ORKish Trukks from DZC !
 Post subject: ORKish Trukks from DZC !
PostPosted: Mon Sep 02, 2013 10:55 pm
Scroll down & Check out these Ork-style Trucks from DZC. Even though they are 10mm, these would work fine with Epic/6mm ... Da Bee BIG Trukkz !!! http://cdn.shopify.com/s/files/1/0159/4 ... 3.pdf?1476 ImageImageImageImageImage
 Post subject: Re: ORKish Trukks from DZC !
PostPosted: Tue Sep 03, 2013 12:22 am
mmm...not just for orks but even better for LatD
PostPosted: Tue Sep 03, 2013 4:52 am
And should be good for the Genestealer Cult list as well. Anyone old enough for Rogue Trader days should remember the old limos from the studio army! :D
PostPosted: Tue Sep 03, 2013 3:24 pm
Yeap ... could work for those as well ... 8)
PostPosted: Tue Sep 03, 2013 3:25 pm
Really like the look of the smaller type. Look good for both LATD and genestealer cult as mentioned.
PostPosted: Thu Sep 05, 2013 11:56 am
Are those 6mm scale?
PostPosted: Thu Sep 05, 2013 12:08 pm
Dropzone Commander is officially 10mm.
Some of the stuff still works though (o:
Let there be code.
PostPosted: Thu Sep 05, 2013 4:18 pm
Yes, as I noted in my first post these are 10mm, but like most 10mm, based on the piece it will work for Epic 6mm. Also, as I've see previously 1/285/6mm like GHQ, save for some of the bigger models like the E-100 or Maus, most are too small. And the E-100, Maus etc., as closer to an MBT in Epic scale not HeavyBT ... And I've got some 10mm (MiniFigs ?) armored cars, A7Vs and a few others and they really work fine for Epic scale. Which with the inevitable scale creep, many of the newer Epic Infantry models are closer to 7-8mm ... Image
PostPosted: Thu Sep 05, 2013 11:43 pm
Pretty sure those are Minifigs ...
