Identify the bits
 Post subject: Identify the bits
PostPosted: Fri Apr 15, 2005 11:38 am
Hi all
have a few bits that need identifying, I believe most are MoW bits, possibly Chaos. If that is the case are you interested Mojarn? or any others.
Anyhoo, heres the pic:
PostPosted: Fri Apr 15, 2005 11:56 am
One of the bitz is definitely from the Tower of Skulls Daemon Engine. The one in the upper left corner looks a bit like some kind of a prow bit I'm not sure. The rest... Well Anybody?
Cheers!  :)
PostPosted: Fri Apr 15, 2005 12:12 pm
The bit to the left is a plagueship  (I will probably be corrected on the name) of Nurgle, a ship of the line; the semicircular bits are paddlewheels from the Plaguecrusher Man o war ( I think); the dome above them comes from the Slaaneshi Man o War - forgot the name too, the hellship? - will check at home, unless Admiral Piett or others intervene before.  No idea of the others. And, Justiniel - I call dibs! Want!
Back from oblivion (again)?
PostPosted: Fri Apr 15, 2005 12:53 pm
The upper right one is ftom tower of skulls all right.
Vanvlak is right about the other bits; the one that looks like a mini-plaguetower is from Plaguecrusher while the dome is from Hellship. The paddle wheels are either from a plaguecrusher or plague galleon (both have the sema kind of paddle wheels). The skull is, I'd guess, from a MOW Khorne deathgalley while the ritghtmost one of the two cylinderical bits _looks_ like an Ogryn-sized frag grenade from Rogue Trader days.
PostPosted: Fri Apr 15, 2005 3:05 pm
I agree with my "learned cohorts" ! :;):
PostPosted: Fri Apr 15, 2005 10:53 pm
As mentioned, one is a epic demon engine piece the others are MOW pieces.
PostPosted: Tue Apr 19, 2005 9:22 am
Thanks guys, I was originally use them as bitz but then I thought with MoW bits so rare I'd better offer them rather than cut them up (the horror) so they are joining the Maltese Fleets. The grenades really puzzled me, they seem to be action man size, ogryn you say, big even for those I would have thought, still they would make good fuel tanks. So thanks again, cheers.
