Post new topic Reply to topic  [ 119 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
Epic to 40K?
 Post subject: Epic to 40K?
PostPosted: Wed Feb 18, 2004 9:19 pm
Yep.  I spray with an enamel.  I don't have an airbrush and testors is cheap.  In my early days, I even used a flat enamel as a primer on plastics.
I've never had a problem with enamels obscuring detail, even when I felt like I had put too much on.
PostPosted: Wed Feb 18, 2004 9:22 pm
I'm a big fan of spray painting. While mostly everything I have painted in my life for epic was done the "hard way" by painting by hand. Once I tried spray painting, at least for the major color the model has, I'd never paint entirely by hand again.
PostPosted: Wed Feb 18, 2004 11:08 pm
I must admit I always go for the easiest painting methords.
All my Epic Orks are painted simply buy spraying black, drybrushing Boltgun-Metal and then added details.
When I first started painting I too did it the hard way, those nitemareish memories of undercoating with a brush seem very distant now.
I find that matt enamel paints are realy good for base coating, Ive always used them both in brush and spray form for this job. They leave a nice flat finish with a slight texture that acrilics realy cling to.
Ive never owned an airbrush either... always seemed far too expencive to me.
Nuf Said.
PostPosted: Thu Feb 19, 2004 1:27 am
Spray Painting all the way, baby!   Spray undercoat, leave for a while, come back and spray base coat, leave overnight, and you are ready to detail!  Wouldn't do it any other way!
my .02,
iblisdrax
Spray black - it's the only way to go  :)
For yellow a undercoat of white or bleached bone can form a good base... alternatively bubonic brown (very yellow in colour) can be used as a base coat, or even the yellow itself if you don't want a bright yellow.
PostPosted: Thu Feb 19, 2004 6:02 am
Yes ... black spray paint is usually how I start out most of my models.
PostPosted: Thu Feb 19, 2004 8:58 pm
Added some extra plating to the hull sides giving the model a more Orky look.
Also made a driver for it.
I discided I didnt want the usual style of "Ork shouting and waving gun madly"
So Ive spent some time converting my Ork to look far more chilled out :cool: ...hand on chin, smoking a cigar.... or maybe something stronger judging by his layed back pose ?:;):
Pics arent that clear but Ill post better ones when hes painted, which I plan to do soon as Ive not painted anything for weeks.
http://briefcase.yahoo.com/bc/kr00zza
Nuf Said.
PostPosted: Thu Feb 19, 2004 9:51 pm
Kr00za, the picture taking machine!  :D
Thanks for making my forum visits fun!
PostPosted: Thu Feb 19, 2004 11:34 pm
Awesome!  That ork driver is cool, man.
my 2cents,
iblisdrax
PostPosted: Fri Feb 20, 2004 12:58 am
Great work krooza, amazing!
PostPosted: Fri Feb 20, 2004 10:15 am
LOL! Love the tank driver. Who cares what GW says; Have that thing recast and I'll sure buy a couple! Excellent work. :)
Cheers!
PostPosted: Sat Feb 21, 2004 3:22 pm
Started painting my driver... so the pics are a lot clearer now.
This model was customized by cutting the legs off and reworking the arms "plastic ones" into the new position. Also re-defined the fingers as they were pretty poor. Then made the two V stripes to indicate the rank of Korpral.
I plan to put a number of manic Grots on this BattleWagon. I think their hyper-active poses wll contrast well with my laid-back Ork.
Nuf Said.
PostPosted: Sun Feb 22, 2004 10:55 pm
Wow.. this model just gets better and better Kr00za.... the final model will be stunning I can tel!  :;):
www.darkrealmminiatures.com
PostPosted: Mon Feb 23, 2004 10:32 am
Painted up my first Grot. Ive also started to make some platforms so Im able to sit some ork gunnaz on the battlewagon. They're big anuf to house one ork each, or two if I slightly modify the bases of the orks.
Ok I admit it... there was pretty much no point at all using a Leman Russ coz hardly any of the origanal model showing. Mind u that said, Ive used most of the origanal model in this conversion and not having to scratch build the bit that lets the turret rotate has saved me alot of time n effort.
Nuf Said.
PostPosted: Mon Feb 23, 2004 3:49 pm
Yet again, my jaw drops.  You da ORK!!!!
:D  :D  :D
my 2cents,
iblisdrax
