.Mk3 Falcon
 Post subject: .Mk3 Falcon
PostPosted: Sun Feb 08, 2004 8:34 pm
I've tried to cut up an old plastic Falcon and put it back together to look more like the new metal version.
The result can be seen here.
I'm not sure about the look though... I think something is missing from the middlesection but I don't know how to model it. Above all it has to be easy to do as i have 24 of these to be converted. :p
Cheers!
PostPosted: Sun Feb 08, 2004 8:46 pm
Is the link active?
PostPosted: Sun Feb 08, 2004 11:47 pm
:oo  ...The link does seem to work Primarch...
Hmmm... well, I'm not sure how you could improve the look of the model W/M... I agree it is lacking a 'certain something' right now- perhaps you could use a little greenstuff to smooth round those square corners...?  ???
www.darkrealmminiatures.com
PostPosted: Mon Feb 09, 2004 12:35 am
I can see the pics now.
Too bad the archive was shut down. I can remember several good bits to place in the center of the models divide that would look very cool.
PostPosted: Mon Feb 09, 2004 7:39 am
Quote (stormseer @ 08 2004 Feb.,23:47)
- perhaps you could use a little greenstuff to smooth round those square corners...? ????
Agreed with Stormseer re green-rounding. Good idea, the slit, though. For the middle - how about a couple of  probes sticking forward - asymetrically, I'd say. Just use a bit of paperclip or stiff wire (dried flower arrangement wire, I discovered, is great).
Back from oblivion (again)?
PostPosted: Mon Feb 09, 2004 12:31 pm
AAARRGH!!! I just realized that the cut up falcon kind of looks a bit like the new FW Hell Talon fighter!!! My Eldar is infested by Chaos! ...The Inquisition is not gonna like this...
Anyway: Thanks for the input guys. I guess I just need to get to work with the green stuff then... Or maybe I should just leave the Falcons as they are...
Cheers!
PostPosted: Mon Feb 09, 2004 1:29 pm
Quote (Warmaster Nice @ 09 2004 Feb.,12:31)
Cheers!
Or add wings and call them Firewings  :L
