Epic carry cases
 Post subject: Epic carry cases
PostPosted: Tue Nov 01, 2005 2:03 pm
Hello,
Can anyone recommend me a good carry case to transport Epic stuff around?  I've got an old GW carry case but it's not that great for 6mm scale stuff.  I was wondering if there's anything better out there.
-Bombot
"The Hoff isn't just a person - he's a state of mind, a kind of higher power"
PostPosted: Tue Nov 01, 2005 2:59 pm
I use Plano plastic boxes normally used for fishing implements. You can find them at any wholestore. If you want extra protection you can line the spaces with felt.
PostPosted: Tue Nov 01, 2005 3:28 pm
I use plastic ammo boxes for .22 cal Remington rimfire rifle cartridges. I like them, but they are, obviously, hard to come by. :p :D
BTW, welcome to the boards, Bombot!  :cool:
PostPosted: Tue Nov 01, 2005 3:30 pm
Gun cases with foam padding are good. I have several myself that I use for larger figures such as titans.
PostPosted: Tue Nov 01, 2005 4:15 pm
Tackle boxes are more or less the standard.  The models are mostly lightweight enough that a bit of knocking around won't damage them.
For those that are more vulnerable, you can use felt or thin foam to cushion, or use magnetic strips to anchor them.
I use a modular system with separate boxes and a nylon carrying bag with pockets for all the gaming junk (dice, tapes, BMs, etc), so I just grab the boxes for the army I want and drop them in the bag.  I just use deeper trays without dividers for large models.
I also use Plano.  They make cheap, solid stuff.  A lot of other companies make their boxes interchangeable with Plano's because they are the biggest in the market, but any of the tackle box manufacturers have similar systems.
PostPosted: Tue Nov 01, 2005 4:54 pm
Quote (Dwarf Supreme @ 01 Nov. 2005 (07:28))
.22 rimfires?
Hehe... I'll see your .22 and raise you to a .50 cal ammo case. :p
I use the ammo cans with foam inserts cut to shape to transport stuff. They're a bit heavy but nigh on indestructable.
The Cheese! The Cheese!
PostPosted: Tue Nov 01, 2005 5:23 pm
Quote (Heresiarch @ 01 Nov. 2005 (15:54))
.22 rimfires?
Okay, so you beat me!  :D  :cool:
PostPosted: Tue Nov 01, 2005 9:34 pm
For some reason gun/ammo cases are harder to get in Uk than US!!
I use Figures-in-Comfort cases:
http://www.figuresincomfort.co.uk/
There are several different sized cases (I have several of 4/8/12 tray cases) with wide variety of foam trays from same as current GW foam trays to specific ones for vehicles/Titans.
They are UK company- for US you could also try Battlepack/Skirmishpack from Charon Productions: http://www.battlepack2001.com/
or Sabol Armytransport/Battaliontransport:
http://saboldesigns.net/index.php
James
My Epic trades list
PostPosted: Tue Nov 01, 2005 9:55 pm
I use Amway cardboard product boxes that I get form a neighbour of my mothers. I makes card dividers (using carefully measured and cut cartridege card, and add foam for delicate models. It is a fair bit of work, but stores the figures very securely (evem upside down etc) and there is very little 'waste space' in this storage technique (still boxes and boxes of them though ;): )
PostPosted: Tue Nov 01, 2005 9:56 pm
I have used both the fishing tackle boxes and pistal and rifle cases, I've also found certain candy boxes like for some chocolates make good carrying cases, also checkout fabric or pins and needle cases they tend to be made for cradling smaller objects.
who are we to bring down the stars
http://lostandfoundohio
PostPosted: Tue Nov 01, 2005 10:48 pm
Quote (wargame_insomniac @ 01 Nov. 2005 (13:34))
Hehe... I actually work for a Canadian defence contractor so I can occasionally snag them from work. I look at it as kind of a tax rebate.  ;)
I've also currently have a couple of end caps off British 81mm mortar shipping tubes sitting on my work bench right now that I'm looking at turning into industrial type structures / landing pads.
PostPosted: Tue Nov 01, 2005 10:54 pm
Ok, good suggestions all.  Wargame_insomniac - those Figures-in-Comfort cases look ideal for carrying cases.  I think I?ll look into those (I?m in the UK) and adopt some of the other ideas for static storage (chocolate boxes - like it!).
PostPosted: Wed Nov 02, 2005 12:34 am
Oh, I forgot, welcome to the forums Bombot. :)
PostPosted: Wed Nov 02, 2005 7:26 am
Welcome Bombat :8):
Pizza Boxes, with cardboard dividers and bits of foam for safety.
Besides think of the fun you'll have eating your way to enough containers for the hordes of minis :laugh:
Jaldon :p
PostPosted: Wed Nov 02, 2005 8:51 am
I'll see your .50cal boxes (I use them for tool boxes as they are nicely water proof) and raise you a 127mm HE packing crate!  Its full of all my terrain, hills, trees etc.
:p
For figs., I use tackle boxes, but keep them in a large plastic tool box into which they stack nicely.  The toolbox has small plastic compartments on the top for counters, dice, rules etc
Tas
Users browsing this forum: No registered users and 77 guests
