Death Guard Myphitic Blight Hauler
 Post subject: Death Guard Myphitic Blight Hauler
PostPosted: Mon Nov 20, 2017 4:32 pm
New
 Post subject: Re: Death Guard Myphitic Blight Hauler
PostPosted: Mon Nov 20, 2017 8:40 pm
Any more details?
PostPosted: Mon Nov 20, 2017 8:51 pm
The data sheet is online
https://www.reddit.com/r/Warhammer40k/c ... datasheet/
It looks like a multi-melta and a missile launcher so far and it's maw
The bile spurt is like a small flamer
It has a fixed save of 5+
Armour should be around 2+ to 3+
Caf +4 around due to its maw
Move 20cm
Cost 150 for 3 estimated
PostPosted: Mon Nov 20, 2017 10:30 pm
Interesting. I like that they are adding more daemon engines to the chaos factions. Khorne had so many.
Now to see how they can be added to my queue. ;)
PostPosted: Mon Nov 20, 2017 10:40 pm
Wow ! Very interesting ! Nice modeling job !
PostPosted: Mon Nov 20, 2017 11:11 pm
Hey I didn't paint it I'm just an info miner.
Check this out https://www.shapeways.com/product/QUC53 ... arketplace
https://www.alternative-armies.com/coll ... nce-turret
https://www.alternative-armies.com/coll ... oom-spores
http://sciborminiatures.com/en_,shop.ph ... n_p_02.jpg
https://www.alternative-armies.com/coll ... es-save-10
PostPosted: Wed Nov 22, 2017 2:25 pm
Move 20cm
crap it's all in 8th edition (of course) which I need to give a read to in order to port to EA stats (too much has changed to use the previous processes). Anyone up to date with the latest rules?
Edit: actually if someone has say Leman Russ stats and/or Baneblades I should be able to build out from there
PostPosted: Wed Nov 22, 2017 3:46 pm
SquatWarlord wrote:
Regardless it is a nice paint job ! So thanks for passing on good intel ! 8)
PostPosted: Wed Nov 22, 2017 4:29 pm
Apparently trying to share screenshots from a Chromebook to a forum is a nightmare, but here's a linky:
Index Imperium II
Relevant comparisons:
- Same speed as a Leman Russ
- T7 8W 3+ Sv vs. a Russ' T8 12W 3+ Sv vs. a Rhinos T7 10W 3+ Sv vs. a Land Speeders' T5 6W 3+ Sv (also, S vs T changed this edition, with less than double your S being wounded on 5+, so 8 is the magic T at which bolters and flamers can no longer shred you)
- Has an invuln save as per normal for a daemon engine
- Standard 40K Imp Guard BS of 4+ for the Multi-Melta and Missile Launcher
- Bile spurt and Gnashing maw are probably just FF and CC weapons for EA without special rules (the plague weapon ability is pretty trivial)
- Some variant of the explosion on death thing is almost universal for vehicles in new 40K, no need to incorporate that
- Might want to work in the Putrescent Fog ability somehow though?
Last edited by NoisyAssassin on Wed Nov 22, 2017 10:30 pm, edited 1 time in total.
PostPosted: Wed Nov 22, 2017 7:57 pm
I only play Netepic so my stats for this were based on that not EA
PostPosted: Thu Nov 23, 2017 8:03 pm
yup, understood. Wasn't directed at you :P ;)
Index Imperium II
Nice one!
Hrmmm so putting on my thinking cap here. I'm apt to keep it as an AV as you not, it's just over the line in T, albeit with a shitter save, so... 5+? Agreed the maul and other nurgle shit is abstracted away into the FF/CC values.
So perhaps...
AV M:20cm, A:5+, F: 5+, C:5+
Multi-melta 15cm MW5+
and (15cm) Small Arms MW
Missile Launcher 45cm AP5+/AT6+
Notes: Invulnerable save, fearless
PostPosted: Fri Nov 24, 2017 12:43 am
That looks like a pretty accurate statline to me! Now whether or not the unit would be useful at all is another question...
PostPosted: Fri Nov 24, 2017 2:24 pm
yeah not sure what it brings to the table but still fun to have as an option. perhaps I should resurrect my collated Random Epic Stats document that had all these lost children units put into one place for those that wanted to play?
PostPosted: Fri Nov 24, 2017 3:02 pm
Do it!
PostPosted: Fri Nov 24, 2017 3:46 pm
Yeah, I'll be getting one at least. 8th edition is pretty damned good and GW is just the best once again.
Seeing it in epic scale would be awesome, too, guys.
