[AI] Bat Rep- Dawn Raid on Saint's Triumphant Span
 Post subject: [AI] Bat Rep- Dawn Raid on Saint's Triumphant Span
PostPosted: Sat Jul 27, 2013 3:21 am
Greetings,
My Air PDF had a rematch against the Dark Eldar. This time, the PDF were on the offensive!
Dawn Raid on the Saint's Triumphant Span
After the fall of Spacer's Point, the Dark Eldar raid on Perdition continued. Urgent calls for aid rang out across the void. However, until reinforcements responded, it was up to the Perdition PDF to fend off the xeno raiders and protect the loyal citizens of Perdition.
Reports came in from all across the planet of alien raiders appearing as if from thin air to attack civilian centers. The lucky ones were killed screaming in agony from the Dark Eldar slaver's exotic wargear, while the unlucky were hauled back into the blackest shadows from whence the aliens came.
Dark Eldar raiders appeared inside St. Drucker's hive. The local PDF troops immediately set-up a cordon across the Saint's Triumphant Span to keep the aliens from entering the St. Crozian Hive spire. However, to isolate them to the opposite side of the bridge, the local PDF called for an air strike to destroy the Saint's Triumphant Span to contain the menace.
In the darkness of the Perdition night, local PDF air assets were scrambled to the Saint Triumphant Span. As they approached, their chronometers alerted them to the coming sunrise. In addition, their ground controllers reported erratic augur readings moving to intercept. The pilots of the mission could only assume the worst, Dark Eldar aircraft were inbound. Each pilot was left in radio silence to make peace with the God-Emperor as the target areas zoomed into view.
You can read all about it here:
http://z8.invisionfree.com/Airspace/ind ... wtopic=951
Do you like Free Wargames?
http://bloodandspectacles.blogspot.com/
 Post subject: Re: [AI] Bat Rep- Dawn Raid on Saint's Triumphant Span
PostPosted: Sat Jul 27, 2013 3:37 am
Yes!!!
