Players' Index Query at www.epic40k.co.uk
 Post subject: Players' Index Query at www.epic40k.co.uk
PostPosted: Thu Aug 07, 2003 10:39 pm
Has anyone registered with this?
I can't seem to find anyone when I make a search. ?
Just wondering...
I have a cunning plan...
PostPosted: Fri Aug 08, 2003 4:13 am
it does, I just found a local player... so now I'll finally have a chance to try out Epic!   :D
I did find the search function to be a little vague, so I would try VERY broad searches... like by country  :L   But, nonetheless, it worked!
pics of my minis
PostPosted: Fri Aug 08, 2003 1:29 pm
There are currently over 100 hundred people registered. But compared to the geographical area of the planet, that is quite small. My recommendation would be that you search for your country and find the area of players that way. Also, remember that in the UK, people could be UK, England, United Kingdom, Britain and USA could be USA, States, United States, etc.
This is also on my list of things to neaten up. Please bear with me!  :p
PostPosted: Fri Aug 08, 2003 4:08 pm
In the early days, I had an easy time using the Player's Index. Now I can't even find local players who I KNOW are in the index.
I used to type "California" (a state in the USA) and come up with nearby players, but, for some reason, that search now comes up with a big goose egg.
CyberShadow,
No worries. It's still nice to have the Index around!  :)
Shalom,
MAksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Aug 11, 2003 5:02 pm
Really, that is worrying!
I just did a search and found 10 players in California.
Are you searching the right fields (keywords, 'and' connector, all fields searched)?
If you are, drop me a PM or email and I will see if I can sort this out.
Thanks.
PostPosted: Mon Aug 11, 2003 6:00 pm
CS,
I tried again and came up witht he x10 entries. I guess that all that "and/or" stuff is really tricky.
- Here's another sugestion: Can you please make someway to edit an entry?
Mine has old information and I'd like to update it. (I input my entry before it was updated with E-A information.)
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Aug 11, 2003 7:56 pm
Well, this is my dumb question of the day...
...where IS the index?
PostPosted: Mon Aug 11, 2003 8:03 pm
Primarch,
http://www.epic40k.co.uk/
Look under the Player's Index at the top of the page.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Aug 11, 2003 10:17 pm
Thanks Maksim!
PostPosted: Wed Aug 13, 2003 7:11 pm
Quote (MaksimSmelchak @ 11 2003 Aug.,18:00)
Maksim:
Editing an entry means that I need a way of making sure that only you can edit your entry, which in turn means a whole set of passwords and such like, which I try to stay away from as much as possible.
In the end, I found that the easiest way is either to let me know what you want changed, or (even better) just create a second entry and then email me with the record number of the previous one, which I will just delete.
And primarch, there are no dumb questions, only dumb answers.
PostPosted: Thu Aug 14, 2003 1:47 am
Well..it was more bad memory, since I knew I had subscribed to it sometime ago (and judging by my number a REAL long time ago), I just couldn't remember exactly where it was.
Thanks for the help.
