Saganami Island
 Post subject: Saganami Island
PostPosted: Tue May 02, 2006 4:56 pm
This should get the attention of L4/Primarch: :D
Space Combat in the Universe of Honor Harrington
http://www.adastragames.com/products/adastra/sits.html
Saganami Island Tactical Simulator uses the critically acclaimed Attack Vector: Tactical game engine to put you in command of the ships of the Honorverse. Thrill to the long range missile duel, dancing in 3-D vector space with broadsides of laser heads. Or close in to "kissing distance" and unleash the titanic fury of grasers and lasers! An innovative card draw mechanic incorporates "The Honor Factor" without turning the game engine into a series of speciall cases modifying special cases.
Extensively researched, SITS has new material on the ships and doctrines of the Royal Manticoran Navy and the People's Republic Navy. Building rich tactical depth from easy-to-use Newtonian movement, SITS builds on the novels to give you control of small squadron actions in the Honorverse.
SITS uses two game scales - the tactical game scale has 7.5 minute turns, and 125,000 km hexes. The system scale uses 25 light second hexes and 1 hour turns, with simple rules for transitioning between scales.
Every warship in the series will be statted out over the course of this product, including additional ships approved by David Weber himself.
SITS offers tactical control without massive record keeping - watch salvoes of hundreds of missiles melt away with a handful of die rolls.
Simultaneous Sequence of Play means that everyone at the table is doing something, rather than waiting for the other guy to finish their turn.
Accurate, intuitive 3-D movement system, allowing combat to break the plane of the map, and giving unprecedented tactical depth.
In addition to SITS, we are also producing Havenite and Manticoran miniatures, and calendars of ship artwork!
Apologies if this has been posted before but had quick look and could n't see any previous threads.
James
My Epic trades list
PostPosted: Fri May 05, 2006 7:55 am
$75 for the rules and cardboard boxes as ships? ???
At that price I should at least get some plastic ships.
Think I will pass on this one.
Thanks for the heads up though.
dafrca
              - Cities of Death, page 59
