Ork Traktor Cannons in SM2/TL against Titans
 Post subject: Ork Traktor Cannons in SM2/TL against Titans
PostPosted: Fri May 23, 2014 6:58 pm
Never really played these before and will be using them soon, and I am confused on the rules when using them against Titans, like a Warlord...
Basically roll to hit 5+ and void shields have no effect. If the target it is hit, it makes a save with a -1 modifier using its highest saving throw from anywhere in its areas, so in this case a +1, which means a save of 2+.
Then the Ork player rolls again, 1-5, whatever hit is immobilized, but a 6 is SQUASHED - Destroyed.
Typically things that destroy vehicles just cause hits to locations to Titans, like a Vortex missile, but there is nothing in the description to say something like that here. Granted, its a long shot for one player to roll a 5+, the other to roll a 1, and then the other to roll a 6, but if that happens, then it appears the Warlord is toast. And even if there were just a location damaged, there is no way of explaining how to pick out a location that is it.
So am I playing this right? A 20 point model can take out a 900 one in one shot? If thats the case I might be hitting the Trading Forum...
 Post subject: Re: Ork Traktor Cannons in SM2/TL against Titans
PostPosted: Fri May 23, 2014 8:46 pm
Wording is somewhat vague, but this is the deal.
You roll to scatter as normal, one a location is determined, it gets a save, but note the save is the highest save on the hit location template, not necessarily the one you've scattered on (usually a save of 1+ or 2+ on a titian). If it fails the save roll on the table, if a "6" is rolled then roll on the damage table for the location you hit. The damage roll is necessary, there is no "insta-destruction" from the traktor beam on a target with hit location template. Either you immobilize or get to roll on the damage chart.
PostPosted: Fri May 23, 2014 10:03 pm
Ah ok thanks. The rulebook could have just said that!
PostPosted: Fri May 23, 2014 10:17 pm
Things were not very well thought out in the original rulebooks and it wound up having some big loopholes like this one.
Users browsing this forum: Google [Bot] and 21 guests
