Parts parts form FW
 Post subject: Parts parts form FW
PostPosted: Mon Feb 26, 2007 5:47 am
I got some badly casted parts from Forge World.
I have requested that they replacement parts.
I have attached pictures.  Do you guys think I had a valid complaint/argument?
While FW makes somw of the best looking models I find that their casting quaility is very hit and miss. soem perfect with siome just horrid.
PostPosted: Mon Feb 26, 2007 5:49 am
second set.  The one cracked as I was trying to trim the flash
PostPosted: Mon Feb 26, 2007 5:51 am
Yep !   They should replace those ... I don't think they should give you a problem !
PostPosted: Mon Feb 26, 2007 7:54 am
CC, the first one got hit by Nid flak!
They shouldn't have problems replacing - valid call, I'd say.
Back from oblivion (again)?
PostPosted: Mon Feb 26, 2007 4:58 pm
I think you have a complaint.
PostPosted: Mon Feb 26, 2007 5:07 pm
The top one definately looks like a torn mold and a valid complaint.
PostPosted: Mon Feb 26, 2007 6:31 pm
FW replied.  They are sending replacement parts.   :)
PostPosted: Tue Feb 27, 2007 6:02 pm
As I said !  "Success" !  :;):
PostPosted: Tue Feb 27, 2007 10:46 pm
Yep. I can't believe they let so many bad casts get out of those molds...
PostPosted: Wed Feb 28, 2007 10:04 am
I've just had to phone for a replacement Nightwing body, that one was completely unrepairable, missing half of the 'nose' and a strange 'napped' quality to the whole upper surface leaving no detail whatsoever. No problems...a new piece is being sent as we speak  :D  :D
PostPosted: Wed Feb 28, 2007 10:09 am
I agree, it is a real hit-miss with Forgeworld, just like GW it has a very very bad quality control.
All BFG:
Last summer :
2 Protectors: clean, excellent cast
3 Castellans: all bend and a twist in the wing
Now february;
1 Custodian: one engine came from different casting (grey instead of white). Otherwise excellent besides very much flash.
2 Emissary: engines (on hull) not that good but repairable. Very much flash and one of them very much 'dirt' on the prow. Pity.
3 Castellans: this time excellent
4 Wardens: excellent
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Wed Feb 28, 2007 3:18 pm
That's even more odd considering I got essentially the same mix of ships last summer, and they were superb.
I wonder what the main variable is? That drunk guy that comes in on Friday?
PostPosted: Wed Feb 28, 2007 5:37 pm
Some of the plastic land raiders in my SM2 box set were partially melted, as if they were warped when being taken out of the mold while still hot. A bit sad to think things haven't got any better.
