Firestorm Armada base size?
 Post subject: Firestorm Armada base size?
PostPosted: Sun Apr 17, 2011 1:29 am
Can anyone tell me the scale of this model set for Firestorm Armada? Is it usable for Epic?
Thanks!
 Post subject: Re: Firestorm Armada base size?
PostPosted: Sun Apr 17, 2011 2:30 am
i recall seeing a measurement for something on wau at one point, from memory its a bit small for epic use. i'll take a look and see if i can find it again, but dont hold your breath
PostPosted: Wed Apr 20, 2011 2:29 pm
I have this set, and sadly it is indeed too small for epic. It is useable none the less as "detailing gubbins" for some parts, which you can recycle as air recycling blocks on your building, or generators, or skydomes, etc...
The amount you receive is large, so i think it is still good value, but you certainly won't be able to use the parts as originally intended
Users browsing this forum: Google [Bot] and 21 guests
