translation, please. My German is a bit (make that a lot) rusty.  :grin:
