Dungeon Bowl
 Post subject: Dungeon Bowl
PostPosted: Sun Jul 12, 2009 4:17 pm
I recently picked up some dungeon pieces in the interest of playing Dungeon Bowl.  The pieces look good enough and the price was fair, but the scale is closer to 25mm than 28mm.  But I guess it should work.
Grimtoe's Brawlers still a WIP  :sulk:
PostPosted: Sun Jul 12, 2009 10:43 pm
From experience, you should go with bigger square areas (like the one on the right of the pic).
The setup you have there mean that Agility teams are going to get squashed by Strength teams as there is nowhere to go.
We just finished the Dungeon bowl a couple of months ago where the finals were held in the dungeons. Even with more open areas, the Khemri team destroyed all the other Agility teams.
Also with the doorways being only 1 square across, that is going to provide huge problems. The older edition had doorways as 2 deep (only a big guy under the 2nd ed rules could block a doorway). You will find that the game flows better actually with no doorways and just large areas of dungeon to run through
Hope this helps
Cheers....
PostPosted: Mon Jul 13, 2009 4:08 am
The larger squares would be easier, the single wide doors we actually played as double wide since the are centered between squares.  I probably will only keep this set until I can kind some bigger squares, better for fitting larger miniatures in.
We played today.  It was pretty fun, my Orks were down 3 players very fast due to an exploding chest, getting lost in the warp from a teleporter, and then the sneaky gitz Oomies put another one down.  The Humans controlled the ball most of the game but it was the orks who scored the winning goal!
Whack a Oomie!
GGGOOOOAAAALLLLLLL!!!!!
PostPosted: Tue Jul 14, 2009 4:27 am
Looks like a nice set up.  What is the manufacturer of those dungeon pieces?
PostPosted: Tue Jul 14, 2009 4:58 am
Not sure, I bought them on ebay (search for dungeon tiles).  They were about $33 for all of it.  Supposed to be 25-30mm in scale but 25mm is the reality of it.  I will probably keep them until I get some quality card stock dungeons tiles or a different set of larger cast tiles.
 Post subject: Re: Dungeon Bowl
PostPosted: Sat Aug 27, 2011 7:25 pm
Really nice stuff!
Did you painted the tiles or did they came like that (they seem to be some kind of grey with white drybrush)?
cron
