Page 1 of 1
[ 8 posts ] |
Painting White |
Mojarn Piett
Post subject: Painting White Posted: Fri Aug 15, 2003 7:46 am |
| Brood Brother |
Joined: Fri Feb 14, 2003 7:35 am Posts: 5455 Location: Finland
How do you manage to paint a smooth and even coat of white?
With a brush there always seems to be brush marks visible, no matter how many coats I paint.
With a spray can, there are no brush strokes but the surface looks like it had been repeatedly stabbed with a needle.
Should I add detergent to remove surface tension?
Use thinner paint?
Use a different kind of brush?
_________________ I don't know and I let who care. -J.S.
| Top |
TuffSkull
Post subject: Painting White Posted: Fri Aug 15, 2003 11:09 am |
| Brood Brother |
Joined: Tue Feb 25, 2003 11:49 am Posts: 2830 Location: South East UK
The only way to get a really good clean coat is to use many layers of thin paint.
Make sure you let each layer dry before applying a second or else you will ruin the lower layer and end up with ridges.
Its tedious, but if you must paint white...
_________________ Cheers, Paul "TuffSkull" T. http://hobbybrush.com - My New Website, with thousands of painted Mini Pics :) http://hobbybrush.blogspot.com - My Hobby Blog TuffSkull's notepad- My Old Blog on Wargames Wiki.
| Top |
MaksimSmelchak
Post subject: Painting White Posted: Fri Aug 15, 2003 2:54 pm |
| Brood Brother |
Joined: Sun Feb 16, 2003 4:43 pm Posts: 7258 Location: Sacramento, California, USA
White is one of the hardest colours to get to come out well especially if you're trying to paint it over a black primer.
The only way to do it in my experience is to keep layering white until it comes out smoothly.
Godd luck!
Shalom, Maksim-Smelchak.
| Top |
Jimbo
Post subject: Painting White Posted: Fri Aug 15, 2003 9:30 pm |
| Brood Brother |
Joined: Fri Feb 14, 2003 11:01 pm Posts: 3495 Location: Wessex
| Top |
Legion 4
Post subject: Painting White Posted: Sat Aug 16, 2003 6:07 am |
| Brood Brother |
Joined: Thu Feb 13, 2003 5:13 pm Posts: 37005 Location: Ohio - USA
I never base coat white, I spray black, gray, etc., and touch up afterwords with a watered down version of the sprayed color ...
_________________ Legion 4 "Cry Havoc, and let slip the Dogs of War !" ... "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
| Top |
Markconz
Post subject: Painting White Posted: Sat Aug 16, 2003 7:18 am |
| Purestrain |
Joined: Mon Jul 28, 2003 10:43 pm Posts: 7925 Location: New Zealand
Using a light coloured base coat before you do the white helps.
E.G. I undercoat almost everything black...
Areas which I want to be white, I first paint with Space Wolves grey, bleached bone etc...
That way I only need to do two or three coats of white over the top and still get a smooth finish.
Leaving some of that base coat showing through in recesses provides shading to the white as well.
| Top |
Mojarn Piett
Post subject: Painting White Posted: Mon Aug 18, 2003 7:30 am |
| Brood Brother |
Thanks for tips everybody!
Now I have some hope that the shoulder pads of my Black Templars may actually even improve someday...
| Top |
Shadow Hunter
Post subject: Painting White Posted: Tue Aug 19, 2003 8:48 am |
| Brood Brother |
Joined: Fri Jan 17, 2003 11:41 am Posts: 1747 Location: Norton Canes, Cannock, Staffs, UK
If I have used a black undercoat (which I usually do as it seems better), then to paint white I always do a couple of layers of thin space wolves grey. It seems to go on very well, covering the black paint. I will then go straight to white, or maybe add bleached bone first.
| Top |
Page 1 of 1
[ 8 posts ] |
