Anyone know a little about art pens?
 Post subject: Anyone know a little about art pens?
PostPosted: Sat Jun 04, 2005 8:41 am
Hi Guys,
I recently bought black art pens for situations when a 0000 or 00000 brush was not good enough for insignia on shoulder pads or when transfers werent small enough to be used.
The pen I used last night seems to be 005 size and it has a really super small tip.
Does anyone know if you can get different colours? My art dealer didnt know and I was after white and red. ?If not then I will just have to practice using a brush but I found a pen so much easier.
If anyone has any info I would be really grateful to hear it.
Thanks in advance.
Doug
PostPosted: Sat Jun 04, 2005 2:21 pm
I didnt know you could get them that small...have a link or  a manufacturer's name?
my 2cents,
iblisdrax
PostPosted: Sat Jun 04, 2005 3:39 pm
Painting pens? Excuse my ignorance, but what are they?
PostPosted: Sun Jun 05, 2005 12:13 am
Art pens are just something I discovered that you can use for models.  These look just like felt tip pens but once dry dont come off so easily.
They come in small sizes and I used one to draw on an epic banner.  It was much easier to do than using a paint brush.
As I have progressed with my painting skills I find that using a detailed brush wasnt good enough to get the result I wanted so I started looking for an easier way to dry very small patterns in small areas, on a 6mm mini.  For instance my painted DA vehicles require the insignia painted on the front and hatches.  On the marines themselves I wanted to paint the insignia on each shoulder pad and then the correct squad number or detachment type on the other shoulder pad.  I found that very thin paint brushes like the 0000 or 00000 were good for detail but I seemed to not have the right technique to hold the brush for very very fine detail. A pen on the other hand seemed to be more stable.
I asked the mini painting yahoo group and recieved the following link which you can see the pens for yourself
http://www.rexart.com/sakura_pigma_micron.html
I didnt find the white but this is a very good start since I only have black
Hope the explanation helps.... so if you know any other retailers that sell this stuff... let me know.... again thanks in advance.
I would show a pic of the banner I did which was simple in design but I am not allowed as yet..... as soon as I am told I will upload the pic straightaway
PostPosted: Sun Jun 05, 2005 4:00 pm
I am assuming you used the .20 mm black one?
my 2cents,
iblisdrax
PostPosted: Sun Jun 05, 2005 4:03 pm
Ah, thanks!
PostPosted: Sun Jun 05, 2005 7:11 pm
yep I did and that helped a lot...... now if only I could find white ???
