Void terrain pieces
 Post subject: Void terrain pieces
PostPosted: Fri Jan 28, 2005 10:07 pm
Hi all,
collected the White Dwarf this morning, and gave a longing look at the last four boxes of Void models in store - and finally gavein, getting no. 31909, an armoured bridge. This includes two resin ramps and a span, wide enough for square-based troops to cross two-abreast. I'll take a couple of pics tomorrow. Very ood for Epic, if you are not finicky about the diamond pattern anti-slip steel plates which are obviously out of proportion for epic (the model is intended for 25 (or 28)mm models). I might be tempted to check out a box of craters, too. Quite well priced too.  :D
Back from oblivion (again)?
PostPosted: Fri Jan 28, 2005 11:34 pm
Oooh, VOID :), quality game system.
Tom Webb
PostPosted: Sat Jan 29, 2005 1:16 am
Cool stuff Vanvlak... I've got a similar sort of bridge (though its probably micro machnes or something similar- it was originally going to be my entry into the terrain bit of the painting comp, but I didn't have time to do it!
Recently I've been musing on how to get rid of the tread pattern though, so maybe you'll see more in a month or so! :;):
www.darkrealmminiatures.com
PostPosted: Sat Jan 29, 2005 4:41 am
Sounds cool - now you cvan play "A Bridge too far" epic style!
For the tread pattern try
a) lightly rubbing over the pattern with a dremel or file.  This will levae a rough and unveen surface
b) accept that it has been upgraded with Titan anti-slip treatment! :D
Looking forward to pics! :;):
Tas
PostPosted: Sat Jan 29, 2005 12:28 pm
Quote (Tas @ 29 2005 Jan.,04:41)
a) lightly rubbing over the pattern with a dremel or file. ?This will levae a rough and unveen surface
(a) is a good idea, but for me (b) sounds brilliant!  :D
cheers, Tas - pics should come along with my tale of 6 gamers squat pics.
