Sleipner Class Escort Carrier WIP
 Post subject: Sleipner Class Escort Carrier WIP
PostPosted: Fri Sep 10, 2004 12:09 pm
I was just fidddeling through my bits box when I noticed a disproportionate ammount of spare Imperial Launch Bays. What to do, what to do...
An hour of so later this little ship emerged from the docks. It's a dedicated carrier Light Cruiser consisting of 6 Launch bays and a single turret for defensive purposes. It's primary duty will be to escort Merchant vessels but in times of need it may be pressed into service as a strike carrier inthe Imperial Navy.
The model still needs a prow. I was thinking of doing one similar to the Defence Monitor.
Cheers!
PostPosted: Fri Sep 10, 2004 1:54 pm
Oooh.. I like it WM... methinks I'll have a go at building my own take on it sometime. :)
www.darkrealmminiatures.com
PostPosted: Fri Sep 10, 2004 4:38 pm
Like I said, I don't play BFG, but you are doing some nice stuff there, W/N ! :;):
PostPosted: Sun Sep 12, 2004 12:27 pm
Here's a quick pic of the finished Escort Carrier ready for a coat of paint.
Cheers! :)
PostPosted: Sun Sep 12, 2004 12:32 pm
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
Nice model indeed! I like the model. The problem is that from a gaming balance POV it will never be accepted since it provides the IN with a cheap and massive carrier, but hey, as if that mattered! :D Kudos to you for a very good mocel man :cool:
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Sun Sep 12, 2004 7:48 pm
Cool model.
What have you used for the engines?
Do you scratch build the prow or have you used something else?
I have a cunning plan...
PostPosted: Fri Sep 17, 2004 5:56 pm
I used the prow from the Defence Monitor. For the engines I used 3 plastic beads and two treads from a tank kit. (I use a lot od these as they are a great way of adding a mechanical texture to something. I also stuck on some kind of a gn... Possibly part of the defence turrets from a Warmonger Titan though I can't really remember...
Cheers!:)
