d6 vs. d10
 Post subject: d6 vs. d10
PostPosted: Fri Aug 11, 2006 11:23 pm
(beelzemetz @ Aug. 11 2006,14:27)
hello folks,
sometime ago i?ve read a thread with the above theme,
only i don?t remember anymore where it was.
is anyone able to help me locate it?
thanks,
beelzemetz
Is it this thread you are thinking of?
d10 for Epic
dafrca
              - Cities of Death, page 59
PostPosted: Sat Aug 12, 2006 12:27 am
(beelzemetz @ Aug. 11 2006,15:51)
just one problem remains:
i can?t read half the posts,
there is no text in some posts.
has somebody an explanation for this?
Interesting, I just went through all four pages and see text on every page, every post.  ???
Wish I could help, but I am unsure what would cause you to not be able to see texts unless you have selected to "ignore" people.
If the post has an "Unignore" button on the top right then that is it. If it says "Ignore" then I have no idea what it is.
Sorry.
dafrca
PostPosted: Sat Aug 12, 2006 4:40 am
I've been having the same problem - mostly with posts from the old boards. All I see are the comment posters' signature but no text.
Edit:
I just checked the same thread in Safari and everything looks fine - maybe it's a problem with Firefox (1.5.0.6 Mac OS X)?
PostPosted: Sat Aug 12, 2006 5:31 am
I seem to be experiencing the same issue...again with Firefox... :(
ib
PostPosted: Sat Aug 12, 2006 6:32 am
You guys need to post this issue over in the Forum area. Let Cybershadow know. He may have a solution for you.
dafrca
PostPosted: Sat Aug 12, 2006 6:41 am
It reads fine using Konqueror (the Suse Linux browser), but my version of Firefox (can't figure out which version I have ATM) doesn't like it either.  Firefox seems to have trouble with posts that have quoted text in them.
[QUOTE=Frecus]Who do you know has more than a couple of d10's? Do you know any set of more than three d10's, d20's or any other dice not d6?[/QUOTE]
I have over 120 d10 for Exalted alone, maybe over 200 (let's see, there's the 40 red, then there's about 40 blue/purple, then there's the 40 greens, then there's another 30ish in random colors from the Pound-O-Dice bag...still need white/gold, black/red, black/white, white, silver/blue, and red, orange/yellow, green, blue, violet, about 40 of each to start with, give or take 10 dice).  When you routinely roll 25 dice to-hit before adding magical effects (potentially doubling parts of your dice pool!), you need LOTS of dice.  Then every hit above the target's defense # is another die of damage (already over 13 dice, not counting Charms).
My old D&D character (a Crane Iaijutsu Master) rolled 4 d20s in melee, 2 or 3 at range per turn.  Cyberpunk uses d10 for ability rolls and the big guns (although v3 changed to d6 for heavy weapon damage, which I don't think I like).  Shadowrun and Heavy Gear/Silhouette use d6.
Do I have enough dice?  No.  I almost forgot the 200+d6 I have running around, including my 'Anything But(t)' dice, which have a picture of a (female, from the shape) posterior where the 'One' pip should be.  After all, you never say the word 'one' while rolling dice.
PostPosted: Sat Aug 12, 2006 7:14 am
:p
ib
