Post new topic Reply to topic  [ 655 posts ]  Go to page Previous  1 ... 39, 40, 41, 42, 43, 44  Next
THE RETURN OF THE PRIMARCHLOAD!!!!
 Post subject: Re: THE RETURN OF THE PRIMARCHLOAD!!!!
PostPosted: Thu Jul 28, 2016 5:16 pm
IG bikers, lots of them!
Close up.
PostPosted: Thu Jul 28, 2016 5:17 pm
Ogyrns!
Close up.
PostPosted: Thu Jul 28, 2016 5:18 pm
That should be it, unless I forgot something more. ,LOL!
PostPosted: Fri Sep 30, 2016 4:08 pm
Very impressive! Im speachless!
Wonder how all your empire of man (including Squats) would fare against all other non-human armies on this board :)
PostPosted: Sat Oct 01, 2016 1:37 am
I'm unfamiliar with that t-hawk lander. It intrigues me. Greatly.
-Vaaish
PostPosted: Sat Oct 01, 2016 4:03 am
You, trying to out do me.... ;D ;D ;D
OK you win... ;) ;)
so any chance you can send me over a dozen Hydras..PLEASEEEEEEEEEEEEEEEEE ;D ;D ;D
Regards
Greg
PostPosted: Fri Oct 14, 2016 9:24 pm
The Imperial Army is the largest in the Collection.
Conservatively it is probably somewhere north of 250,000 points, not including titans. Adding Squats would push it over 300k.
Then again my memory is bad and my estimations could be grossly undershooting reality. ;)
PostPosted: Fri Oct 14, 2016 9:26 pm
Its a forumware model.
It is a MONSTER!
All metal and very heavy.
I could literally kill some one by hitting them on the head with it. It is THAT heavy.
While a great model it has proven hard to properly storing it due to weight and size.
PostPosted: Fri Oct 14, 2016 9:27 pm
OK you win... ;) ;)
The only army I am not updating is the IG. Mainly due to size.
Once all other projects are done (tall order). I will tackle updating that one as well.
I'll remember you when I need to "get rid of stuff". ;)
PostPosted: Sat Oct 15, 2016 12:53 am
Cool you have my email address...... :D :D :D
Regards
Greg
PostPosted: Sat Oct 15, 2016 10:52 pm
One would think that 1 Leviathan was enough. =P
PostPosted: Sat Oct 15, 2016 11:45 pm
1 is never enough for Primarch. :D
PostPosted: Sun Oct 16, 2016 12:17 am
This makes for a good motto or T-shirt. ;)
PostPosted: Sat Dec 17, 2016 10:38 pm
Genehost
this is absolutly amazing
PostPosted: Sun Dec 18, 2016 2:41 am
That's what they say. ;)
Would it shock you to know compared to what is being worked on right now, all that is on this thread is "nothing" in comparison?
There are 4 of about 30 projected commissions already being painted. Two of the latest ones sent out weight 39 and 41 pounds respectively. Minus a few pounds for the packing materials that is 35lbs+ of metal to be painted on.
Having packed it, it is a staggering amount. The recipients tell me its pretty unbelievable too. ;)
These 4 barely scratch the surface of what is laid out in my hobby room. If I were to extrapolate the weight it is easily above 1000lbs.
That these 4 have eaten through over 1000 infantry bases and over that in vehicle bases, should give you a hint on size.
I had to make a restock order for bases before even these went out.
The base makers seem to know me well by now and sent my order really fast. ;)
Each commission will be revealed here once completed. I believe 2017 will see the completion of one (if not all) of these 4 initial ones.
It will be one for the ages. :)
