Thunderfire proxies?
 Post subject: Thunderfire proxies?
PostPosted: Fri Dec 15, 2006 3:08 pm
Ok, maybe this topic should not be here, but i can't think about a better place for it: Is there anything usable as an squat thunderfire proxy? I say so because it seems almost impossible to buy one these days  :(
"It would be most ilogical if i let you kick my ass"
-Spork, son of Spoon son of Fork
PostPosted: Fri Dec 15, 2006 3:32 pm
Chaos Orc has some, but unfortunately his price is $20 US for two.  :(
PostPosted: Fri Dec 15, 2006 3:40 pm
I'd look for something in a 10mm or 15mm Flak tank and just use the turret.
If you could get some of the Mark I Basilisks, it might look OK to mount 2 turrets together to make a proxy.
Of course it might be interesting to build some of these yourself out of  rod & card.  I found some small aluminum tubing at a hobby shop.  One size slides neatly into the next size up and would make some great gun barrels.
Understand this: that skag and his floozy...they're gonna die
PostPosted: Sat Dec 16, 2006 1:25 am
I reckon the Forgeworld Earthshaker with a couple of extra barrels added would be pretty good, and I wouldn't have a problem with people using the FW Hydra Platform either.
Fire bad, tree pretty - Buffy
PostPosted: Sat Dec 16, 2006 3:55 am
Yes, Con, is correct ... a 10 or 15mm Flak Gun(s) is more to scale.  GHQ, though very nice, is just too small ...
PostPosted: Sun Dec 17, 2006 1:55 pm
Not sure how big the guns need to be but several CAVs have gatling style weapons.  You can order just the parts for most CAVs, clip the weapons off the arm and dress it up a little bit.  Although, if you're outside the US shipping cost may outweigh the benefits.  Here's a couple examples of models I own
Starhawk V Dimensions 29mm x 5mm x 4mm
Starhawk VI Here's a pic of one Dimensions 32mm x 8mm x 7mm
Wraith(This one might be more difficult to use) Barrel length is 15mm and is 5mm in diameter.
My Photobucket: http://s21.photobucket.com/albums/b285/Sergeant_Crunch/
My blog
PostPosted: Wed Dec 20, 2006 9:39 am
Squat Thunderfire? Are these the sinle big cannon pointing up into the air?
I don't really like squats that much and I think I have one or two lying around somewhere.
PostPosted: Wed Dec 20, 2006 3:24 pm
No, the Thunderfire has a total of three barrels. You're thinking of the Goliath, a super-heavy howitzer.
PostPosted: Wed Dec 20, 2006 5:50 pm
I'm sure if you don't want that Goliath, one of the Boyz here will take it off your hands !  :)
PostPosted: Wed Dec 20, 2006 5:51 pm
That's a safe bet!  :D
