Blitzkrieg Commander II
 Post subject: Blitzkrieg Commander II
PostPosted: Wed Dec 16, 2009 9:44 am
If you pre-order you get £2.50 off.
http://www.specialist-military-publishi ... ...II.aspx
Some of the changes
The attacks have been split into two: AT and AP (this has simplified the rules and is more historically accurate)
Artillery support units have been added to the army lists (they are on-table versions of off-table artillery)
The limits in the army lists now reflect Battalion (Max per 1000) and Regimental level (Max per Battlegroup) allocations
Removed the Min limit from the army lists
Removed the rule for howitzers
Revised the way in which British artillery plays in the game
Added Weapon Pits, AFV Pits and Command Posts to field defences
Added save values to buildings, fortifications and certain field defences
All the unit stats have been revised
Lots of new units have been added, including different types of infantry
Added a new list covering Slovakia
Split the Hungarian army list into two
Merged two of the Italian army lists
