Ork Hulk WIP
 Post subject: Ork Hulk WIP
PostPosted: Wed Oct 01, 2008 4:47 am
My Ork fleet is still MIB but I got a wild hair and decided to start work on the Hulk.  I started to work cutting away with my foam cutter and some blue insulation board.  But here is my question; what is your idea of a good size for a hulk?  I'm thinking I may cut down the size some...
PostPosted: Wed Oct 01, 2008 2:50 pm
Bigs good.  This is mine, seems to work ok size wise for games.
PostPosted: Thu Oct 02, 2008 4:22 am
That looks good, just didn't want anyone to say my Hulk was compensating!  :no:
PostPosted: Thu Oct 02, 2008 4:08 pm
Dont worry bout that! Mine certainly over conpensating for something :sus:
More importantly... it shows you dont have to follow the old design of a random jumble of wreakz fused together in an asteroid. You can have the asteroid purposly built into a ship.
Nuf Said.
PostPosted: Thu Oct 02, 2008 11:05 pm
now that is a thing of beauty...
My shifting projects
PostPosted: Thu Oct 02, 2008 11:12 pm
Exactly along what I was planning!
PostPosted: Fri Oct 03, 2008 5:05 am
I got some more work done on the Hulk tonight.  The hull is finished be cut and I stuck a mass of bitz on it.  It is bigger than what I previously stated too: the main body is a bit over 11", with some attachments it is over 12".  I also glued the base (CDROM and 1.5" plastic plumbing pipe) to the hulk.
Next I will add some texture to it and then shoot it with some primer.  Might have a sneak peak up in the "what are you working on" thread this weekend.
PostPosted: Fri Oct 03, 2008 12:20 pm
Hmmm... Id have to say even I would concider that a bit oversized.
My Hulk is 7" long... and its pretty massive even by Hulk standards but the extra bulk is mostly made up in hight, not width or length.
A 12" long Hulk is ruffly twice the size of an average one.
I too based mine on a CD. I used that to determin the size of the Hulk.
Having your Hulk on a base which size relates to the size of the Hulk itself helps alot game wize.
A 12" long Hulk on a base thats overall area is only about a quarter of that of the Hulk does become a problem as then you have to measure from the Hulk and not the base to avoid being labeled a cheezemonger :;):
This overhead view of my hulk shows how big it is in relation to the base. Ive had to draw it in as the prospective of the shot gives a false impression of the base size.
Nuf Said.
PostPosted: Sun Oct 05, 2008 5:02 am
More picks in WIP thread:
PostPosted: Sun Oct 05, 2008 9:50 am
Now thats big! :oops:
Nuf Said.
