Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Storm's course models!
 Post subject: Storm's course models!
PostPosted: Fri Nov 04, 2005 3:23 pm
It's going to look great when it's done, Stormy.  :8):
PostPosted: Tue Nov 08, 2005 9:40 pm
Here is what I have after today and yesterday's work- the two halves, both shaped and beautifully smooth (I spent at least 4 hours hand sanding today  :8: ), almost ready to be formed!
www.darkrealmminiatures.com
PostPosted: Tue Nov 08, 2005 9:45 pm
The photos don't show the time that has gone into these chunks of wood sadly- trust me when I say that getting something curved and perfectly smooth is no easy task!
This photo shows the end blocks I've made up. which will allow a trouble free vac form (without them, the pointed tips would probably have pierced the plastic...).
Leaning up on the left, you can see the sheets of plastic which I'll be using tommorow. I've decided to polish up the wood sections and then rub them with beeswax to bring out the grain and give them a lovely smooth glossy finish- these will be left inside the formings, showing through the clear plastic exterior, which should look pretty cool, and will make the model look more solid.  :8):
Deadline is Friday, so got a few more long days to go!
PostPosted: Tue Nov 08, 2005 9:50 pm
At least 4 hours of hand sanding? Holy cow. Too bad you couldn't use a power sander.
Looking good, Stormy. I'm sure the end product won't disappoint.  :cool:
PostPosted: Tue Nov 08, 2005 9:55 pm
Yeah, I did actually use a disc sander and a bench belt sander for taking off lots of material to start with, but the downside with them is that it is virtually impossible to get a clean, smooth finish- especially on a shape like this with all it's weird curves- thus the hand sanding to get the finished shape! :D
PostPosted: Wed Nov 09, 2005 1:26 am
Man, this seems to be a lot of hard work!
I'm sweating just reading it!
PostPosted: Wed Nov 09, 2005 7:17 am
Wow - do you use finer grades as you get closer to finishing? We have a similar formof torture called specimen preparation, starting with 200 grit and moving to 400, 800, 1200, 2400 and then 1micron polishing paste... :( :)
Back from oblivion (again)?
PostPosted: Wed Nov 09, 2005 7:51 am
Suddenly being a code slave doesn't feel so bad... :alien:
PostPosted: Wed Nov 09, 2005 11:49 am
Quote (vanvlak @ 09 Nov. 2005 (06:17))
Yes V...
I used 180 grit to do the hard work removing all the lumps and bumps and rounding it properly, then 240 for further finer smoothing, then 400, then 600 up to 800 for the final finishing...  :;):
PostPosted: Wed Nov 09, 2005 12:12 pm
Quote (stormseer @ 09 Nov. 2005 (11:49))
Yes V...
I used 180 grit to do the hard work removing all the lumps and bumps and rounding it properly, then 240 for further finer smoothing, then 400, then 600 up to 800 for the final finishing... ?:;):
Oww, at least ours are just flat surfaces....
cheers, and keep it up with the old elbow grease.
:D  :alien:
PostPosted: Wed Nov 09, 2005 12:22 pm
The joys of woodwork :laugh: it's starting to look good Stormy, hopefully the marks will be payback for the amount of work involved.
Apart from a scale version of hip and valley roof timbers (no real need to finish as they are usually pretty rough anyway :D) I've never modelled in wood, only card or polystyrene.
Can't wait to see how this progresses.
PostPosted: Wed Nov 09, 2005 8:19 pm
Just back in from the workshop: two vacformings are finished! :D
One isn't quite right, but I should be able to bend it back a little to get it perfect...
The plan tommorow is:
1). Get the plastic formings cut out, reshaped and sanded.
2). Paint base board,
3). Varnish exposed wood sections,
4). Sandblast stripes into clear sections
5). Cut tops and rear from acrylic
6). Scribe curved parts
7). Final polish and sanding of parts
8). Assembly and detailing!
Wish me luck.... :p
PostPosted: Wed Nov 09, 2005 8:37 pm
Quote (stormseer @ 09 Nov. 2005 (19:19))
Wish me luck.... :p
Good luck!  :cool:
PostPosted: Fri Nov 11, 2005 1:06 am
Midnight.... LOADS if work done so far, but it isn't finished yet!
Did a 12hour day in the workshop and completed mostof the above steps, but theres still a lot to do..
Pictures tommorow (dependant on how dead on my feet I am! :;): ).
Cheers, ~G
PostPosted: Fri Nov 11, 2005 7:58 am
Wow, Stormy, they're keeping you busy! I did a good job bribing my colleagues at your Uni to keep you out of the Epicomp this year... :p :p :p :laugh:
