A Bridge Too Few - Epic Bridge Miniatures.
 Post subject: A Bridge Too Few - Epic Bridge Miniatures.
PostPosted: Fri Feb 18, 2005 11:57 pm
Hi,
Have been looking around the web for a while now for bridges suitable for Epic, but with very little luck. FW do a few for Warmaster which are ok in size, but not exactly futuristic/industrial in looks. I've also seen a few railway bridges that are passable, but they are never wide enough to be a nice objective to fight over (generally you could just about fit a stand on them).
Does anyone know of any readily available bridges suitable for Epic? Preferably long enough to span approx 3 inches and quite wide. (It isn't important if the scale is slightly out, ie: 10/15mm)
And before anyone suggests making one myself, my large scale model-making sucks, so I've ruled that out. (Unless someone can write a quick tutorial.)
Freshmetal
(ooh! 200th post! Yay!)
Blastmarker.com
PostPosted: Sat Feb 19, 2005 12:00 am
I use railway bridges. However I don't use the "floor part but make a new one from wood/card polystyrene (depending on what's at hand) and then simply glue the sides onto that. I usually find that something about the width of a Titan base looks good.
Cheers! :)
PostPosted: Sat Feb 19, 2005 1:40 am
I have one of these, not assembled all the way yet.  I have put together the sides of the bridge, and debating whether to paint the sides before adding the deck (It doesnt come with a deck, so you can make one as wide as you need...cardstock will work)  I also have the Russian Orthodox Church piece and the Mosque, both of which are at the primer stage.
Anyhow, here is the link:
3 arch stone bridge
If I ever get mine finished I will post a pic.
:O
my 2cents,
iblisdrax
PostPosted: Sat Feb 19, 2005 4:36 am
N or Z-scale RR bridges work great!
Shabbat Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Sat Feb 19, 2005 11:26 am
Hi Freshmetal,
The Void Armoured Bridge, by I-Kore, is excellent, made of resin, and quite cheap. The textured metal plates for foot grips are out of scale, but you can always say they're there for the Titans, as L-4 pointed out. I MUST build this and take pics!
EDIT found a couple of pics here.
Don't stop at the first bridge picture - there's a better one, with troops crossing, further down. Another pic here.
Back from oblivion (again)?
PostPosted: Sat Feb 19, 2005 12:12 pm
I'd reccommend the Urban Mammoth (ex-i-kore) Urban war range of plastic scenics. One of the small kits should provide enough parts to make a number of tech-like bridges & a few other things as well!
I cant seem to find it on the Urban Mammoth site itself, but the stuff's always for sale on ebay:
Platformer Terrain - small set
Paul "TuffSkull" T.
PostPosted: Sat Feb 19, 2005 1:46 pm
Hi,
Thanks for the replies, I'll have a look at all of those today. I'm going to have to try to minimise the number of orders I place for stuff, so I'll have to figure out everything else I want to get before I decide which to go with. I'll probably look at RR bridges first so I can use it for other games though.
Freshmetal
Blastmarker.com
PostPosted: Sat Feb 19, 2005 4:32 pm
We use a number of different models of bridges including some I made from plastic card and bitz. If the model is too wide, it can't cross ... a simple but useful rule ! :;):
PostPosted: Sat Feb 19, 2005 9:13 pm
Most microarmour bridges are too small.
Try a company called Gallia though.
Shabbat Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Feb 21, 2005 1:18 am
Do JR miniatures sell bridges?
PostPosted: Mon Feb 21, 2005 2:42 am
Hi Serps,
Yes, JR Minis does have a few bridges as do most microarmor scenery manufacturers.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Feb 21, 2005 10:38 am
Its quite pricey (and I havent actually seen it), but the big bridge Timecast do looks pretty impressive in pictures:
http://www.timecastmodels.co.uk/range_16/range_16.html
Reaversbane (or RB for short...)
PostPosted: Tue Feb 22, 2005 6:10 pm
If you can find them...and that is a very large if... there was a line of resin bridges put out in the early/mid-90s for Steve Jackson's Ogre by a company called Detailed Casting Products.
The bridges are scifi and the larger of the two is scaled to drive an Ogre across, which would translate out to superheavy vehicle/war engine for sure.
The Cheese! The Cheese!
PostPosted: Tue Feb 22, 2005 9:19 pm
Hi,
Ordered one of the Timecast bridges, without the supports. Shall post a size pic when it arrives.
Freshmetal
Blastmarker.com
PostPosted: Wed Feb 23, 2005 5:30 am
I have those DCP brigdes in my collection. ?Nice pieces, but I think they are out of business ... :)  I also have a few of their CP Bunkers and Orbital Defense Turrets, all great for Epic terrain !   :;):
