Bretonnian mounted Squires alternative miniatures?
 Post subject: Bretonnian mounted Squires alternative miniatures?
PostPosted: Mon Mar 09, 2015 8:52 am
I need 6 mounted Bretonnian Squires (Yeomen). But eBay is too expensive for the GW ones. Is there another brand that has good proxies?
Epic 40,000: Exodites, Necrons, Dark Eldar, Sisters of Battle, Tau
BLOG: Epic 40,000
BLOG: Warmaster
Toco's Mod: Allied HeroQuest
 Post subject: Re: Bretonnian mounted Squires alternative miniatures?
PostPosted: Mon Mar 09, 2015 10:56 am
I'm assuming you mean at 38mm?
The best Brett alt range I've seen is fire-forge games.
There are mounted Men at Arms: http://www.fireforge-games.com/webstore ... gory_id=13
And mounted Seargant at Arms: http://www.fireforge-games.com/index.ph ... &Itemid=95
There is also some good brett stuff in mantic's Basilean range, depending on whether you're willing to adjust the theme a little to include ridden panthers and female fighters, with angels replacing pegasus riders:
http://www.manticgames.com/mantic-shop/ ... silea.html
PostPosted: Mon Mar 09, 2015 11:02 am
35mm indeed. Those mounted sergeants are great! thanks
i am building a 35mm army but will be using warmaster rules
BLOG: Epic 40,000
BLOG: Warmaster
PostPosted: Fri Mar 13, 2015 1:18 am
OOps. I think those are 28mm, not 38 mm. I think I just typed it wrong. Do check before you buy.
cron
