Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Working on CONQUEST terrain this weekend...
 Post subject: Working on CONQUEST terrain this weekend...
PostPosted: Thu Sep 02, 2004 8:17 pm
Amazing what you can achieve whhen you really put your mind to it. Looking forward to the pics Maksim. :)
Cheers! :)
PostPosted: Thu Sep 02, 2004 10:48 pm
I just finished carving some hills out of foam.
I never realized that making hills was so much work!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Thu Sep 02, 2004 11:54 pm
I prefer making hills from paper mache or plaster , making them all at once, then painting them over time.  I hate carving rounded shapes out of foam.
my 2cents,
iblisdrax
PostPosted: Fri Sep 03, 2004 6:11 am
I finished painting the hills and everything is ready for CONQUEST except a few army lists that I want to tweak with a little.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri Sep 03, 2004 11:25 pm
Good luck and always remember the EpiComms warcry
pictures...
pictures...
pictures...
:D
PostPosted: Sat Sep 04, 2004 12:11 am
I found hill building from foam not too difficult, or that time consuming... just extremely messy! To make mine I've been carving chunks of blue foam into the rough shapes, then sanding them into natural curves- a dust mask is required if you don't want to be sneezing all day!
Guess I should invest in a hot wire cutter, but alas, current finances do not allow it... :(
www.darkrealmminiatures.com
PostPosted: Sat Sep 04, 2004 12:19 am
My digital camera appears to be down... so there will probably be no pictures, guys. Sorry.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Sat Sep 04, 2004 4:26 am
Isn't that why they make disposible cameras... :D
PostPosted: Sat Sep 04, 2004 5:14 am
No pictures?!
I'm crushed.... :(
My labor day weekend is ruined...! :D :p
PostPosted: Sun Sep 05, 2004 1:37 am
My hot wire cutter works pretty good on small to medium sized pieces, just not with really large bits of styrofoam.  I'd like to have a hot knife, but they are like $70.
btw, how expensive are hot wire cutters over there?   I only paid $8 for mine here in the USA.
my 2cents,
iblisdrax
PostPosted: Sun Sep 05, 2004 1:44 am
Hot Wire Foam Company
Hey Iblisdrax,
Chck out the above link.  Their stuff is very good and at a good price.  Take Care
PostPosted: Sun Sep 05, 2004 1:47 am
ooooo.....those are better prices!  Thanks for the link!
my 2cents,
iblisdrax
PostPosted: Sun Sep 05, 2004 1:57 am
I actually bought one of those years ago...
... never used it....
PostPosted: Sun Sep 05, 2004 4:16 am
The knife is the most useful. ?The wire on the stick. ?It allows you to cut through large pieces of foam. I made this with the tools.
PostPosted: Sun Sep 05, 2004 5:08 am
The 'hot wire' cutting system is the best for foam in my experience.  Use of sandpaper to refine the more gentle edges makes it more rigid.  I then paint it, cover with clear estapol and add flock while its still wet.  Once fully dry (2 days later) I then add another layer of estpol.  The end result is VERY tough, waterproof, light and durable.  I have spilled coffe, beer and other stuff on them and they are back in play in seconds after a quick drain with no damage.
For a cheap hot wire wcutter, use your car jumper leads, the car battery and some thin wire.  Works a treat!
Tas
